Solving Reduction Formula: Step-by-Step Guide
  • Thread starter Thread starter suspenc3
    Formula Reduction
The discussion revolves around the use of a reduction formula to evaluate the integral of sin²x. Participants are exploring the process of applying this formula and clarifying their understanding of the steps involved in integration techniques related to trigonometric functions.
  • Participants discuss the reduction formula and its application, questioning the necessity of integration by parts. There are attempts to verify the relationship between sin²x and cos(2x) as part of the integration process. Some participants express confusion about the substitution method and the relevance of example 6 provided in the problem statement.
The discussion is active, with various interpretations being explored. Some participants have offered guidance on applying the reduction formula directly, while others are still grappling with the concepts and seeking clarification. There is a mix of understanding, with some expressing that they have found clarity while others continue to seek assistance.
Participants are working under the constraints of a homework assignment, which specifies the use of a particular reduction formula. There is mention of example 6, which is referenced as a guide for solving the integral, but the details of this example are not fully disclosed in the discussion.
suspenc3
Hi, I am having trouble understanding this question, I have looked over a few examples, but I'm still confused about the process.
A)Use the reduction formula to show that:
[tex]\int sin^2xdx = \frac {x}{2} - \frac{sin2x}{4} + C[/tex]
any help would be appreciated
I assume you're referring to the reduction of the exponent?
Using cos(2x) = cos²x-sin²x combined with cos²x+sin²x = 1, you can derive the following formulas to get rid of a square in cos or sin:
sin²x = (1-cos(2x))/2 and cos²x = (1+cos(2x))/2
Try to verify this yourself.
Now, using the first formula, do you see how the integral was done?
i am still confused, this is the first question like this I have done. The question says to refer to ex.6...here it is:
[tex]\int sin^nxdx = -\frac{1}{n}cosxsin^n^-^1x + \frac{n-1}{n} \int sin^n^-^2xdx[/tex]
let: [tex]u=sin^n^-^1[/tex]
[tex]dv=sinxdx[/tex]
[tex]du = (n-1)sin^n^-^xcosxdx <br /> <br /> [tex]v=-cosx[/tex]<br /> <br /> integration by parts;<br /> <br /> [tex]\int sin^nxdx = -cosxsin^n^-^1x + (n-1) \int sin^n^-^2xcos^2xdx[/tex]<br /> ...[/tex]
I see, they really mean a reduction formula for the integral (a bit overkill for such an integral, imho).
In that case, compare the formula (your first line) with the problem. It's exactly the same, only n = 2.
So apply the formule with n = 2, no integration by parts is necessary (unless you'd want to prove the reduction formula, but that isn't asked here!)
so [tex]u=sin^n^-^1[/tex]...i get that part..and end up with only -sinx
Are you trying to prove the reduction formula you gave?
I don't understand why you keep coming that this 'u' for a substitution.
I understand the problem as:
Find
[tex]\int sin^2xdx[/tex]
Using the formula
Is that what you're supposed to do? If so, apply this last formula with n = 2.
I am trying to show[tex]\int sin^2xdx = \frac {x}{2} - \frac{sin2x}{4} + C[/tex]
using the reduction formula shown in example 6:[tex]\int sin^nxdx = -\frac{1}{n}cosxsin^n^-^1x + \frac{n-1}{n} \int sin^n^-^2xdx[/tex]
and in that example they let [tex]u=sin^n^-^1[/tex]etc...shouldnt i do the same for what i am trying to show?
i made this too complicated...hahaha so easy..nvm i understand now
thanks
I think that in example 6, they have proven this formula. In order to do this, they'll have used integration by parts I assume.
What you now have to do (*I think*), is use this formula (not prove it again) on the particular problem.
In ex 6, they've set up a relation between the integral of sin(x)^n and an integral with sin(x)^(n-2), so this formula allows you to reduce the exponent by 2 every time you apply it. Now in your problem, you wish to find the primitive of sin²x, you can use this formula with n = 2.
  • · Replies 22 ·
