Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   General Physics (http://www.physicsforums.com/forumdisplay.php?f=111)
-   -   Radiation's equivalence principle (http://www.physicsforums.com/showthread.php?t=141667)
Lord Snooty Nov4-06 03:25 PM
Why is that an accelerated charge radiates in a zero-valued
gravitational field, whereas a charge in free-fall in a non-zero
gravitational field does not? Doesn't this contradict Einstein's
Equivalence Principle? Are we in fact already assured, via measurement,
of the free-fall case's outcome?
Phillip Helbig---remove CLOTHES to reply Nov4-06 03:25 PM
Re: Radiation's equivalence principle
In article <SQSFf.10817$1n4.2693@newsread2.news.pas.earthlink.net>,
"Lord Snooty" <bonzo@dog.com> writes:
For the definitive account, read http://arxiv.org/abs/gr-qc/9303025 .
Marc Millis Nov4-06 03:25 PM
In <SQSFf.10817$1n4.2693@newsread2.news.pas.earthlink.net> Lord Snooty
Good question.
The difference is that a charge falling in a gravitational field (which
is accelerating relative to the position of the gravitating body) is in
free-fall. "Free-fall" means that is not accelerating in its own frame
it, it does not "feel" inertial forces.
A charge that is accelerating in a zero-valued field must, even in its
own frame, experience the energy difference from whatever is
accelerating it, and react accordingly. To accelerate a charge in flat
space requires another source of force (energy).
Now, here is another thing to ponder. Why then does a charge that is
'stationary' in a gravitational field, say if it were sitting atop a
table and in which case it is indeed "feeling" the accelerating forces,
not radiate?
Marc
ebunn@lfa221051.richmond.edu Nov4-06 03:25 PM
To take the last question first, I think the answer has got to be no.
For gravitational accelerations of the amount we get around here in
the solar system, the typical wavelength of radiation is a light-year,
and the amount of energy radiated is really tiny.
But the question is a very interesting one from a purely theoretical
point of view. It gets rediscovered here on sci.physics.research
fairly often. I suggest you dig through back issues of the newsgroup
(say on groups.google.com), searching for the words "charged particle"
and "equivalence principle". You'll find me, among others, going on
at some length about it.
The biggest chunk of the answer, I think, is that the equivalence
principle is local -- that is, it makes sense only in small
neighborhoods. Most of the time, when someone says that something is
radiating, they're referring to a measurement that can only be made
far away from the something. At small distances, you can't tell the
thing's radiating, and at large distances, you can't use the
equivalence principle. So everything works out OK.
That's not the whole story. You can think of reasonable radiation
criteria that can be defined in a small neighborhood. So it's
quite a subtle problem!
-Ted
[E-mail me at name@domain.edu, as opposed to name@machine.domain.edu.]
In article <dscjn4$jed$2@online.de>,
Phillip Helbig---remove CLOTHES to reply <helbig@astro.multiCLOTHESvax.de> wrote:
I'll say what I always say when this comes up:
1. I heartily second Phillip's recommendation: Everyone who's at all
interested in understanding this issue should read this paper. It
lays out the relevant issues very clearly and makes arguments that are
well worth considering.
BUT
2. I don't think that the author has justified his main conclusion,
which is that "purely local experiments" can distinguish a charge in
uniform acceleration from a charge at rest in a uniform gravitational
field.
The purely local experiment he has in mind is a measurement of the
force required to support the charge in its motion. If it's at rest
in a uniform gravitational field, the force should be equal to the
charge's weight. If it's accelerating (he argues), it should be more
than that, because of the radiation reaction force.
The problem is that he hasn't shown that the radiation reaction force
for a uniformly accelerating charge is nonzero. The standard theory
of radiation reaction forces on classical point charges, the
Lorentz-Dirac equation, says that the force is zero in this situation.
The Lorentz-Dirac theory is famously pathological, but it's not clear
to me that the pathologies are relevant in this situation. Anyway,
since there's not really any better competing theory, there's no good
way to justify the claim that the force is nonzero.
-Ted
PS in case anyone's wondering:
It may seem obvious that the radiation reaction force on a uniformly
accelerated charge must be nonzero -- after all, the charge is sending
electromagnetic waves off to infinity, and the energy's got to come
from somewhere! But I claim it's not the least bit obvious.
Start with a charge at rest in the lab, gently nudge it into
accelerated motion, let it uniformly accelerate for a while, and then
gently reduce the acceleration to zero, leaving it in uniform motion
relative to the lab. Lorentz-Dirac theory says that there's a
radiation reaction force only during the two "nudges" at the beginning
and the end -- during the uniform acceleration, the total force
required is the same as it would be for an uncharged particle of the
same mass. And if you calculate the work done by the external force
during the whole time, it works out right: The work equals the final
energy (mc^2 + KE of the charge + radiated energy) minus the initial
energy (just mc^2).
Granted, Lorentz-Dirac theory is sick, but this is the sort of
situation in which it's expected to be approximately correct
(acceleration for only a finite period, all nudges smooth and gentle).
Anyway, it's an existence proof that you can conserve energy even if
the reaction force is zero during periods of uniform acceleration.
Tom Roberts Nov4-06 03:26 PM
> field.
I agree. Here's a simple gedanken that I think shows that no local
experiment can do so, given the equivalence principle:
Consider a small rocket with a bare charge suspended inside, and an
observer who can measure the EM field at rest with respect to the
rocket, anywhere within it; all other sources of the EM field are
negligible. With the rocket far from any massive objects and thrusting
with constant proper acceleration, at any given position within the
rocket the EM field will be constant in time[#], so this observer cannot
possibly _measure_ any radiation[@]. With the rocket at rest on a
(large) massive planet, the equivalence principle implies the same
result. So for both cases this observer must necessarily conclude there
is no radiation[@], and therefore no radiation reaction and no
observable difference between the two cases.
[#] Consider the instantaneously-comoving inertial frame
(ICIF) of the observer. In this frame the EM field is due
to the retarded position of the charge, so the charge is
slightly offset in position and has a small velocity relative
to the observer in this ICIF. At any time this relationship
remains the same (even though the ICIF is different) because
the _proper_ acceleration is constant. Since the observer
always measures the field in the then-current ICIF, the
observer measures the field to be constant in time (even
though it is not purely Coulomb).
[@] Note that ExB is nonzero, but the absence of any time
variation in either E or B implies no radiation. The
corresponding transport of energy and momentum is of
course constant in time and is offset by the mechanism
suspending the charge.
Note this depends on the rocket being small, and the acceleration being
uniform.
As I have remarked elsewhere, "radiation" can be a rather slippery
concept; but the time variation of the EM field (or lack thereof) is
definitive, and in this case gives a clear conclusion. I believe the
above reference's error is in not basing the conclusion on
_measurements_ made locally.
Tom Roberts tjroberts@lucent.com
ebunn@lfa221051.richmond.edu Nov4-06 03:26 PM
In article <1139856844.342067.266560@g44g2000cwa.googlegroups.com>,
Igor Khavkine <igor.kh@gmail.com> wrote:
>Actually, the study of the motion of a point particle coupled to a
>classical field has recently been a fairly active research topic. For
>example, there is a review article by Eric Poisson published in Living
>Reviews in Relativity:
>The Motion of Point Particles in Curved Spacetime
>by Eric Poisson
>http://relativity.livingreviews.org/...es/lrr-2004-6/
>And it seems that, with a slight modification, the Lorentz-Dirac
>equation is no longer pathological. The modification is described in
>An introduction to the Lorentz-Dirac equation
>by Eric Poisson
>http://arxiv.org/abs/gr-qc/9912045
Thanks for this information! I've been going around for years telling
people that there is no satisfactory classical theory of point charges,
but this makes it look like I was wrong.
I seem to remember reading about the order-reduction trick Poisson
describes and thinking that it wasn't a satisfactory way to remove the
pathology in the Lorentz-Dirac equation for some reason. But I can't
see what that reason might be at the moment -- it looks convincing to
me.
Given this information, I'll now strengthen my claim that Parrott is
wrong in his about charged particles and the equivalence principle. I
used to tell anyone who'd listen that he hasn't adequately shown that
the reaction force on a uniformly accelerating charge is nonzero.
Instead, I'll now say that, in the only sensible theory to apply in
this situation, the force is definitely zero.
>These are fairly recent developments. I wonder when they'll make it
>into a newer edition of Jackson or some texbook on electrodynamics.
Actually, Jackson does give the order-reduced version of the
Lorentz-Dirac equation, although without a particularly careful or
rigorous derivation like Poisson's. The nonrelativistic limit is in
the main text, and the full equation is in the problems. I suspect it
wasn't there in the edition I used in grad school (the one with the
reddish cover), or else I think I'd probably have known about it. I
could be wrong, though.
-Ted
[Spam?] Re: Radiation's equivalence principle
In article <HPbHf.54823$PL5.41279@newssvr11.news.prodigy.com>,
This is a correct argument showing that the equivalence principle
implies no radiation reaction. The point of Parrott's paper is to
question whether the equivalence principle is valid in this situation.
In other words, he agrees with your argument, up to the last step. He
then combines it with the assumption that the radiation reaction force
is nonzero, and concludes that the equivalence principle doesn't
apply. In other words, to use a word I may not have used since
high-school geometry, he does the contrapositive of what you do (not-Q
==> not-P instead of P ==> Q).
Personally, I'm with you. I just want to make sure Parrott's
argument gets a fair shake.
-Ted
Neil Nov4-06 03:26 PM
<ebunn@lfa221051.richmond.edu> wrote in message
news:dsig3n$jv$1@bigbang.richmond.edu...
> BUT
The issue of radiation from a *uniformly* accelerating charge is clearly
problematical, considering disagreements and the rather casual throwing
around of claims that the EP may just not work for charges (er, wouldn't
that mean complete revision of GR and replacement with...what?) However,
I ask an even more challenging question: what if we had an oscillating
charged body (not necessarily a "particle," but perhaps an insulated
object) undergoing natural SHM inside a diameter tunnel through the
earth. This body is in free fall, and "feels" like it is floating in
space. There are tidal fields, but they are symmetrical per up-down
distinctions. The charge must radiate in some external sense, because
the local existence of changing EM fields (say, on the earth's surface)
must propagate to distant locations. That implies energy transport to
those distant locations. However, there is no reasonable basis for such
a charge to feel the reactive self-force: F_rad =
(2/3)k(q^2)(da/dt)/c^3. An accelerometer attached to the charge measures
no acceleration, nor change in acceleration. Furthermore, because the
actual coordinate value da/dt = -(4/3)G(rho)(dr/dt), any effect
involving say tidal fields must be velocity sensitive! Hence, either:
(1.) The charge behaves as expected in terms of simple application of
the EP. It radiates but is not impeded by a self force. Thus it radiates
energy for free.
(2.) The charge is subject to the self-force that would apply in a
non-gravitating system (i.e., as if it were in an antenna free of
gravitational fields.) Energy is conserved, but we must (?) adjust GR to
violate (?) the EP and explain how the charge can "sense" its actual
coordinate acceleration changes.
I wouldn't know which will apply, although I expect (1.) to be
considered distasteful to many. Option (2.) if true may have some
application to peculiar recent observations and commentary on charged
particles near or falling into black holes (sadly I can't find the
reference/s - can you?) It has odd consequences, such as a breaking
force on charges moving at high speed through the matter of the universe
(from equivalence to free-fall inside a planet) and acceleration of
fast-moving charges approaching the earth etc. - and aren't we wondering
about how some charged particles hitting our atmosphere can have so much
kinetic energy?
markwh04@yahoo.com Nov4-06 03:27 PM
Actually, it *follows* from the Equivalence Principle. The
"accelerating" in "accelerating charge", in all cases, is that taken
with respect to a free fall frame since the Equivalence Principle
states that free fall is to be taken as the curved spacetime analogue
of inertial motion.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
