What is Time? | General Physics Discussion
  • Context: High School
  • Thread starter Thread starter kateman
    Time
The discussion revolves around the nature of time, exploring its existence, measurement, and implications in both physics and philosophy. Participants examine various perspectives on time, including its relationship with space, gravity, and consciousness, as well as the possibility of time travel.
  • Philosophical
  • Some participants question whether time truly exists or is merely a measurement created for convenience in formulas.
  • Others suggest that time is fundamentally linked to change and our perception of it, raising the issue of whether time travel is feasible.
  • One participant proposes that time is a function of observation, influenced by mass and velocity, and is not a simple variable.
  • There is a discussion about the relationship between time and gravitational fields, with some asserting that time runs slower in stronger gravitational fields.
  • Participants differentiate between "coordinate time" and "proper time," suggesting that the ambiguity in the term "time" complicates the discussion.
  • Philosophical perspectives are introduced, positing that time may be an illusion of consciousness, while scientific views focus on measurable aspects of time.
  • One participant mentions the historical evolution of the concept of time from Newton's constant time to Einstein's relativistic view, which introduces complexities such as time travel.
Participants express a range of views on the nature of time, with no consensus reached. Some agree on the complexity of defining time, while others maintain differing opinions on its existence and implications.
The discussion highlights the limitations in measuring time accurately and the unresolved nature of its definition, which varies between philosophical and scientific contexts.
This discussion may be of interest to those exploring the philosophical implications of time, as well as individuals seeking to understand the scientific complexities surrounding the concept of time in physics.
kateman
first off, sorry if this is in the wrong place. iam not sure exactly were this topic should be put so i posted it in general physics
anyway, i was interested to know what time is. i mean its used in formulas i know, so obviously its something, but does it really exist.
i was originally thinking that was just some measurement that we pulled out of our hats because the formula's are wrong without it. but then i think about how its possible to go back in time, which makes me think that there has to be something more to it than just some made up measurement.
i would appreciate all your thoughts on time in general :)
I liked your train of thought better before you assumed time-travel was possible.
We can't really know that traveling backwards in time is impossible until we know what time is.
well more assuming its probable, but not for living beings. more or less for particles instead.
i don't mind opinions but what do we actually know about time?
Well...
It relates to space, velocity and mass in a meaningfull way.
Time is not like a switch, that you can turn on or off, or a variable you can zero out. Think of it this way, if an object has mass and any velocity relative to any other arbitrary object (including an external observer) then time is a function of the observation.
Just like a Scottie dog you measure the length of while he/she/it is taking it's leisure at a local fire hydrant gives you a number the same puppy doing the same thing at the same "time" if measured from orbit the puppy is just about a doggy hair shorter not due to a rounding error, but by nature of the fact that in orbit the measurer is moving at several thousand miles per hour and there is a tiny, but predictable, difference.
Read "einstein's Dreams" and see if you can pick which dream reflects the real world.
cheers
Is it safe to say that time is the speed of light which varies depending on the strength of the gravitational field in GR?
Thats what confuses me. Time is said to run slower near strong gravtational fields. Light redshifts to adjust distance vrs. time changes to keep c constant and as a result clocks in different places run at different rates. Are you saying that the speed of light does not slow when it is redshifted, but the atomic clock does slow.
Im pretty sure that's a yeah. C is constant.
The speed of light is always equal to 'c' if you use local clocks and local rulers.
While the modern approach to GR always uses local clocks and rulers to measure speeds, sometimes you'll see people doing things differently, especially if they aren't doing GR, but something more down-to-earth.
There are at least two different basic sorts of time, but people don't always carefully distinguish between the two sorts. One sort of time is "coordinate time". The other sort of time is "proper time", which is the sort of time a clock measures. So when one asks "what is time", one could mean several things, because the term is used ambiguously. In addition there can be several different coordinate systems used, there are several sorts of coordinate time possible. (Example: TCB vs TCG - this gets technical quicly, but if you are interested in the details, see for example http://aa.usno.navy.mil/publications/docs/Circular_179.pdf).
"Gravitational time dilation", which depends on gravitational potential rather than the gravitational field, really describes the relationship between a certain type of coordinate time, and proper time.
kateman said:
...i was interested to know what time is. ... but then i think about how its possible to go back in time, which makes me think that there has to be something more to it than just some made up measurement.
The concept of time comes from our awareness of change. It is most obvious that objects around us are in flux, and our inherent sense of this is necessary for interacting with the world. We have refined our notion of time by finding (or fabricating) objects that undergo cyclical change, and we measure the passage of time by counting cycles. We measure time by measuring change.
From this it is clear that traveling "forward" in time is no problem, because our concept of change (cause --> effect) is a forward progression. But traveling backwards is problematic: What does changing backwards mean if all change is forward by definition?
Next we invent Thermodynamics.
I'd like to learn more about the culture of time in the manner this post was establishing.
I would say time could be defined as a series of irreversible processes, all of which as more similar to the others as possible.
To grasp a little bit more on what we know, so far, about time you must first establish which time you are talking about. There are two main views that seem to try to explain time; the philosophical that says that time is nothing more than an illusion of consciousness, and the scientific that says that time is measurable. All other descriptions tend to branch from these two ideas.
This forum isn't designed for the philosophical so I won't speak much about it but to sum it up they say that time is an illusion of motion, progression, cause and effect, etc. Everbody has differing reasons for why it's an illusion, but agree that it's an illusion of some sort. Basically time from this perspective boils down to nothing more than being the conscious observation of the relationship between two or more objects in repititious motion: ie the Earth around the sun = a year.
The scientific approach is more detailed and complicated but still does not give a concrete theory of time. (I would suggest further reading "About Time" by Paul Davies. It simplifies a lot of the complexity of the scientific time.) One of the big questions about time that must be figured out is whether time can be measured in static blocks, because we can't currently measure units time to a high enough accuracy this question is left to theorists and tends to border science and philosophy. Some believe that time is the sequence or transition of these static events.
The idea of time being used for calculations was embedded by Newton. But he believed in a constant time, one that he derived from his theological beliefs. This was an assumption that lasted until Einstein who threw relativity at the concept of time into the picture. This where the possibility of time travel comes into play. This is another area where science meets philosophy b/c it raises the paradoxical question of if you go back in time can you kill your grandfather and therefore not exist? I personally don't think so but there is yet to be scientific or mathematical evidence for why you can't.
Time is about ten past nine where I am :D
As far as i know, "time" is the extra dimension that we need to add in our usual 3-D geometry to explain gravity in relativity. As i think, the backward travel in time is prohibited by the sets of lorentz transformation (its improper transformation-that makes v>1, weinberg approach (c=1), since proper homogeneous lorentz transformations always have v< 1). The main problem i find is this-How do we relate the time we use in daily life with that in General Relativity theory?
the man who sees the world in his 50s the same when he was in 20s has wasted his 30 years.
Why not? We may hit upon it by accident. Do we have to understand what goes on in our bodies to live?
Why so?
I've heard many people say that time dilation is valid for atomic time, not for biological time, whatever that means. They simply cannot accept the fact that humans may age at different rates.
The British Science writer Michael Hanlon has made som very interesting comments on this question in his book "10 questions science can't answer (yet)"
If time is nothing more than a 'layer' of the current spatial state of the universe then it wouldn't matter if traveling back in time was possible. Since it'd be just like rewinding a tape, everything goes backward, and same things happens again going forward. Actually then nobody would even notice time was going backwards...
For all we know time goes back & forth all the time ;)
But then again, if that was true, time dilation wouldn't make any sense...
Just ignore me, I'm rambling, but still to me a 'static' universe seems to be the most logical even though that would mean free will is just something our mind makes us believe we have ;)
Isn't this the same as trying to quantize time?
Philosophically a theory of time is unresolved. Most philosophers agree that time does exist but they haven't yet been able to determine what it exactly is. Most of what is known comes from the use of time in well established physical theories such as QM and GR and the nature of time is explored by looking at what these theories demand of the time variable. Perhaps it would suffice to say that time is a set of relations between events.
Here is a good article you may like to read.
http://www.iep.utm.edu/t/time.htm#H3
That was a good article, thanx. A lot of philosophy for one night though...
It's easy to see why time is still unresolved when so many won't even come to a common ground when trying to discuss possibilities. Philosophy's endless circles are daunting.
Clever old A.E. cut through the gordian knot by saying, "Time is what you measure with a clock...". It turned to be quite fruitful, too.
So, I could use any clock, for example a sand glass? I don't think that's a good way to answer (infact he knew that was not an answer).
A sand glass isn't a self-contained clock on its own, but a sand glass combined with a suitable planet to complete the mechanism would work as a clock for that purpose.
I think what Einstein omitted from that quote was the word ideal or accurate.
Absolutely :approve:
And how do you establish if a clock is more accurate than another if you still have to define what time is?
  • · Replies 52 ·
  • · Replies 32 ·
  • · Replies 27 ·
