Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Advanced Physics Homework (http://www.physicsforums.com/forumdisplay.php?f=154)
-   -   Point Charges in a Square: Could the Force on Each Be Zero? (http://www.physicsforums.com/showthread.php?t=252887)
DietRichCola Aug31-08 06:54 PM
A charge Q is fixed at each of two opposite corners of a square, while a charge q is fixed at the other two corners. (a) if the resultant electrical force on Q is zero, how are Q and q related? (b) could q be choosen to make the resultant electrical force on every charge zero? explain.
F1 = force between Q's
F2 = force between one Q and q's
a = side of the square
2. Relevant equations
F = (1/(4*pi*E))(q1*q2/r^2)
3. The attempt at a solution
(a) F1 = (1/(4*pi*E))(Q^2/2a^2)
F2 = (1/(4*pi*E))((Qq*sqrt(2))/(a^2))
I set them equal to each other and got: Q = -2q*sqrt(2)
The answers weren't in the back of the book, so I'm not sure if that's correct or not
The part I'm having trouble with is part (b). I don't think there can be a value for q that would make the forces on all the charges zero, but I don't know how to explain that.
Thanks!
granpa Aug31-08 07:06 PM
Re: Point Charges in a Square: Could the Force on Each Be Zero?
whats the distance between the Q's?
and where did the sqr(2) come from in your F2 equation?
DietRichCola Aug31-08 08:16 PM
the distance of the side of the square is a, so the diagonal is a*sqrt(2)
granpa Aug31-08 08:26 PM
I misread it as (2a)^2.
still dont understand the F2 equation.
you cant just set them equal to each other. they are vectors.
DietRichCola Aug31-08 09:16 PM
i saw the equation: (1/(4*pi*E))((Qq)/(a^2)) as the force on one of the sides of the square between Q and q. and i know there's another force pointing perpendicular on the adjacent side of the square. the addition of those two vectors would give me the hypotenuse of a 45-45-90 triangle. therefore, i saw that the magnitude of the hypotenuse is that force times sqrt(2).
would that be right?
granpa Aug31-08 09:22 PM
sounds good.
DietRichCola Aug31-08 09:48 PM
that's good.
do you know about part (b) ?
granpa Aug31-08 09:50 PM
you know what q must be for the force on Q to be zero. what must the charge on Q be to make the force on q be zero?
DietRichCola Sep1-08 12:29 AM
Since it's a square, the charge for q would be the same formula as it was for Q, just the Q and q are switched:
q = -2Qsqrt(2)
granpa Sep1-08 12:37 AM
yes. and so? what is your conclusion?
DietRichCola Sep1-08 08:52 PM
so would that mean that the value of q would be -Q ?
i know q =/= Q because then the charges would all repel each other.
if i plug one equation into the other, like: q = -2(-2q*sqrt(2))sqrt(2), i just get that q=8q. which is why i think there can't be a value for q. though, i don't know the explanation.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
