Orbital Radii of planets and moons of jupiter
The discussion revolves around developing models for the four innermost planets and the four Galilean moons of Jupiter by adjusting their orbital radii. Participants are tasked with reducing these radii to create a comparative model, exploring potential reasons for similarities and differences in the resulting models.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss plotting data points to find a best fit line, with some suggesting that the relationship may be exponential. Questions arise regarding the interpretation of "innermost" planets and the method of reducing orbital radii. There is also inquiry about alternative methods to graphical approaches, such as using logarithmic transformations and least squares methods.
Some participants have provided guidance on interpreting the problem and suggested methods for finding equations relating the variables. There is ongoing exploration of the least squares method and its application to the data, with varying levels of understanding and confidence among participants.
Participants express confusion over the inclusion of an asteroid in the data and the clarity of the provided tables. There is mention of the historical context of the problem relating to Bode's law, which some participants question in terms of its theoretical basis.
L²Cc
Finally, develop models for only the four innermost planets and the four Galilean moons by reducing all the orbital radii by a factor that makes the orbital radius of the first planet or moon equal to one. Give possible reasons for the similarities and/or differences in two models.
x = position of planets relative to sun
y = orbital radii
Mercury Venus Earth Mars Asteriod Jupiter Saturn Uranus Neptune Pluto
x 1 2 3 4 5 6 7 8 9 10
y 57.9 108.2 149.6 227.9 T 778.3 1249 2871 4504 5914
x = position of galilean moons relative to jupiter
y = orbital radii
Lo Europa Ganymede Callisto
X 5 6 7 8
Y 422 670.9 1070 1883
This math portfolio asks us to find an equation relating x and y. I find this by plotting the points, and the best fit line. The equation is exponential. I solve for T (the orbital raidus of asteriod), T = 469 millions of kilometers.
For this last question, I don't understand what they mean by the four "innermost" planets...And finding a factor (a common factor?)...
The model for case A is: 1.19x^3.71
The model for case B is: 1.18^3.54
Also, is there another way, other than the graphical method, to find the equation relating x and y??
y = orbital radii
y = orbital radii
X 5 6 7 8
WHY solve for "the orbital radius of asteroid" (and which asteroid?)? There was no mention of asteroids here. (Nor is there a "T".)
The four "innermost" planets are Mercury, Venus, Earth, and Mars- that is what is meant by "position of planets relative to sun".
You are asked to "reduce all the orbital radii by a factor that makes the orbital radius of the first planet or moon equal to one". "Reduce by a factor" means to divide them all by the same thing. You are told that the distance from the sun to Mercury (the first planet) is 57.9 (milliion meters?). What do you need to divide by to make that equal to 1? Now divide the next 3 by that same thing.
Do you mean y= 1.19x3.71? If so, note that, in y= Axb, log y= b log x+ log A, a linear equation. You could use a "least squares method" to find b and log A so that gives as good a line as possible through the (log x, log y) positions and then find your equation. I'm not sure what you mean by "the graphical method".
Thank you hallsofivy. I have one question, though. (Refering to your method)Do I use values from the given data to find the best fit line? For example,
log422 = b logx + logA. Then ?
I do mention T (asteroid) in the table above. When I copy pasted the table off word, the grids disappeared, thus making it hard to follow. It's in sequential order...you just have to correspond the first x value to the y value in the second row...sorry for the misunderstanding.
Yes, that would be the best way to do this.
You are right- I didn't see the third set of data.
I have been researching your 'least squares methods" but I'm still struggling to apply it to my set of data! Help highly appreciated! Thank you!
You should consider doing your IB Type II Assessment on your own.
I wish to clarify a few things: I did do my Type II assessment on my own. Additionally, HallsOfIvy simply verified my work. S/he didn't, in any way, give away answers. And just for the record, I did not determine the equation algebraically until the day before yesterday when I came upon a method to do so as I was researching for a chemistry-related topic.
Thank you, however, for your concern.
The least squares method is basically finding the line of best fit (the square of the errors form the smaller number, therefore least squares). If you have a TI graphing calculator, you do linear regression.
You can do what hallsofivy did and enter in the data using logs and still use linear regression. What you do to find y at the end is raise the other side to a power of the base.
However, that's the long way to get the equation. The simpler way is simply find exponential regression using the calculator.
By the way, I thought this assessment was completely pointless. Aren't we trying to find a relationship that doesn't exist?
What is this 'Assessment'? I think the historical background for this problem is testing Bode's law. For which I don't think there is any theoretical basis, but was at one time taken very seriously.
9K
  • · Replies 30 ·
