Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Mechanical Engineering (http://www.physicsforums.com/forumdisplay.php?f=101)
-   -   COMSOL+Heat Transfer (http://www.physicsforums.com/showthread.php?t=254090)
Skyeagle Sep6-08 07:42 AM
Hi guys,
I found this forum by chance. Was wondering if anyone could help out with my problem. I am very new to this COMSOL and I am required to tackle a problem.
I am required to simulate laser drilling onto a material using comsol to obtain the heat transfer pattern. I have chosen silicon in the drop-down box
I used the New>FEM>Heat Transfer>Conduction>Transient Analysis.
I then created a rectangle with 3 sides thermally insulated and the top is having heat flux.
Under Boundary settings, I need to enter the equation in the Q field as the heat source
The equation is like this: (10^7) x exponential (-10^3 x X^2) for a time of 2 seconds.
I keep having syntax errors. How do I put in the equation properly?
Thanks.
PerennialII Sep6-08 12:32 PM
Re: COMSOL+Heat Transfer
Hi Skyeagle,
Comsol syntax is pretty much identical to that of Matlab (well they share plenty of history) ..... so for your equation you might try something like:
(10^7)*exp((-10^3)*x^2)*(t<=2)
I'm assuming what you're after with the "x" is a cartesian coordinate (or that is how comsol would interpret from the above)? The "t<=2" evaluates as "1" for t <=2 (assuming your t is in seconds) and 0 otherwise (you can do the same thing with a simple "if" - construct or use several of the other available step - function - lookalikes, if you for example wish to smoothen the transition to 0 value).
Skyeagle Sep6-08 10:30 PM
PerennialII ,
Thanks for the reply. yup. I got the waveform as per the syntax that you have given. Right now I need to generate the temperature profile which I am facing some problem.
Its not what I am expecting.
PerennialII Sep7-08 03:21 AM
Yeah, these often take surprising chunks of time to get them working. Let me know if can try to come up with further pointers.
CFDFEAGURU Sep8-08 05:50 PM
If you like I can help you out with a simulation in Ansys. Let me know if you want my help.
cap_kenn Feb27-09 06:56 AM
hi, im dont no nothing about COMSOL, apart from the using a user guid to make a model and plot a graph.. what i wish to achieve is a wire ( rectangle ) which gives heat at one end and over time the heat eventually transfers over to the other.
Thanks kenn
rr00053 Feb28-09 09:47 AM
i think you cn try with the heat transfer using the conduction model to do this....try using tat and contact if u have any doubt
cap_kenn Mar2-09 03:17 AM
as a complete novis to this software, could you explain to me in a step by step process how to achive a model of heat flow from one end of a wire to another? i would reli appreciate this, as well as a stress flow model aswell (where one end increases in tensile stress and the other end increases in compressive stress), many thanks
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
