Maximum Depth for Organisms Under the Sea
  • Thread starter Thread starter mikefitz
    Pressure
The discussion revolves around determining the maximum depth at which certain organisms can survive under the sea, given the pressure conditions and the density of seawater. The subject area includes fluid mechanics and biological limits of organisms in extreme environments.
  • Participants are attempting to calculate the maximum depth using pressure equations and the density of seawater. There are questions about the accuracy of their calculations and the assumptions made regarding pressure and organism survival limits.
There are multiple attempts to solve the problem, with participants sharing their calculations and expressing uncertainty about their results. Some guidance has been offered regarding the equations used, but no consensus has been reached on the correct approach or answer.
Participants are working under the constraints of homework rules, which may limit the information they can use or the methods they can apply. There is an ongoing discussion about the assumptions related to pressure and organism survival at depth.
mikefitz
The maximum pressure most organisms can survive is about 1000 times atmospheric pressure. Only small, simple organisms such as tadpoles and bacteria can survive such high pressures. What then is the maximum depth at which these organisms can live under the sea (assuming that the density of seawater is 1026 kg/m3)?
Ptotal = 10^5 (1000)= 100000000 Pa
100000000 Pa = (1026)(9.81)(d)
d= 9935m= 9.94km?
This is wrong but I am unsure why...
any ideas??:-p thanks!
ahh, I'm still workin on this one, here is my latest try:
1000 atm=101325000 Pa
101325000 = 101325 + 1026*9.81*d
d=909.64m
=.909km
this is still wrong but I've no idea why? Thanks
Hmm... that equation you came up with looks like
[tex]10^8\approx 10^5+10^4d[/tex]
so it should work out to roughly
[tex]d \approx 10^4[/tex]
but you come up with
[tex]d \approx 10^3[/tex]
I'd guess that your first answer was correct modulo some approximation or rounding errors.
11K
