Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Differential Geometry (http://www.physicsforums.com/forumdisplay.php?f=76)
-   -   levi-civita permutation tensor, and kroneker delta (http://www.physicsforums.com/showthread.php?t=119039)
Divisionbyzer0 Apr27-06 11:17 PM
Hello, I'm interested in seeing some proof of the identities involving the levi civita permutation tensor and and the kroneker delta. I've discovered the utility and efficiency of these identities in deriving the standard vector calculus identities involving div, grad, and curl, but I'm sort of just applying a formula which I am taking on faith in the process.
I have no formal knowledge of tensors, tensor calculus and the like, and little formal linear algebra knowledge.
Is it possible to find a proof of these identities which doesn't involve one or the other, or one which is semi-convincing that I can satisfy myself with before taking on the subjects of linear algebra and tensor analysis?
Thanks!
robphy Apr28-06 07:46 AM
No "calculus" (i.e. derivatives) are involved... just "algebra".
Check out:
http://physicsforums.com/showthread.php?t=82919
especially post #6.
These may be useful:
http://www.uoguelph.ca/~thopman/246/indicial.pdf
http://www.damtp.cam.ac.uk/user/gio10/nst_notes.pdf
silviacipi Nov19-06 07:32 AM
Hello, can anyone help me?
I have to solve this 3-dimension integral:
ui*uj*uk*ul du
where u is a versor.
Is it equal to:
delta(i,j)*delta(k,l)+delta(i,k)*delta(j,l)+delta(i,l)*delta(j,k)?
where delta=delta Kronecker
if yes what about the the integrals:
ui*uj*uk*ul*um du
and
ui*uj*uk*ul*um*un du?
(ui,uj,ul,um,un generic component of the versor u)
. I apologize if I don't use Latex (it isn't my pc)
Thanks
silvia
dextercioby Nov21-06 02:04 AM
Well the versor must be written in a basis and therefore its components in that basis must be written in any integral.
IF you know the LaTex code you could just type formulas inside [ tex ] tags.
Daniel.
silviacipi Nov22-06 03:43 AM
Hi, the integral that I have to solve is this:
[tex]\begin{equation}
\int{d^3u u_a u_b u_c u_d u_e u_f}
\end{equation}[tex]
If I have the T^6 of the Legendre polynom in three dimension all would be done!
silvia
silviacipi Nov22-06 03:49 AM
sorry I wrong [tex]!!
[tex]
[/tex]
silvia
silviacipi Nov22-06 03:50 AM
I wronged again...now maybe!
\end{equation}[/tex]
silvia
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
