Understanding Faulhaber's Formula for Sum of Powers of n Integers
  • Context: Graduate
  • Thread starter Thread starter plzhelpme
    Formula Integers Sum
Faulhaber's Formula provides a method for calculating the sum of the pth powers of the first n integers. The formula can be effectively applied using the Euler-MacLaurin summation technique, which involves rewriting the sum as a Stieltjes integral and integrating by parts until the remaining integrand is zero. Understanding Bernoulli numbers is essential for applying Faulhaber's Formula correctly. Numerous references are available for both the Euler-MacLaurin summation and Bernoulli numbers to facilitate deeper comprehension.
  • Understanding of Faulhaber's Formula
  • Familiarity with Euler-MacLaurin summation
  • Knowledge of Stieltjes integrals
  • Comprehension of Bernoulli numbers
  • Research the derivation of Faulhaber's Formula
  • Study the Euler-MacLaurin summation technique in detail
  • Explore the properties and applications of Bernoulli numbers
  • Practice solving problems involving sums of powers using Faulhaber's Formula
Mathematicians, educators, and students interested in advanced calculus and number theory, particularly those focusing on summation techniques and polynomial expressions.
plzhelpme
hi everybody, I have a question in math to figure out the general term for the sum of the pth powers of n integers. I found a formula called faulhabers formula to do this question, but I do not understand the method behind it. can someone please help me?
You can prove it using Euler-MacLaurin summation, where you essentially rewrite the sum as a Stieltjes integral then integrate by parts enough time that the remaining integrand is zero (the p+1 derivitative of x^p vanishes). Look up Euler-MacLaurin summation (lot's of references).
Or are you trying to understand how to apply Faulhaber's in a given situation? It's just plug and chug, but you'll need to know what the Bernoulli numbers are (again, lots of references)
