Force required to slash through chain or steel mail
  • Context: Undergrad
  • Thread starter Thread starter Adam
    Chain Force Steel
The discussion revolves around the forces required to slash through chain or steel mail armor using a sword, with comparisons made to the force needed to shear an iron nail. Participants explore the mechanics of swinging a weapon, the materials involved, and the impact of geometry on the effectiveness of the strike.
  • One participant mentions that approximately 900-950 Newtons is needed to shear an average iron nail and questions how much force is required to slash through chain or steel mail armor.
  • Another participant suggests that pressure, rather than force, may be a more relevant measure for this scenario.
  • It is noted that the strength of chains varies significantly, and the material and shape of the sword are critical factors in determining the effectiveness of the strike.
  • A participant emphasizes that chain mail is designed to give way upon impact, which may affect the energy distribution during a strike compared to a nail embedded in wood.
  • There is a discussion about the geometry of the sword and the chain, with examples given of different scenarios involving varying materials.
Participants do not reach a consensus on the specific forces involved or the most appropriate measures to consider. Multiple competing views regarding the nature of the materials and the mechanics of the strike remain present.
Participants highlight the variability in chain strength and sword design, which introduces uncertainty into the discussion. The impact of energy distribution and geometry on the effectiveness of slashing is also noted but remains unresolved.
Adam
In addition to the question in https://www.physicsforums.com/showthread.php?s=&threadid=12538 I have a few other queries related to combat.
I've read that the it requires about 900-950 Newtons to shear an average iron nail. I'm wondering how much would be required to slash through chain or steel mail armour with a sword, given that the links are made of rings generally about the thickness of a nail.
It's generally no problem for the human body to exert over a thousand Newtons when lifting at the gym, for example, but I'm not sure how much force is involved if we swing a sword and it is focused into that small area (the point of impact from a sword).
Ah, in general, I guess what I'm asking is, how do I work out the forces involved in the swing of a weapon of fist or such? How much body mass do I include, how much movement of the entire body is added to the speed of a swing, et cetera.
PS: The Momentum thread was kinda funny.
I don't think that force is the appropriate measure. I think that pressure is more pertaining to the question.
A lot of what you're asking depends on the chain and the sword.
Chains vary in strength from gold wire which can be broken with fingers to massive chains used to hold boats in place which have links made out of steel several inches thick. Similarly, the material and shape of the sword is important. Is the sword a laser cutter, or a baguette?
Once you have determined the materials that you are using, you can start talking about how the chain is going to be broken.
Of course, there's always a question of geometry as well.
So, regarding your question:
Can someone with a bronze dagger use it to break a steel anchor chain? No.
Can someone with a claymore use it to bust a gold neclace? Almost certainly.
What you want to know about is probably somewhere between those two. In practice, sawing through chains is easier and safer.
I believe Adam was talking about chain-male armor, not a chain like an anchor chain. In comparing chain-male to a nail, I think the most important fact to remember is that chain-male is made to give way when struck, much like today's bullet-proof vests. So whatever amount of energy is required to bring your sword to a halt, that energy is spread out over a short amount of distance (about 1 or 1 1/2 inches), and a short period of time. This makes chain-nale armor much more resistant to breakage than a nail stuck in wood.
  • · Replies 24 ·
9K
  • · Replies 75 ·
  • · Replies 25 ·
9K
  • · Replies 38 ·
11K
