Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Integrals of normal derivatives (http://www.physicsforums.com/showthread.php?t=120374)
Benny May10-06 03:54 AM
Hi can someone please help me out with the following questions?
Supposed that [itex]\phi [/itex] is a C^2 function which satisfies Laplace's equation [itex]\nabla ^2 \phi = \nabla \bullet \nabla \phi = 0[/itex] everywhere in a region V bounded by a closed surface S.
a) If [tex]\frac{{\partial \phi }}{{\partial n}} = \mathop n\limits^ \to \bullet \nabla \phi [/tex] denotes the direction derivative of [itex]\phi[/itex] in the direction of the outward unit normal n, establish the following.
[tex]
\int\limits_{}^{} {\int\limits_S^{} {\frac{{\partial \phi }}{{\partial n}}} \partial S = 0}
[/tex]
[tex]
\int\limits_{}^{} {\int\limits_S^{} {\phi \frac{{\partial \phi }}{{\partial n}}dS = \int\limits_{}^{} {\int\limits_{}^{} {\int\limits_V^{} {\left\| {\nabla \phi } \right\|^2 } } } } } dV
[/tex]
b) If [tex]\frac{{\partial \phi }}{{\partial n}}[/tex] vanishes everywhere on S, deduce from the second result that [itex]\phi[/itex] must be constant in V.
c) If [itex]\phi[/itex] vanishes everywhere on S, deduce from the second result that [itex]\phi[/itex] must vanish everywhere in V.
Part a: Phi is a function of three variables, otherwise the question wouldn't really make sense. I tried to visualise what the statement meant so I tried some specific cases. If S is a hemisphere then V is a half unit ball. The gradient of phi is pendicular to level sets of phi so in this case the gradient of phi is a normal to V (since phi is a function of three variables). So in this case, the unit normal n, to S, is parallel to grad(phi). So how can the integral be zero? The integrand is non-zero. I'm not sure what to do here.
For the second result I'm fairly sure that I need to apply the divergence theorem. But I don't really know how to 'div' the integrand of the surface integral because I don't what the normal, n, is. I think I might need to use a general property somewhere here but again I really don't know what to do.
Part b: If the partial derivative with respect to n is zero on S then from the second result, the triple integral on the RHS must be equal to zero everywhere in V. This can only be the case if the integrand (grad(phi))^2 is identically zero. So phi is constant in V? Not sure.
Part c: I can't think of a way to do this.
ANy help would be good thanks.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
