How Does the Peak Radiative Flux from Planck's Law Vary with Temperature?
The discussion focuses on demonstrating that the peak radiative flux from Planck's law varies as the fourth power of temperature. The formula for Planck's law is given as F(w) = C1/[w^5(exp(C2/wT)-1]. To find the peak radiative flux, one must take the derivative of this formula with respect to wavelength and set it to zero, leading to a relationship that confirms the fourth power dependency on temperature. Integration is not necessary for this derivation, as the peak can be determined through differentiation and substitution into the original formula.
  • Understanding of Planck's law of radiation
  • Knowledge of calculus, specifically differentiation
  • Familiarity with blackbody radiation concepts
  • Basic grasp of thermodynamic principles
  • Study the derivation of Planck's law and its implications for blackbody radiation
  • Learn about the Stefan-Boltzmann law and its relationship to temperature
  • Explore the concept of Wien's displacement law for peak wavelength determination
  • Investigate numerical methods for integrating functions related to Planck's law
Physicists, engineers, and students studying thermodynamics or radiation physics who seek to understand the relationship between temperature and radiative flux in blackbody radiation.
Callisto
Planck's law of radiation??
Hi, can anybody help me with this problem?
Planck's law of radiation for a blackbody radiator quantifies the relation between it's radiative flux and wavelength at a particular temperature.
given by:
F(w)=C1/[w^5(exp(C2/wT)-1]
where, w=wavelength, C1 and C2 are constants and T is the absolute temperature.
My problem is , I have to show that the peak radiative flux of the Planck spectrum varies as the fourth power of temperature.
Do i need to do some integration of Plancks law to show this?
If so, where do i start? :confused:
I think you mean the "total radiative flux," not the "peak radiative flux."
If so, simply integrate your formula over all values of wavelength.
Here's a page that might help:
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/stefan2.html#c1
- Warren
Hi there,
To show that the peak radiative flux varies as the fourth power of temperature, you do not need to perform any integration of Planck's law. You can simply use the fact that the peak of the Planck spectrum occurs at the wavelength where the derivative of Planck's law with respect to wavelength is equal to zero.
To find this wavelength, we can take the derivative of Planck's law with respect to wavelength and set it equal to zero:
dF/dw = (-5C1C2/w^6) * (exp(C2/wT)-1) + (C1C2T/w^7) * (exp(C2/wT)) = 0
Simplifying this expression, we get:
5exp(C2/wT) - 5 = C2T/w
We can then rearrange this equation to solve for the wavelength at the peak of the spectrum:
w = C2T / [5ln(5) - 5ln(exp(C2/wT))]
Now, we can substitute this value of wavelength into Planck's law to find the peak radiative flux:
Fpeak = C1/[w^5(exp(C2/wT)-1)] = C1/[C2^5T^5 / (5ln(5) - 5ln(exp(C2/wT)))^5 * (exp(C2/wT)-1)]
Fpeak = (C1C2^5T^4) / [(5ln(5)-5ln(exp(C2/wT)))^5 * (exp(C2/wT)-1)]
We can see that the peak radiative flux is directly proportional to the fourth power of temperature, as required. Therefore, we have shown that the peak radiative flux of the Planck spectrum varies as the fourth power of temperature without needing to perform any integration. I hope this helps!
  • · Replies 20 ·
15K
  • · Replies 23 ·
13K
