Problem with compiling formula by LaTeX
  • Context: LaTeX
  • Thread starter Thread starter linderox
    Formula Latex
The discussion revolves around issues related to formatting complex mathematical formulas in LaTeX, particularly focusing on the use of environments like {split} and {eqnarray}. Participants explore how to properly align equations, manage brackets, and ensure that formulas compile correctly across multiple lines.
  • One participant expresses difficulty in splitting a long formula across multiple lines, noting that it works for shorter formulas but fails for longer ones.
  • Another participant points out that the absence of alignment characters (&) could lead to formatting issues, suggesting that this might cause parts of the equation to extend beyond the right margin.
  • A request is made for a corrected version of the formula, indicating that the provided example still does not compile correctly.
  • Concerns are raised about the placement of brackets, with suggestions to use phantom delimiters (\left. and \right.) to ensure proper closure of brackets before line breaks.
  • Participants discuss the need to repeat the \left. and \right. procedure for all sets of brackets in complex equations.
  • One participant shares an alternative formatting approach using the {eqnarray} environment, which they find more suitable for their needs.
  • Another participant mentions issues with counting lines in the output and seeks advice on how to remove extraneous labels from the formula.
  • A later post introduces a new formula using the {split} environment, but it is noted that it lacks the necessary alignment characters in the first line, which could lead to compilation issues.
Participants generally agree on the importance of proper alignment and bracket management in LaTeX, but there are differing opinions on the best methods to achieve this. The discussion remains unresolved regarding the optimal formatting techniques for complex equations.
Some participants express uncertainty about the functionality of the {split} command and its requirements, indicating that there may be additional nuances in LaTeX formatting that are not fully addressed in the discussion.
linderox
I read a lot literature how to provide dividing of the formulas to new lines,but it's work just on a short one good like 1st one and doesn't on main (2nd one)
Code:
\begin{equation}\begin{split}
\Psi = & \cos kz + i\sin kz + {} \\
& {} + \frac{f(\theta)}{r}
(\cos kr + i\sin kr)
\end{split}\end{equation}
I try different ways used {split} but everything stopped on the 2nd "\\". Can anybody say me why?
Code:
U = U_0\cos[c_1 \cos(\omega t) + c_2 cos(\omega_1 t) + \phi] \\
=U_0 \cos\phi\left[|J_0(c_1)J_0(c_2)| + \sum_n |2J_0(c_2 )J_{2n}(c_1)|\cos 2n\omega t \\
+\sum_k|2J_0(c_1 )J_{2k}(c_2)|\cos 2k\omega_1 t + \sum_n\sum_k |2J_2n(c_1)J_{2k}(c_2)| \cos [2(k\omega_1 — n\omega)t] \\
+\sum_n \sum_k|2J_{2n}(c_1)J_{2k}(c_2)|\cos [2(k\omega_1 + n\omega)t] \\
+\sum_n \sum_k|J_{2n-1}(c_1)J_{2k-1}(c_2)|\cos[(2k —1)\omega_1—(2n — 1)\omega]t \\
+\sum_n \sum_k|J_{2n-1}(c_1)J_{2k-1}(c_2)|\cos[(2k —1)\omega_1+(2n — 1)\omega]t\right] \\
+U_0\sin\phi\left[\sum_n |2J_0(c_2)J_{2n-1}(c_1)|\cos[(2n—1)\omega t] \\
+\sum_k | 2J_0(c_1)J_{2k-1}(c_2)|\cos[(2k — 1)\omega_1 t] \\
+\sum_n \sum_k|2J_{2n-1}(c_1)J_{2k}(c_2)|\cos[2k\omega_1—(2n—1)\omega]t \\
+\sum_n \sum_k|2J_{2n-1}(c_1)J_{2k}(c_2)|\cos[2k\omega_1+(2n—1)\omega]t \\
+\sum_n \sum_k|J_{2n}(c_1)J_{2k-1}(c_2)|\cos [(2k—1)\omega_1—2n\omega]t \\
+\sum_n \sum_k|J_{2n}(c_1)J_{2k-1}(c_2)|\cos [(2k—1)\omega_1+2n\omega]t\right]
Well, the most obvious problem is you forgot the alignment character (&). I could believe that would result in the bottom part of your equation sitting a few feet past the right margin.
can you write right version here?
this version for example doesn't work too!
Code:
\begin{eqnarray*}
U=U_0\cos[c_1 \cos(\omega t) + c_2 cos(\omega_1 t) + \phi] \\
& {} U=U_0 \cos\phi\left[|J_0(c_1)J_0(c_2)| + \sum_n |2J_0(c_2 )J_{2n}(c_1)|\cos 2n\omega t \\
& {} +\sum_k|2J_0(c_1 )J_{2k}(c_2)|\cos 2k\omega_1 t + \sum_n\sum_k |2J_2n(c_1)J_{2k}(c_2)| \cos [2(k\omega_1 — n\omega)t] \right]
\end{eqnarray*}
I would imagine that your problem is that you are trying to split equations before you have closed the brackets (i.e. you have a \left[ but no \right] before the \\). A way to remedy this is to use phantom delimiters (\left. and \right.) , so your input would read (with additions in red):
Code:
=U_0 \cos\phi\left[|J_0(c_1)J_0(c_2)| + \sum_n |2J_0(c_2 )J_{2n}(c_1)|\cos 2n\omega t \right.[/color]\\
\left.[/color]+\sum_n \sum_k|J_{2n}(c_1)J_{2k-1}(c_2)|\cos [(2k—1)\omega_1+2n\omega]t\right]
You should also correct the mistake that Hurkyl has pointed out.
but it's it very long brackets!
Did I miss something? Is there only one set of brackets in your equation, or are there several? You should repeat the \right. \\ left. procedure for all sets of brackets. Note that this won't do anything to the appearance of the equation, but will just make it work.
Yes, Cristo! It works with your version,but What I have write - it is my long formula with a beginning bracket \left[ at the 1st line and
ended bracket \right] at the end of the whole formula
i don't understand what you meant... "You should repeat the \right. \\ left. procedure for all sets of brackets..." . maybe you can give some example?
2) How better present this formula?
I want to see all lines connected to the left side of the page,but not like now...
This is how I'd typset it (I'm not really that familiar with "split")
Code:
\begin{eqnarray}
%\begin{split}
U&=& U_0\cos[c_1 \cos(\omega t) + c_2 cos(\omega_1 t) + \phi] \\
&=&U_0 \cos\phi\left[|J_0(c_1)J_0(c_2)| + \sum_n |2J_0(c_2 )J_{2n}(c_1)|\cos 2n\omega t \right.\\
&&+\sum_k|2J_0(c_1 )J_{2k}(c_2)|\cos 2k\omega_1 t + \sum_n\sum_k |2J_2n(c_1)J_{2k}(c_2)| \cos [2(k\omega_1 — n\omega)t] \\
&&+\sum_n \sum_k|2J_{2n}(c_1)J_{2k}(c_2)|\cos [2(k\omega_1 + n\omega)t] \\
&&+\sum_n \sum_k|J_{2n-1}(c_1)J_{2k-1}(c_2)|\cos[(2k —1)\omega_1—(2n — 1)\omega]t \\
&&\left.+\sum_n \sum_k|J_{2n-1}(c_1)J_{2k-1}(c_2)|\cos[(2k —1)\omega_1+(2n — 1)\omega]t\right] \\
&&+U_0\sin\phi\left[\sum_n |2J_0(c_2)J_{2n-1}(c_1)|\cos[(2n—1)\omega t\right. \\
&&+\sum_k | 2J_0(c_1)J_{2k-1}(c_2)|\cos[(2k — 1)\omega_1 t] \\
&&+\sum_n \sum_k|2J_{2n-1}(c_1)J_{2k}(c_2)|\cos[2k\omega_1—(2n—1)\omega]t \\
&&+\sum_n \sum_k|2J_{2n-1}(c_1)J_{2k}(c_2)|\cos[2k\omega_1+(2n—1)\omega]t \\
&&+\sum_n \sum_k|J_{2n}(c_1)J_{2k-1}(c_2)|\cos [(2k—1)\omega_1—2n\omega]t \\
&&\left.+\sum_n \sum_k|J_{2n}(c_1)J_{2k-1}(c_2)|\cos [(2k—1)\omega_1+2n\omega]t\right]
%\end{split}
\end{eqnarray}
I just meant that you've got more than one set of brackets, so need to put more that one \left. and \right. in (I've done it above)
Wow! great Thank! but now i have a problem counting each line... how to remove everything except the label to the formula?
Code:
\begin{eqnarray}
%\begin{split}
&=&U_0 \cos\phi\left[|J_0(c_1)J_0(c_2)| + \sum_n |2J_0(c_2 )J_{2n}(c_1)|\cos 2n\omega t \right.\nonumber \\
&&+\sum_k|2J_0(c_1 )J_{2k}(c_2)|\cos 2k\omega_1 t + \sum_n\sum_k |2J_2n(c_1)J_{2k}(c_2)| \cos [2(k\omega_1 — n\omega)t] \nonumber \\
&&+\sum_n \sum_k|2J_{2n}(c_1)J_{2k}(c_2)|\cos [2(k\omega_1 + n\omega)t]\nonumber \\
&&+\sum_n \sum_k|J_{2n-1}(c_1)J_{2k-1}(c_2)|\cos[(2k —1)\omega_1—(2n — 1)\omega]t \nonumber \\
&&\left.+\sum_n \sum_k|J_{2n-1}(c_1)J_{2k-1}(c_2)|\cos[(2k —1)\omega_1+(2n — 1)\omega]t\right] \nonumber \\
&&+U_0\sin\phi\left[\sum_n |2J_0(c_2)J_{2n-1}(c_1)|\cos[(2n—1)\omega t\right. \nonumber \\
&&+\sum_k | 2J_0(c_1)J_{2k-1}(c_2)|\cos[(2k — 1)\omega_1 t] \nonumber \\
&&+\sum_n \sum_k|2J_{2n-1}(c_1)J_{2k}(c_2)|\cos[2k\omega_1—(2n—1)\omega]t \nonumber \\
&&+\sum_n \sum_k|2J_{2n-1}(c_1)J_{2k}(c_2)|\cos[2k\omega_1+(2n—1)\omega]t \nonumber \\
&&+\sum_n \sum_k|J_{2n}(c_1)J_{2k-1}(c_2)|\cos [(2k—1)\omega_1—2n\omega]t \nonumber \\
&&\left.+\sum_n \sum_k|J_{2n}(c_1)J_{2k-1}(c_2)|\cos [(2k—1)\omega_1+2n\omega]t\right] \nonumber
%\end{split}
\end{eqnarray}
Great thanks
linderox said:
Great thanks
You're welcome :smile:
hm... but why it does not work?
\be
\begin{split}
P(t)=cos\theta J_0(\alpha) + 2 \cos \theta \sum_{n=1}^\infty J_{2n}(\alpha)\cos[2n f_0 t +l_0] \\
&&-2\sin\theta \sum_{n=1}^\infty J_{2n-1}(\alpha)cos[(2n-1) f_0 t +l_0]
\end{split}
\label{equ:P_t_bessel}
\ee
I'm not sure; like I said, I don't really know too much about the split command. I can see one problem, namely that you have no && in your first line. Here's another way to write it, along with the output:
Code:
\be
\begin{array}{ccc}
P(t)&=&cos\theta J_0(\alpha) + 2 \cos \theta \sum_{n=1}^\infty J_{2n}(\alpha)\cos[2n f_0 t +l_0] \\
\end{array}
\ee
[tex]\begin{array}{ccc}<br /> P(t)&=&cos\theta J_0(\alpha) + 2 \cos \theta \sum_{n=1}^\infty J_{2n}(\alpha)\cos[2n f_0 t +l_0] \\<br /> &&-2\sin\theta \sum_{n=1}^\infty J_{2n-1}(\alpha)cos[(2n-1) f_0 t +l_0]<br /> \end{array}[/tex]
I have a problem,
I have \left{ and a \righ} in two lines, I want them to be the same size, both big, but only one that has the summation infront of it is big
Can you please help?
thank you
\begin{eqnarray*}
\log p(\mathbf{x}_n,\mathbf{z}_n| \bm{\mu},\bm{\pi}) &=& \log \prod_{k=1}^K \left[\pi_k \, p(\mathbf{x}_n|\bm{\mu_k}) \right]^{z_{nk}} \\
&=& \sum_{k=1}^K z_{nk} \{ \log \pi_k + \log p(\mathbf{x}_n|\bm{\mu_k}) \} \\
&=& \sum_{k=1}^K z_{nk} \left\{ \log \pi_k \right. \\
&+& \left. \sum_{i=1}^D [x_{ni}\, \log \mu_{ki}+(1-x_{ni})\, \log (1-\mu_{ki})] \right\}
\end{eqnarray*}
\left and \right can only be used on the same line. There are at least a couple of ways around this:
(1) Use a dummy \right. to pair with the \left{ on one line and a dummy \left. to pair with the \right} on the next line.
(2) Use bigl/bigr Bigl/Bigr biggl/biggr Biggl/Biggr in lieu of left/right.
11K
  • · Replies 28 ·
