Rock climbing energy conservation
The discussion revolves around a physics problem related to energy conservation in the context of rock climbing. The scenario involves a climber falling while attached to a rope, and the goal is to determine the necessary properties of the rope to ensure the climber's survival during a fall. The problem incorporates concepts from mechanics, specifically the principles of energy conservation and Hooke's law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between gravitational potential energy, kinetic energy, and elastic potential energy in the context of a climber's fall. There are attempts to derive equations relating the stretch of the rope to the height of the fall and the forces involved. Some participants question the exclusion of kinetic energy gained during the fall and the correct application of energy conservation principles.
The discussion is active, with participants sharing their calculations and reasoning. Some have identified errors in their understanding of the forces acting on the climber and the energy transformations involved. There is a recognition of the need to account for the climber's weight and the maximum deceleration experienced during the fall, which has led to further clarification and exploration of the problem.
Participants are working under the constraints of a homework problem, which may limit the information available and the assumptions that can be made. The requirement to ensure the climber's survival introduces specific conditions that must be met regarding the rope's properties.
dfx
Hi,
A rather simple question that I just can't seem to solve:
The greatest instantaneous acceleration a person can survive is 25g, where g is the acceleration of free fall. A climber's rope should be selected such taht, if the climber falls when the rope is attached to a fixed point on a vertical rock, the fall will be survived.
A climber of mass m is attached to a rope which is attached firmly to a rock face at B as shown. When at a point A, a distance L above B, the climber falls.
http://img144.imageshack.us/img144/2483/rockclimbjh9.jpg
(the red bit is the rope)
(a) Assuming that the rope obeys Hooke's law upto the breaking, use the principle of conservation of energy and the condition for greatest instantaneous acceleration to show that the part AB of the rope (of unstretched length L) must be able to stretch by more than L/6 whithout breaking for the climber to survive
My working:
After the climber falls under freefall for a maximum distance of 2L (from A to B, and then the length L of the rope which makes it a total of 2L), then he has maximum kinetic energy which is K.E = [tex](1/2)mv^2[/tex] but [tex]v^2 = u^2 + 2as = 4gL[/tex]
Then K.E. = elastic potential energy + gpe ... (i)
EPE = [tex](1/2)kx^2 = (1/2)Fx[/tex]
and GPE = mgx , where x is the extension during the rope stretching.
So from (i):
[tex](1/2)mv^2 = mgx + (1/2)Fx[/tex] and since F = ma, with the maximum instantaneous acceleration of 25g, then F = 25mg
[tex]2mgL = mgx + (25/2)mgx[/tex]
[tex]2L = (27/2)x[/tex]
Therefore [tex]x = (4/27) L[/tex] ? but the required answer is x = L/6 ?
here's my suggestion, don't try and kill yourself by having expression like:
EPE = KE + GPE
KE after all comes from GPE so y dun we express it as:
EPE = GPE(Big)
Makes life much easier isn't?
But I don't get how you can just exclude the KE that is gained when falling the distance of 2L, because the GPE I've included is purely for the extension bit (x), and does not overlap with the GPE during the 2L fall.
Also if you do exclude it as you suggest, then I can't seem to get an equation with "L" in it, which is fundamental to solving the q.
Thanks for your help though. :smile:
dfx said:
So from (i):
The change in gravitational potential energy is [itex]\Delta(PE) = mg(2L+\Delta x)[/itex] where [itex]\Delta x[/itex] is the amount of the rope stretch. This is all converted into elastic potential energy of the rope at maximum stretch (KE = 0). If the maximum deceleration is 25g, the force is 26mg (weight of climber + 25mg for the deceleration). So kx = F has a maximum of 26mg:
[tex]mg(2L+\Delta x) = \frac{1}{2}k(\Delta x)^2 = \frac{1}{2}26mg(\Delta x)[/tex]
AM
Ah I ignored the weight! Thank you.
Also seem to have got the energy slightly messed up but I understand now.
thanks i was stuck on this queation and missed the weight of the person as well!
