Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Substitution homework question (http://www.physicsforums.com/showthread.php?t=122079)
suspenc3 May26-06 02:27 PM
Hi, Im having a little bit of trouble with the following:
[tex]\int sintsec^2(cost)dt[/tex]
heres what I have so far
[tex]u=cost[/tex]
[tex]du=-sintdt[/tex]
[tex]-\int sec^2(u)du[/tex]
[tex]-2tan(u) + C[/tex]
is this right?
vsage May26-06 02:30 PM
As I recall the derivative of tan(u) is sec^2(u)du
suspenc3 May26-06 02:33 PM
yea but im integrating..so the antiderivative of sec^2(u) is tanu?
Hootenanny May26-06 02:36 PM
[tex]\int \sec^2 x \; dx = \tan x +c[/tex]
~H
suspenc3 May26-06 02:42 PM
I have another..i dont know where to start..can someone point out what I should sub U for?
[tex]\int_{1/2}^{1/6}csc \pi t cot \pi t dt[/tex]
Hootenanny May26-06 02:51 PM
Quote:
Quote by suspenc3
My first step would be to turn the cosec and cot into sine and cosine. See where that takes you.
~H
suspenc3 May26-06 03:01 PM
ok..so i did..
[tex] \int_{1/2}^{1/6} \frac{1}{sin\pi t) \frac{cos \pi t}{sin \pi t}dt[/tex]
ended up with...
[tex] \int_{1/2}^{1/6} cot \pi t[/tex]
im guessing its wrong haha
Hootenanny May26-06 03:07 PM
Quote:
Quote by suspenc3
ok..so i did..
ended up with...
It's almost there :wink:
[tex]\frac{1}{\sin \pi t} \cdot \frac{\cos \pi t}{\sin \pi t} = \frac{\cos \pi t}{\sin^2 \pi t}[/tex]
Now, see what you can do with the identity [itex]\sin^2 \theta + \cos^2 \theta = 1[/itex]. Btw, I think this can be done without a substitution.
~H
suspenc3 May26-06 03:14 PM
do you mean..sin^2(pi t) = 1-cos^2(pi t)..and then sub?
arunbg May26-06 03:25 PM
Forget about the subs.
Try putting sin(pi*t) = x
What is dx ?
HallsofIvy May26-06 05:58 PM
Quote:
Quote by suspenc3
[tex]u=cost[/tex]
is this right?
As others have pointed out, the anti-derivative of sec2(u) is tan(u), not -tan(u).
Also, the original problem does not say anything about "u"! That was your "invention". To properly answer the question, you need to go back to t:
[tex]\int sintsec^2(cost)dt= 2tan(cos(t)+ C[/tex]
EbolaPox May26-06 06:25 PM
Actually, the original poster (with respect to the original question) is correct, save for the two.
[tex] \int sin(t) sec (cos(x))^2 dx [/tex]
[tex] u = cos(x) du = -sin(x) dx [/tex] This is right. Substituting back yields
[tex] - \int sec(u)^2 du [/tex] Just as the OP said. The negative sign is the result of the du = -sin(x) dx part.
Now, the antiderivative of sec(x)^2 = tan(x) + C (as everyone as stated)
- ( tan(u) + C)
-tan(cos(x) + C.
The original poster's only error is the two infront. The minus sign is correct . Check with differentiatoin (or use the "Integrator").
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
