Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Precalculus Mathematics Homework (http://www.physicsforums.com/forumdisplay.php?f=155)
-   -   Inverse matrices help please (http://www.physicsforums.com/showthread.php?t=118874)
lakitu Apr26-06 03:51 PM
inverse matrices help please
hi there would anyone be able to give me a link or guidence as how i would go about finding the inverse of A? I have a book that tells me add subtract and multiply.
the question is this: find the inverse of A
A =
(19 81)
(2 10)
sorry for the crude matrices. any help would be great :)
lakitu
vladimir69 Apr26-06 06:42 PM
there is a trick for finding the inverse of a 2x2 matrix
[tex]A=\left( \begin{array}{cc} a & b \\
c & d \end{array} \right)[/tex]
then
[tex]A^{-1}=\frac{1}{ad-bc}\left( \begin{array}{cc} d & -b \\
-c & a \end{array} \right)[/tex]
provided ad-bc is not equal to zero
hope that helps
Gale Apr26-06 08:40 PM
http://www.purplemath.com/modules/mtrxinvr.htm
halfway down is how i usually find matrices. always works, so thats what i use.
lakitu Apr27-06 06:48 AM
thank you for your comments :)
HallsofIvy Apr27-06 01:45 PM
If your book is telling you "add, subtract, and multiply" (hey, that's how you solve any mathematics problem!:rolleyes: ) then go back and read over exactly what you add and subtract and what you multiply by. I suspect that your book is talking about "row operations"- that's what Gale's website is talking about.
robphy Apr27-06 09:22 PM
Before rushing off to a formula or procedure, it might be helpful to understand what you are trying to do when determining the inverse of a matrix.
Given a square matrix [tex]A=\left( \begin{array}{cc} a & b \\
c & d \end{array} \right)[/tex],
its inverse [if it exists] is another square matrix [tex]A^{-1}=\left( \begin{array}{cc} p & q \\
r & s \end{array} \right)[/tex] such that the matrix product is the identity matrix.
[tex]
\begin{align*}
AA^{-1}&=I\\
\left( \begin{array}{cc} 1 & 0 \\
0 & 1\end{array} \right)
\end{align*}
[/tex]
If you carry out the matrix multiplication, you should find a simple system of four linear equations in four unknowns... "simple" because it's really a pair of systems of two linear equations in two unknowns. You can easily solve these systems to obtain the formula given by vladimir69 above.
(In addition, the inverse would satisfy [tex]A^{-1}A&=I[/tex] as well.)
HallsofIvy Apr28-06 05:59 AM
Of course, if you have a 3 by 3 or 5 by 5 matrix, so that your system is 9 equation in 9 unknowns or 25 equations in 25 unknowns, you might find robphy's method a bit tedious! I think it's worth learning row reduction.
MathematicalPhysicist Apr28-06 06:05 AM
Quote:
Quote by vladimir69
then
hope that helps
i think it's a bit more trickier than just plain trick, it's actually a theorem.
robphy Apr28-06 06:26 AM
Quote:
Quote by HallsofIvy
Agreed!... assuming one first understands what it means to take the inverse of a matrix.
Hurkyl Apr28-06 07:42 AM
This is how I like to think of it. If this doesn't make sense to you, feel free to forget about it so you don't get confused!
We start off with the partitioned matrix:
[A : I]
which has the property that: (the left matrix) = (the right matrix) * A. In particular, A = I*A.
Now, if we do row operations, we will get some other partitioned matrix:
[B : C]
which still has the property that: (the left matrix) = (the right matrix) * A. In particular, B = C*A
If we fully row-reduce the left hand side, we get the partitioned matrix:
[I : V]
which still has the property that (the left matrix) = (the right matrix) * A. In particular, I = V*A, and therefore V is the inverse of A.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
