Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Calc BC - Integration Problem involving Constants of Integration and Related Rates (http://www.physicsforums.com/showthread.php?t=281700)
carlodelmundo Dec27-08 09:12 AM
Let A be the area of the region in the first quadrant under the graph of y = cos (x) and above the line y = k for 0 <= k <= 1.
a.) Determine A in terms of k.
b) Determine the value of A when k = 1/2.
c) If the line y = k is moving upward at the rate of ( 1 / pi ) units per minute, at what rate is the area, A, changing when k = 1/2 ?
2. Relevant equations
Fundamental Theorem of Calculus
3. The attempt at a solution
Here's my work insofar:
http://carlodm.com/calc/prob2.jpg
For c.) I have no idea on how to tackle this problem. Should I derive my area formula in terms of dt?
Thanks
Dick Dec27-08 03:57 PM
Re: Calc BC - Integration Problem involving Constants of Integration and Related Rate
It would really help if you could make a smaller scan. You are doing fine up to c). First you need to find dA/dk correctly. A(k)=sin(arccos(k))-k*arccos(k). It looks like its almost right, except why are you mixing x's and k's. Shouldn't they all be k's?
carlodelmundo Dec29-08 11:24 AM
Thank you Dick for your help. Here's my new work:
http://carlodm.com/calc/prob4.JPG
I have a problem. I have the rate of change of area with respect to time in terms of x. I'm given a rate of change in terms of y. I thought to myself that maybe I can just "cheat" and plug in dK/dt for dx/dt, but isn't this wrong?
Basically, can you give me tips to solve for the rate of change of y? I'm stumped.
Dick Dec29-08 01:58 PM
You are sort of confusing x and k. x is the variable you are integrating over. The upper limit is arccos(k). Area should just come out as a function of k. I get that dA/dk=-arccos(k). dA/dt=dA/dk*(dk/dt).
carlodelmundo Dec30-08 05:00 PM
Thanks a lot, Dick!
You're right about me confusing x and k. I thought all related rates problems derived in terms of t, but now I can see that that's not always the case. That is a very elegant solution in my opinion.
Here is my revised work:
http://carlodm.com/calc/prob6.PNG
Is my answer -1/3 Units^2 / min correct?
Dick Dec30-08 05:07 PM
Looks good to me!
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
