Solving the Mystery of the Factory's Antenna Array
The discussion revolves around the capabilities and range of a factory's antenna array, specifically focusing on 802.11b antennas. Participants explore the potential transmission distance, the technology used, and methods to assess signal strength.
  • One participant notes the factory has a large array of antennas and wonders about their transmission range, speculating that they might be using 802.11b due to its larger range.
  • Another participant suggests that the transmission range could vary significantly based on transmitter strength and environmental factors, indicating uncertainty about the actual distance.
  • A different viewpoint proposes using an 802.11b receiver card to measure signal strength directly, though this raises questions about distinguishing the source of the signal.
  • One participant mentions that the observed signal strength from the factory is greater than expected for typical consumer equipment, suggesting the use of amplifiers or professional radio equipment.
  • There is a discussion about the capabilities of Wi-Fi transceivers, particularly regarding frequency changes and the ability to monitor multiple networks.
Participants express varying opinions on the transmission capabilities of the antennas, with no consensus on the exact range or technology used. The discussion remains unresolved regarding the specifics of the factory's setup and the implications for signal strength.
Participants acknowledge limitations in their understanding, such as the dependence on transmitter strength, environmental factors, and the potential for interference from other networks.
screwball
OK here is what I am trying to figure out
there is a large factory by my house which towers about 4 stories above the surrounding community. on the roof there is an array of 802.11b anttenas (im assuming its B and not A cause B has larger range) there are 10 large anttenas, 5 on one side of the building and 5 on the other all arranged near the corner of the building. they are all pointed in the same direction. I am wondering how far could this possibly be transmitting?
Computer science news on Phys.org
Hard to say just knowing they have a few antennas on the roof. They might be capable of going several miles, or they could have trouble going 40 feet. It depends on their transmitter strength and what materials (and topology) they are trying to transmit through.
The only way to know for sure is to either (1) call them on the phone and ask them, or (2) walk over to the building, go in and ask them. Ask for the Manager or Director of Information Technology.
Or if you have an 802.11b receiver card, you could walk around and find out for yourself -- most come with a utility to monitor signal strength, even if you can't log onto their network.
well it reaches me and I am like a couple hundred feet away
i was just wondering what the max was on the access points that computer companies sell
cause it seems like its more than there capable of
i think there useing amps and what not, actual radio equip not just the regular junk they sell at compusa.
seems like they have more than your average buisness's wireless network. makes me courious that's all
But then you run into the question, is this signal from that big building or from your next door neighbor? I guess if you move around enough you might be able to find out. Do many wifi transceivers allow you to change the frequency they use or are they hard-coded?
^^^ My 'site survey' utility lists the SSID (network name), channel #, and signal strength of all the networks around. So I can see both my network and my neighbor's... and incidentally see he/she was too dumb to bother encrypting or MAC-filtering it.
yeh that's usually the way it goes lol
Heeheehee...
So you get to see all your neighbor's porn 'eh? :wink:
  • · Replies 35 ·
  • · Replies 16 ·
12K
12K
  • · Replies 17 ·
