How to calculate confidence limits in bernoulli trials with only one outcome.
  • Context: Undergrad
  • Thread starter Thread starter azira
    Bernoulli Limits
This discussion focuses on calculating confidence limits for Bernoulli trials with a single outcome, specifically when only "OK" results are observed. The user seeks to determine a 95% confidence interval for the probability of "OK" (p) after running the process multiple times, resulting in a challenge due to a standard deviation of zero. The conversation highlights the inadequacy of traditional t-distribution methods in this scenario and introduces the adjusted Wald method and the LaPlace method as viable alternatives for calculating confidence intervals under these conditions.
  • Understanding of Bernoulli trials and binary outcomes
  • Familiarity with confidence interval calculations
  • Knowledge of the adjusted Wald method for confidence intervals
  • Basic statistics concepts, including standard deviation and t-distribution
  • Research the adjusted Wald method for calculating confidence intervals in Bernoulli trials
  • Explore the LaPlace method and its application in statistical analysis
  • Learn about alternative methods for confidence interval estimation when facing zero variance
  • Study the implications of using different distributions for confidence interval calculations
Statisticians, data analysts, and researchers involved in probability theory and statistical inference, particularly those working with binary outcome data and confidence interval estimation.
azira
I have this problem that I have been trying to figure out all week and can't seem to get.
I have a process that produces one of two outcomes "OK" (in some unknown porportion: p) or "NOT OK" (in porportion q = 1-p). Let's say I ran the process [x] times (like 20) in a row and it reported "OK" each time. How can I calculated a 1-sided (or 2-sided) 95% confidence interval for the value of p?
I think I should be assigning a value of "1" to "OK" and "0" to "NOT OK" and then applying the conventional confidence interval calculations using the t-distribution. The problem I run into is that all I observe are "OK" then my std deviation goes to 0 and the whole thing falls apart.
Is there another method? What am I missing?
Thanks, much appreciated.
After more searching on this forum, I found a reference to something called the adjusted/modified wald method and the LaPlace method. It seems like those are good candidates to apply to this problem.
  • · Replies 22 ·
