What is the most accurate way to measure pushing force for a trolley on wheels?
  • Context: High School
  • Thread starter Thread starter monstereyebrows
    Forces
The discussion revolves around methods for measuring the pushing force required to move a trolley on wheels. Participants explore various tools and calculations related to force measurement, including weighing scales and Newtonmeters, while considering the complexities of friction and movement.
  • Peter inquires about using weighing scales mounted on a trolley to measure pushing force and whether calculations can replace precise measurements.
  • Warren suggests that while bathroom scales could theoretically measure force, they may be inaccurate when mounted horizontally and recommends using a spring scale instead.
  • Warren notes that calculating the force required to move the trolley is complicated due to factors like axle bearings and wheel deformation, making precise calculations challenging.
  • Another participant mentions that using a Newtonmeter would be easier for measuring the forces involved, although they express uncertainty about where to obtain one.
  • Warren emphasizes the importance of selecting a Newtonmeter that can measure the appropriate force range.
  • A later reply clarifies the terminology differences between the UK and US regarding the term 'Newton meter' and provides a link to a source for purchasing one.
Participants generally agree that measuring the pushing force can be complex and that using a Newtonmeter may be a more effective approach than weighing scales. However, there is no consensus on the best method or the feasibility of calculations versus measurements.
The discussion highlights limitations in measuring techniques and the complexity of factors affecting force measurement, such as friction and mechanical properties of the trolley.
monstereyebrows
Hi I am new to physics so be gentle!
I am involved in training people in lifting, carrying, pushing and pulling.
My question is: If I wanted to measure the pushing force required to move a trolley/cage/bin on wheels could I use a pair of weighing scales mounted on the trolley/cage/bin to measure the force?
2nd question: If I know the weight of the trolley/cage and its load weight is it posible to do a basic calculation of the pushing force required to start to move the trolley and the force to keep it moving. Or would I always have to measure it presisely?
many thanks for your replies.
Peter
Welcome! Glad to have you here. :smile:
In principle, yes, you can glue bathroom scales to the trolley and use them to measure the force necessary to get the train moving. All an "ideal" bathroom scale does is display the force applied to its top surface -- in other words, the force "squeezing" its top and bottom surfaces together. In practice, however, bathroom scales may not work mounted horizontally, or they may be wildly inaccurate. Besides, I think bathroom scales only go to a few hundred pounds. A more precise measuring tool is a spring scale -- you attach one end to the trolley, and pull on the free end of the spring. The amount the spring stretches is a measure of the force applied to it. Of course, I'm not sure where you would get such a spring... maybe someone else has some practical engineering expertise. Strain gauges maybe?
If the trolley were just a block of wood sliding on a surface, you could easily calculate the force required, considering the coefficient of friction between the wood and the surface.
However, the trolley is quite a bit more complicated. The friction experienced by the trolley is due to the bearings of its axles and the deformation of the wheels and track as it rolls. These are very complex mechanisms, and probably, well, virtually impossible to calculate with any success.
- Warren
Yes it'd proably be a lot easier to use a Newtonmeter as they are designed to measure just these sort of things. I've got no idea where to get one of these from, but I don't imagine they're too difficult to get hold of.
...but make sure you express your trolley in joules.
- Warren
Another thing about Newtonmeters, make sure you get one that can measure the sorts of forces that are involved as they come in all sorts of different ranges.
I suppose the name 'Newton meter' wouldn't be used in the US as it's the exact same spelling as the unit of torque, but in the UK they're called Newton meters:
http://www.scalesontheweb.co.uk/products_list.asp?Tquest=1&catid=82&MenuLinkName=Salter%20Brecknell%20Newton%20Meters
edited to add link and change text
  • · Replies 26 ·
  • · Replies 23 ·
