How can I find the critical points of a function involving fractions?
  • Context: Undergrad
  • Thread starter Thread starter Дьявол
    Function Maxima Minima
The discussion revolves around finding critical points, including minima and maxima, of various functions, particularly focusing on quadratic functions and a rational function. Participants explore methods such as taking derivatives, completing the square, and analyzing the behavior of the first and second derivatives.
  • Some participants suggest that critical points occur where the first derivative f'(x) equals zero.
  • Others mention that minima or maxima can be found at the vertex of a parabola, which lies halfway between the x-intercepts.
  • A few participants argue that the second derivative f''(x) can be used to determine the nature of the critical points (maximum or minimum).
  • There is a discussion about the terminology, with some participants clarifying the difference between critical points and stationary points, as well as the concept of saddle points.
  • One participant raises a question about points where f'(x) = 0 that are neither maxima nor minima, leading to a discussion on saddle points and inflection points.
  • Another participant provides an example of a quadratic function and demonstrates how to find its minimum using the method of completing the square.
  • A later post introduces a rational function and seeks assistance in finding its critical points, indicating a shift in focus from quadratics to more complex functions.
Participants generally agree on the methods for finding critical points and the role of derivatives, but there is some disagreement regarding terminology and the classification of certain points (e.g., saddle points vs. inflection points). The discussion remains unresolved on the nature of points where f'(x) = 0 but are not extrema.
Some participants express uncertainty about the application of their methods to functions beyond quadratics, particularly in the case of rational functions. There are also unresolved questions regarding the definitions and classifications of various types of points related to derivatives.
Дьявол
How will I find minima,maxima or both of one function (if they exist)? For example:
[tex]f(x)=x^2-3x+2[/tex];
[tex]f(x)=x^2-2x-x+2[/tex];
[tex]f(x)=x(x-2)-(x-2)[/tex];
[tex]f(x)=(x-2)(x-1)[/tex]
x1,2=1,2
Those are the zeroes of the function.
But how will I find the critical points (minima,maxima) of the function if [itex]x \in \mathbb{R}[/itex]
The minima/maxima of a function is the point(s) where [tex]f'(x)=0[/tex]
That's a quadratic function. Since it is concave upward it has a minimum but no maxiumum. The minimum is at the vertex you need to find the vertex. You could do that by completing the square but since you have already found the x-intercepts of the function, you can use the fact that, for a parabola with vertical axis, the vertex always lies half way between the x-intercepts.
Since this problem has nothing to do with linear algebra or abstract algebra, I am moving it to "General Mathematics".
Take the derivative of the originial function, then find where the derivative equals zero. Then plug those points (they are x-values) into your original function, and that will be your Y-coordinates. That will give you the values of your max's and min's. It will also let you see absolute max and min.
Don't forget about inflection points!
Do you mean like f(x)=(x-a)2+b ?
HallsofIvy, When I draw graphic of the function it is not parabola.
f(3)=2
f(2)=0
f(1)=0
f(0)=2
f(-1)=6
f(-2)=12
f(-3)=20
f(x) has a relative minimum or maximum at either the endpoints of a region you're observing or when f'(x)=0. To determine whether it's a minimum, find when f''(x) is positive or negative; when f''(x) is positive, the graph is concave up, and when f''(x) is negative, the graph is concave down. Therefore, you have a relative extrema when f'(x)=0; it's a maximum if f''(x) is positive, or a minimum if f''(x) is negative.
F''(x)=0 are your points of inflection.
Eh? If inflection points are where f''(x) = 0 (which they are), what do you call points where f'(x) = 0, but is neither a maximum nor a minimum? For example, f(x) = x^3, which has no maximum or minimum has f'(0) = 0. What are those points called if it's not inflection points?
f(3)=2
f(2)=0
f(1)=0
f(0)=2
f(-1)=6
f(-2)=12
f(-3)=20
? It certainly is a parabola! Any quadratic function has a parabola as its graph. And the points (3,2), (2,0), (1,0), (-1,6), (-2,12), (-3,20) definitely lie on a parabola. The vertex is, as I said before, half way between 1 and 2, at 3/2. f(3/2)= 9/4- 9/2+ 2= -9/2+ 2= -5/2. f(x)= (x- 3/2)^2- 5/2.
Saddle points.
Edit
Perhaps that was too hasty. The problem is that the term inflection point describes a point where the second derivative reaches this. Inflection points obviously do not in general coincide with stationary points. A saddle point is by definition a stationary point that is not a local extremum.
Inflections points are the points where the 2nd derivative equals zero, at those points the concavity will change.
Where the first derivative is zero are called critical points, those are the relative max's and mins of a function.
More appropriately, the points where the first derivative is zero are called stationary points. The absolute value function has a well-defined critical point: x=0. It has no stationary point because the derivative is non-zero everywhere except for x=0 and is not defined at x=0.
Not all stationary points are extremal. Tac-Tics gave a perfectly good example of a function that has a stationary point but no extremal points.
A quadratic function does not have any "inflection" points. And the original question has already been completely answered.
Ah, yes. Thank you. It's been about 6 years since I studied this. The concept is there, but the terminology is fuzzy and needs dusting :-)
Since all of your functions are quadratic, an alternative to calculus is to complete the square. Ie., your first function is f(x) = x^2 - 3x + 2 = (x - 3/2)^2 - 5/2. Since squares of real numbers are never negative, your function has the minimum point (3/2, -5/2).
Thanks for the posts. I found the minima with derivation of the original formula. So my goal is [itex]x^2-3x+2=(x-a)^2+b[/itex]
[tex]x^2-3x+2=x^2-2ax+a^2+b[/tex]
[tex]-3x+2=-2ax+(a^2+b)[/tex]
[tex]-3=-2a[/tex]
and
[tex]2=(a^2+b)[/tex]
So, a= 3/2
and
[tex]b=2-9/4[/tex]
[tex]b=-1/4[/tex]
[tex]x^2-3x+2=(x-3/2)^2-1/4 \geq -1/4=f(3/2)[/tex]
So 3/2 is the local minimum.
In other words, the vertex of the parabola is at x= 3/2, half way between the x-intercepts. That's what I said in post 3.
I am again stuck with minima and maxima of function.
The original problem:
[tex]f(x)=\frac{4x}{3x^2+4}[/tex]
Now, I tried:
[tex]f(x)=\frac{4}{3}*\frac{x}{x^2+\frac{4}{3}}=\frac{4}{3}*\frac{1}{x+\frac{4}{3x}}[/tex] and I don't know how to go on out of here. I was trying to have something in the form (x+a)2+b > or < b
Also I tried [tex]\frac{4x}{3x^2+4} + 1 - 1=\frac{3(x^2+\frac{4}{3}x+\frac{4}{3})}{3(x^2+\frac{4}{3})} - 1 = \frac{(x-\frac{2}{3})^2+\frac{6}{9} \geq \frac{6}{9}}{(x-0)^2 + \frac{4}{3} \geq \frac{4}{3} } - 1[/tex]
Again nothing. Please help me!
Thanks in advance.
  • · Replies 17 ·
