Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Differential Equations (http://www.physicsforums.com/forumdisplay.php?f=74)
-   -   Analytical Solution to this? -- linear system of ODES (http://www.physicsforums.com/showthread.php?t=262358)
FrogPad Oct7-08 08:58 AM
Hi All,
It's been awhile since I've even attempted to solve something analytically, so before jumping back into the text. Does the following already have a common solution that I can find somewhere?
Thanks,
dx1/dt = A1 + B1x1 +C1x2 + D1x3
dx2/dt = A2 + B2x1 +C2x2 + D2x3
dx3/dt = A3 + B3x1 +C3x2 + D3x3
HallsofIvy Oct7-08 09:42 AM
Re: Analytical Solution to this? -- linear system of ODES
That certainly does have an "analytical solution" since it is a system of linear we equations with constant coefficients. If you are asking for a specific formula, so yo can just plug in the values of A1, B1, etc. I doubt you will find such a thing. I would be inclined to write it as a matrix equation:
[tex]\frac{d\left[\begin{array}{c}x1 \\ x2 \\ x3 \end{array}\right]}{dt}= \left[\begin{array}{ccc} B1 & C1 & D1 \\ B2 & C2 & D2 \\ B3 & C3 & D3\end{array}\right]\left[\begin{array}{c} x1 \\ x2 \\ x3 \end{array}\right]+ \left[\begin{array}{c}A1 \\ A2 \\ A3\end{array}\right][/tex]
and then look for the eigenvalues of the matrix. The eigenvalue equation is, of course, a cubic equation.
FrogPad Oct7-08 09:51 AM
I assumed since it was linear that I could get a solution to it, but like you said there is a cubic in there. That cubic is probably going to be a pain in the ...
I was especially asking, because for whatever reason it looks like it could be a really standard problem that has been solved over and over again. Before diving in, I just wanted to test the waters.
Also, why did you quote "analytical solution"? Just curious...
Thank you
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
