What Frequency Range Keeps the Spring Safe in Driven Oscillations?
The discussion revolves around a driven oscillation problem involving a block suspended by a spring. The block's mass is 2 kg, and it is subjected to a vertical driving force. The spring has a strength of 2000 N/m, and there is a concern regarding the maximum extension of the spring to prevent yielding. Participants are tasked with determining the frequency range that can be safely applied without exceeding the spring's extension limit.
  • Participants discuss the setup of the ordinary differential equation (ODE) for the system, questioning the inclusion of damping terms and the representation of forces acting on the mass. There are attempts to clarify the roles of gravitational and driving forces in the context of the spring's behavior.
The discussion is ongoing, with participants actively questioning each other's assumptions and interpretations of the problem. Some have provided insights into the forces at play, while others are still seeking clarity on how to correctly formulate the equations governing the system.
Participants note the absence of explicit information regarding damping in the problem statement, leading to varied interpretations of whether damping should be included in the equations. There is also a focus on ensuring that the forces are correctly represented in the context of the problem.
Benzoate
1. The problem statement, alml variables and given/known data
A block of mass 2 kg is suspended from a fixed support by a spring of strength 2000 N m^-1. The block is subject to the vertical driving force 36 cos pt N. Given that the spring will yield if its extension exceeds 4 cm, find the range of frequencies that can safely be applied. Take g = 10 m s-2
m*x'' + b*x'+kx= F(t)
x''+2*K*x' + [tex]\Omega[/tex]2=F0cos(pt)
2*x''+ b*x'+ 2000*x=36*cos(pt) N
what is the extension, and how would I find the range of frequencies.
Are you sure that you have set up your ODE correctly? There are no velocity dependent forces specified in the question and you don't seem to have any term to account for the weight of the mass.
I had the last equation written wrong.
x''+2*K*x'+x*[tex]\Omega[/tex]2=F0*cos(pt)
I didn't include the weight into the equation because I wasn't sure how to incorporate weight into the oscillation driven equation since there is no weight term.
Let's start again from first principles. Newton's second law states that
m*x'' = Fnet
Where Fnet is the sum of all forces acting on the body. So what is the sum of all the forces acting on you block?
m*x'' = Fnet
Fnet= Fspring+Fgrav
Fspring= m*x'' + b*x'+kx
Fgrav= m*g
can ignore drag forces for now.
Are you sure about your F_spring? Is there really a damping force specified in this question? And why is there an mx'' in there?!
I got the equation
Fspring= m*x'' + b*x'+kx , from the textbook Classical Mechanics written by John R. Taylor.
The problem doesn't specify that there is a damping constant present, but I thought that a damping constant could not be present only when the oscillator is under ideal conditions, i.e. no dissipative force presents and the oscillator oscillates forever.
Benzoate said:
Fnet= Fspring+Fgrav
Fgrav= m*g
You say that we can ignore drag forces, yet you include a damping term (b*x') in your spring equation. You also pull a second order differential term out of thin air.
One other thing to be careful of is your signs. The weight of the mass will always act down and would there usually be negative is a standard coordinate system.
Benzoate said:
I got the equation
You can't just blindly apply equations from texts without knowing what they mean! Close that textbook and read the question. Now, what are the forces acting on the mass?
Fnet= Fspring-Fgrav
You are right. drag forces would be present only when a damping constant is present, well at least for a simple harmonic.
x''+2Kx'+(x*(omega)^2)=X''
X=36 cos (pt)
X'= -36 p sin (pt)
X''= -36 p2 cos(pt)
Therefore
x''+2Kx'+(x*(omega)^2)=-36 p2 cos(pt)
Benzoate said:
Fnet= Fspring-Fgrav
X=36 cos (pt)
X'= -36 p sin (pt)
X''= -36 p2 cos(pt)
Therefore
I still have no idea where you're pulling these equations from. You still have a damping here in there (x'), there is no damping force. As I said above, the best way to start this question is to simply write down the sum of the forces acting on the mass. In other words, write the following expression explicitly.
Benzoate said:
Fnet= Fspring-Fgrav
Fnet = ...
Fnet = ...
x'' + 2Kx' + [tex]\Omega[/tex]2=F(t) is the spring equation for driven harmonic motion. I am not pulling these equations out of thin air. How can there not be a damping present when the only case where a damping constant is not present in the equation for an oscillator is when the linear oscillator is a classical linear oscillator, where external conditions allow oscillator to bounce up and down forever without stopping. And the problem doesn't say that this external driving force will act upon the oscillator forever , so I don't think I can just assume no damping constant is present.
Hootenanny said:
Fnet = ...
Fexternal=Fspring -Fgrav ; what other forces could there possibly be?
There is also a driving force isn't there? ;0)
What are the expressions for each of these three forces,
F_spring=?
F_grav=?
F_driving=?
If you assume that there is a damping force, then you can not find a numerical solution (the solution will be a function for the damping parameter). You are not told that the system is damped, nor are you given any information regarding the damping constant, nor can you work out the damping constant with the information provided.
F_spring=?
F_grav=?
F_driving=?
My external force is my driving force
F_grav=-mg
F_spring=-kx
F_external= 36*cos(pt)
36*cos(pt)= -mg - kx
Shouldn't F_net=F_grav+F_spring+F_driving? Also since F_spring is presumably the restoring force that the spring imparts onto the mass, shouldn't it be +kx to signify that it is pulling the mass upward (while gravity is pushing it downward)?
For an damped undriven oscillator
x''+2*K*x' +omega^2*x=0
for a driven harmonic oscillator
x''+2*K*x'+omega^2*x=F_driven
and F_grav i thought was always pointing down so shouldn't F_grav have a negative sign?
Forget about those two equations for a second and continue on with F_net (the sum of all forces acting on m).
F_net=?
F_net=?
Okay.
F_net= F_spring + F_driven-F_gravWhy should I be concerned with the net force?
Benzoate said:
Okay.
Because from Newton's second law, the net force is also equal to ma=mx'', so you get a differential equation for x:
mx''=F_net=F_spring + F_driven+F_grav
(this is how the equations of motion for the oscillator in your book are derived!)
Substitute your expressions for F_spring,F_driven,F_grav into this; what do you get?
F_spring= -kx
F_grav= -mg
F_driven = 36 cos(pt)
mx''= 36 cos(pt)-mg-kx
Close, F_spring should be positive since it is pulling the mass upwards. So,
mx''= 36 cos(pt)-mg+kx
=> mx''-kx=36cos(pt)-mg
Which is an inhomogeneous ODE. Have you tackled one of these before?
gabbagabbahey said:
Close, F_spring should be positive since it is pulling the spring upwards. So,
I think so. I would treat this as an auxillary equation:
mx''-kx= 36 cos(pt)-mg ==>What should I assume about pt
==> x''-(k/m)*x = 36/m*cos(pt) - g
Should I let x= ceipt?
should I also take the amplitude into account:
a= F0/(([tex]\Omega[/tex]2-p2)2-4K2p2)1/2
r^2-1000= 18 cos pt -10
let F= 18e^(ipt)
x'' -1000x = 18 e^(ipt)
x= ce^(ipt)
x'= cip*e^(ipt)
x''= -cp^2*e^(ipt)
e^(ipt) cancel and I am left with :
(cp^2*e^(ipt))-1000(ce^(ipt))= 18e^(ipt) -10
Normally e^(ipt) would cancel , but since I have an extra term where the e^(ipt) is not a coefficient therefore , I can't cancel out e^ipt easily
I don think I will have any qualms with obtaining the complementary solution since:
r^2-1000= 0
therefore
x=Ae^(-31.6277t) + B*t*e^(-31.62777t)
what role will the extension of the spring play in my general equation ?
No, Benzoate had it correct first time. F_spring is a restoring force so it is going to be positive sometimes, but negative other times. In the ODE, and Hooke's law for that matter, x represents the displacement from the equilibrium position; in other words when the mass is simply hanging stationary from the spring, it is at position x=0. Now, when the mass drops below this point (negative x) the restoring [spring] force is going to be directed upwards, toward the origin (equilibrium position). However, when the mass is above this point (positive x), the restoring [spring] force will be directed downwards. Therefore, the correct expression is
Fspring = -kx
As Benzoate had it originally. Hence, the correct form of the ODE is
mx'' = 36cos(pt) - kx - mg
Do you follow Benzoate? This is an important point to note. I'll help you with solving the ODE next.
Fspring = -kx
yes, I understand now why spring force is in the negative direction. However , my x=e^ipt fails to cancel out nicely .
Start by finding the complimentary solution; that is the solution to mx''+kx=0 (sorry about the +-kx confusion BTW)
x=e^ipt
x'=ipe^ipt
x''=-p^2*e^ipt
e^ipt cancels and I am left with
mp^2 - k=0
dividing out the mass I now have:
p^2-k/m=0
plugging in k and m I get:
p^2=1000
p1= [tex]\sqrt{1000}[/tex]
p2=- ([tex]\sqrt{1000}[/tex])the equation for complementary function is :
x= c1ep1*t + c2ep2*t
now I think what I only have left is to calculate the amplitude and the equation for the driven response xD
Not sure how to calculate to xD easily since the e^ipt factor doesn't dissipear so easily .
what role will the extension play in the problem
Benzoate said:
x=e^ipt
x'=ipe^ipt
x''=-p^2*e^ipt
mp^2 - k=0
p^2-k/m=0
p^2=1000
Your solution looks okay, except that you're missing a factor i from your complementary function. In the first line of your solution you say assume that
x=e^ipt
And then you determine the values of p,
[tex]p_{1,2}=\pm10\sqrt{10}[/tex]
Hence, your complementary function should be
x= c1eip1*t + c2eip2*t
Do you follow? It is the fact that these exponentials are complex, that we allow us to write the complimentary function in a form that is little easier to deal with.
To answer your question regarding extension, x is the extension of the spring beyond it's equilibrium position.
  • · Replies 17 ·
  • · Replies 20 ·
