How Does EM Wave Penetrate in an Elevator/Lift?
  • Context: Undergrad
  • Thread starter Thread starter serverxeon
    Em Em wave Wave
The discussion revolves around the behavior of electromagnetic (EM) waves, specifically radio signals, in the context of elevators (lifts). Participants explore why mobile phones tend to have better reception compared to FM radio in such environments, examining factors like signal encoding, frequency, and the physical properties of elevator cabins.
  • Some participants suggest that mobile phones have better reception in elevators due to digital encoding, which allows for error correction, unlike analog FM radio.
  • Others argue that the frequency of operation plays a significant role, noting that mobile phones operate at higher frequencies (e.g., 900MHz to 1900MHz) compared to FM radio (88MHz to 108MHz).
  • One participant mentions that elevators can act as Faraday cages, which could theoretically block signals, but they are not perfect due to gaps between metal sheets.
  • Another point raised is that the strength of the signal from mobile phone towers may be greater than that from FM broadcasting towers, affecting reception quality.
  • Some participants discuss the skin effect, suggesting that higher frequency EM radiation penetrates materials differently, which may impact signal reception in elevators.
  • There is mention of the geometry of the elevator and the potential for differences in electric potential between metal sheets affecting signal behavior.
Participants express differing views on the reasons for the disparity in signal reception between mobile phones and FM radios in elevators. There is no consensus on a single explanation, and multiple competing perspectives are presented throughout the discussion.
Participants highlight various factors influencing signal reception, including the physical structure of elevators, the nature of digital versus analog signals, and the impact of frequency on penetration through materials. These aspects remain unresolved and are subject to further exploration.
serverxeon
Hi,
I'm rather new here.
I've got a question that's bothering me, and therefore decided to ask here.
Why is it that in a lift/elevator, radio signal usually gets weakened?
And, as far as i know, FM radio operates on the radio wave band, as well as cell phones. But why is it that mobile phones generally have acceptable reception in lifts/elevator whereas FM radio reception remains poor? Don't they operate at the same wavelength/freq?
Has this something to do with the energy level stated by E=hf, or something?
It has nothing to do with E=hf.
Maybe that the reason why cell phones are more tolerant that FM radio is that in the cell phones the signal is digitally coded. And as you know digital communication works well, even is the signal is degraded, until it is so degraded that it stops working. The situation is the same with others digital communications as digital TV (broadcast). When analog reception is poor digital TV is still excellent. A similar case is with vinyl records and CDs: even new vinyl's where noisy and old CDs are not.
I believe that high frequency EM radiation penetrates much deeper into matter because it is much more energetic (E=hf). Wouldn't that explain why cell phones work better than FM radios? FM radios are operated at ~80-100 Mhz whereas cell phones are operated at ~1800 Mhz.
AM Radio waves have longer wavelengths (on the order of meters) than FM Radio wavelengths. This is the reason why when you pass under a bridge while driving and your radio is tuned on the AM dial the signal gets cut off while on the FM dial it doesn't. (AM waves can't penetrate through the bridge).
Cabins of lifts/elevators are usually metallic.
The penetration in metals is less for higher frequencies than for lower ones. It is called skin effect. See:
http://en.wikipedia.org/wiki/Skin_effect
This is a somewhat different problem. Bridges and tunnels behave as (bad) waveguides. The maximum wavelength that can penetrate a waveguide is twice the width of the waveguide/bridge/tunnel.
Have you considered that the signal from a mobile phone tower may simply be stronger to begin with than an FM broadcasting tower potentially tens of km away? (Also, I don't really agree with you anecdotal evidence, my phone loses signal in lifts with frustrating regularity :rolleyes: ).
Claude.
First of all as Claude Bile has said.
1. Mobile phones use digital encoding. FM radio = analog. Digital encoding allows for signal error checking, error correction, and pretty much "perfect" transmission as long as there is enough bandwidth.
2. No, mobile phones DO NOT operate on the same frequencies as FM or AM radio. FM radio goes from 88MHz to 108 MHz. There are three GSM bands I know of that are in common use: 900MHz, 1800MHz, and 1900MHz. Not close at all.
3. An elevator acts as a Faraday cage, because an elevator is pretty much a cage of metal, which fits the bill for being an electromagnetic shield. If it were a perfect shield, you would get absolutely no signal in the elevator as there is theoretically no electromagnetic field inside.
The last say as to whether a particular frequency band is better than another depends on too many factors: the operating reception range, the presence of materials that absorb certain EM frequencies, the geometry of the landscape, and particularly in digital signals the type of modulation used.
P.S. I usually don't have problems with my phone on the lifts I use ;D
D
An elevator acts as a very poor Faraday cage. It has all that is needed to be a Faraday cage: inside you are surrounded by metal sheets. In a lift, the sheets are not welded together and do not form an equipotential surface. There are isolating "slots" between sheets. Even if in DC or low frequency two neighbor sheets are connected, this is not true in high frequency.
EM field induces differences of potential in the sheets. Even between connected sheets there can be differences of potential if the connection point is at a distance comparable to wavelength.
Two sheets with a difference of potential act as an antenna in the inside of the cabin, and re-emit the signal received on the other side.
As wavelengths used in cellular phones are shorter than those used in FM, the lift cabin behaves as a worse Faraday cage for cellular phones than for FM receivers.
Of course a lot of things depend on the power of the emitters. But you should not forget that the emitter whose power is very limited is that of the cellular phone itself and which must reach the receiver of the cell.
Maybe it's time for me to buy a new phone then :wink: .
Claude
  • · Replies 19 ·
12K
  • · Replies 20 ·
  • · Replies 33 ·
