Contour Integral: Analyzing Complexities & Singularities
The discussion revolves around a contour integral involving complex variables, specifically analyzing singularities and the behavior of the integrand. The integral includes factors such as \(\rho^4\), \(\sin^3(\theta)\), and an exponential term, raising questions about the implications of these components on the singularities and the overall evaluation of the integral.
  • Participants explore the location of singularities, questioning whether they are influenced by the \(\rho^4\) factor. There are attempts to simplify the integral by considering the impact of odd and even terms in \(\rho\) on the contour integration process. Some participants express confusion regarding the cancellation of terms and the evaluation of the integral.
The discussion is ongoing, with participants sharing various insights and approaches. Some suggest that odd terms may complicate the contour integration, while others believe that careful evaluation of the angular integration could clarify the situation. There is no explicit consensus, but multiple interpretations and methods are being explored.
Participants note the potential for confusion regarding the limits of integration and the nature of the variables involved, particularly whether they are dealing with polar coordinates or real values. There are also references to computational tools like Mathematica and Maple, which have yielded similar results, adding to the complexity of the discussion.
MadMax
[tex]\int \frac{\rho^4 \sin^3{\theta} d \rho d \theta e^{i \rho r \cos{\theta}}}{(2 \pi)^2 [K^2 + \rho^2]}[/tex]
I am confused about where the singularities are in this function. Will they simply be at \rho = iK and -ik or does the \rho^4 factor make a difference?
Also the sin^3(\theta) e^(i \rho cos (\theta)) when evaluated on mathematica for example brings in some terms with three different powers of \rho some of which I am afraid will make the function odd in \rho in which case I would struggle with the final contour integration...
Any help suggestions would be much appreciated.
Thanks.
OK well I just did a test to see if perhaps the factor of \rho^4 makes a difference by dividing the denominator by that factor... it seems that in that case there are no singularities... which can't be right since the integral is supposed to have a finite answer... and a contour integral with no singularities = 0 right? -> confused.
If I just assume the factor of \rho^4 on the numerator makes no difference, and that the singularities are at -ik and ik, then we still have something that maple says will have terms that aren't even functions in \rho, which I wouldn't know how to deal with when it comes to contour integration.
hmm for now I am going to do the theta integral and worry about symmetry and singularities later.
Good idea! I think you'll find that the parts that are odd in rho will cancel after the theta integration.
We find
[tex]\int \frac{d \rho}{(2 \pi)^2} \frac{e^{-ir \rho}-e^{ir \rho}}{K^2 +\rho^2} \frac{\rho}{ir} \left [ \rho^2 - \frac{2 \rho}{ir} + \frac{1}{r^2} \right ][/tex]
if we leave it like this we find that there are odd terms which I don't know how to handle...
the only thing I can think of doing is to factor in the rho's into the possibly singular denominator...
we then find
[tex]\int \frac{\rho d \rho^2}{(2 \pi)^2} \frac{e^{-ir \rho}-e^{ir \rho}}{ri} \left [ \frac{1}{iK^2 / \rho^2 + 1} + \frac{2}{ir[K^2 / \rho + \rho]} + \frac{1}{r^2[K^2 + \rho^2]} \right ][/tex]
Now I'll try and figure out which of these terms exhibit singularities, cancel the ones that don't, and hope I'm doing the right thing...
MadMax said:
We find
we then find
Why are the odd terms a problem? One can still simply do the contour integration nevertheless, no?
I will simply use the first form you quoted and write 1/(k^2 + rho)^2 as
[tex]\frac{1}{(\rho + i K)(\rho -iK)}[/tex] and then you do the integrals over the two exponentials separately, picking up the contour that has a semicircle contribution vanishing at infinity (for example, for [itex]e^{-i r \rho}[/itex] you must close the contour below the real axis in order to pick the pole at -i K).
Patrick
The problem he would have with the odd terms is that the first step to the contour integration is to extend it from the positive real axis to the whole real axis. With the even terms it's easy. Just do it and add a factor of 1/2. What to do with odd (since the extension will necessarily vanish, but not necessarily the original)? Fortunately, if he does the angular integration more carefully (it's not right as stated), he'll find that even power terms in rho are associated with a cos(r*rho) and the odd ones with a sin(r*rho) - so the extension is no problem.
Ah ok. The limits of integration were not given and I had assumed that rho was integrated over the real axis but now I realize that those coordinates meant polar coordinates. Thanks for the clarification.
Mathematica gives pretty much the same answer I got (apart from a few factors of 2). There is one odd term with a factor cos(theta), and since the limits of the integration are between theta = 0 to theta = pi, it won't dissapear... I'm really confused and stumped.
How did you calculate the integral dick? I did it using substitution, the identity cos^2 a + sin^2 a = 1 and then integration by parts twice.
The answer I'm looking for is
[tex]\frac{K^2}{2 \pi} \frac{e^{-Kr}}{r} \left [ \frac{3}{Kr} + \frac{3}{K^2 r^2} \right ][/tex]
Thanks.
Well, buddy, I just can't agree with you and Mathematica there. The cos(theta) terms should give rise to terms like exp(i*rho*r)+/-exp(-i*rho*r). These are cos(rho*r) and sin(rho*r) respectively, giving me terms containing cos(rho*r)/r^2 and sin(rho*r)/r^3. Both of which are even. So the right answer is out there somewhere! It's not hopeless!
This is what I 'm going to do. I'm going to go through the integral again, meticulously, on paper. Then transcribe into this thread. Let's see if, and if so where, I went wrong.
Fine idea. If you are REALLY meticulous, you'll probably catch all of your own errors and won't need to transcribe it. That would be pleasant.
OK, still pretty much the same answer...
[tex]G = \int \frac{\rho^4 \sin^3{\theta} d \rho d \theta}{(2 \pi)^2} \frac{e^{i \rho r \cos \theta}}{K^2 + \rho^2}[/tex]
[tex]= \int D sin^3{\theta} d \rho d \theta e^{a \cos \theta}[/tex]
where
[tex]D= \frac{\rho^4}{(2 \pi)^2} \frac{1}{K^2 + \rho^2}[/tex]
and
[tex]a=i \rho r[/tex]
if u = cos(theta), du/dtheta = -sin(theta), so that dtheta=-du/sin(theta),
[tex]G = -\int D sin^2{\theta} d \rho du e^{a u}[/tex]
since cos^2(b) + sin^2(b) = 1
[tex]G = \int D (u^2 - 1) d \rho du e^{a u}[/tex]
using integration by parts
[tex]G = \int D \left[ \left ( \frac{u^2 e^{au}}{a} -2 \int \frac{u e^{au}}{a} du \right ) - \frac{e^{au}}{a} \right ] d \rho[/tex]
[tex]= \int D \left[ \left ( \frac{u^2 e^{au}}{a} -\frac{2}{a} \left( \frac{u e^{au}}{a} - \int \frac{e^{au}}{a} du \right ) \right ) - \frac{e^{au}}{a} \right ] d \rho[/tex]
[tex]= \int D \left[ \frac{u^2 e^{au}}{a} -\frac{2 u e^{au}}{a^2} + \frac{2 e^{au}}{a^3} - \frac{e^{au}}{a}\right ] d \rho[/tex]
Considering Dick's next post I'll cut it there for now.
Whoa, stop, stop! You are going backwards! Just evaluate the above expression between u=-1 and u=1. Notice that in this expression the 1/a terms drop out at both limits!
Here is your mistake. You've factored the problem as A(u)*B(u). Then to evaluate between u=-1 and u=1, you are computing (A(-1)-A(1))*(B(-1)-B(1)). The correct answer is A(-1)*B(-1)-A(1)*B(1). Which is NOT THE SAME THING!
Yes I was making a mistake putting in the limits. Thanks.
OK so now we have
[tex]= \int D \left[ \frac{2 e^{-a}}{a^2} +\frac{2 e^{-a}}{a^3} + \frac{2 e^{a}}{a^2} - \frac{2 e^{a}}{a^3}\right ] d \rho[/tex]
but since D is even in rho and the exponential is odd in rho, the terms with a factor of 1/a^2 (which is even in rho) will be odd in rho, (with the terms having a factor of 1/a^3 being even in rho).
Beg to differ. The a^2 term looks like (exp(a)+exp(-a))/a^2. I call that EVEN in rho. And (exp(a)-exp(-a))/a^3 is also even. Flip a to -a and see what happens... Exponentials are NOT ODD.
nevermind...
woo! I think i just understood what you meant. I was just too dense to see. if we convert the exponentials into sin and cos we are sorted! thanks a million dick, should be fine now :)
Good. Once you're ok with the extension to the whole real line, you'll have to break them up again into + and - imaginary parts to get the correct contours, right?
