*HELP* Finding x in [_,_] of Possible Inflection Points
  • Thread starter Thread starter AnnaSuxCalc
    Points
The discussion revolves around finding possible inflection points of the function f(x) = e^sin(x) by analyzing its second derivative, f''(x). Participants are tasked with determining the x-coordinates of these points within the interval [0, 2π].
  • Participants discuss factoring the second derivative and setting it to zero. There are attempts to clarify the implications of the hint regarding the function g(t) = e^t, which is never zero. Questions arise about the meaning of "possible inflection points" and how to find all relevant x-values in the specified interval.
The conversation is ongoing, with participants exploring different methods to solve the equation cos^2(x) - sin(x) = 0. Some guidance has been provided regarding the quadratic form of the equation in terms of sin(x), and there is recognition of the need to find two solutions within the interval [0, 2π].
Participants express confusion about the problem's requirements and the implications of the solutions found so far. There is a focus on ensuring that all solutions are within the specified interval and that the values are expressed in radians.
AnnaSuxCalc
The solutions of f''(x) = 0 are the x-coordinates of possible inflection points on the curve y = f(x), where f'' denotes the second derivative of f. The second derivative of f(x) = esinx is:
f'' (x) = esinxcos2x - esinxsinx
Find all x in [0,2π] of possible inflection points.
Uhhhmmmmm...
also: our hint for this question is:
"keep in mind that the function g(t) = et is never zero for any real number t"
:bugeye: what is going on here?
Thanks in Advance:!)
Factor [tex]e^{sin(x)}[/tex] from both terms in f''(x) and then set the remaining factor to 0. As a hint in solving the resulting equation cos^2(x) = 1 - sin^2(x).
F"(t)= [itex]e^{sin(t)}(cos^2(x)- sin(x))[/itex] and, as your hint tells you, [itex]e^{sin(t)}[/itex] is never 0. In order to have F"(t)= [itex]e^{sin(t)}(cos^2(x)- sin(x))= 0[/itex] you must have [itex]cos^2(x)- sin(x)= 0[/itex].
Uhm ok so...
f''(x) = esinx (½(1+cos2x))-esinxsinx
f''(x) =esinx (½ + ½cos2x - sinx)
so what should i do now?
so
cos2x = sinx or (½+½cos2x) = sinx ?? is this what you mean?
okay my main problem is that i don't understand what the question is asking for what does the last part of the question mean the 'find all x in [0,2π] of possible inflection points'?
what am I trying to find here?
??No one has suggested that you convert [itex]cos^2(x)= (1/2)(1+ cos(2x))[/itex]. What has been suggested is that you solve [itex]cos^2(x)- sin(x)= 0[/itex]. Mark44 suggested you use [itex]cos^2(x)= 1- sin^2(x)[/itex] so that [itex]cos^2(x)- sin(x)= 0[/itex] becomes [itex]1- sin^2(x)- sin(x)= 0[/itex]. That is a quadratic equation in sin(x). If you let y= sin(x) you have [itex]y^2+ y- 1= 0[/itex]. Solve that that for y and then solve sin(x)= y for x.
OKAY so:
f'' (x) = esinx(cos2x - sinx)
let cos2x - sinx = 0
1-sin2(x) - sinx = 0
let y = sinx
y2 + y - 1 = 0
Quadratic Equation Gives 2 Answers:
0.6180
and
-1.6180 <-- DO NOT use because it is not in the interval in question
sin(x) = y
sin(x) = 0.6180
x = sin-1(0.6180)
x = 38.17
is that it for this problem?
Not quite.
You're correct to discard the value -1.6180, but for the other, you have found one value of x for which sin(x) = .6180. There are two values in the interval of interest, [0, 2pi]. Both values should be in radians, not degrees.
Mark44 said:
Not quite.
so ok since:
sin(x) = 0.6180
x = 0.6662 rad
so I drew my sin curve but...
ok so am I supposed to just for example do:
x = 0.6662 + π
No, that's not it. Think about what the graph of y = sin(x) looks like between 0 and 2pi. As a hint, sin(pi/6) = 1/2 (or sin(30 deg.) = 1/2). What's another value x, in radians, for which sin(x) = 1/2? It's not pi + pi/6.
oh ok I have to find the where the line
sinx = y = 0.6180 crosses with the curve y = sinx
that is two times in this interval once at the inverse of sin(0.6180) and ?
okay i can see it on my graph but how do i actually calculate this value of x?
With a calculator?
NoMoreExams said:
With a calculator?
lol omg *embarrassed* YES
Didn't know anyone got so excited about calculus
can you help me:redface: please
Help you with what? I thought your question has been answered
No...this question hasnt:
You would use your calculator and type in arcsin(.618)?
haha, yes I did taht but it only gives me the one value of x, but there are two intersections so there is another value of x that gives sin(x) = 0.6180
if you just do sin-1 (0.6180) = 0.6662 ---> only one value, i need 2 values
OK let's pick a simpler example. If you had to find sin(x) = 1/2 how would you figure out x?
sin-1(1/2) = x
lol sure, but if you didn't have a calculator, how would you figure that one out.
oh you got me:confused::redface: i don't know
You should go back and review trigonometry. It's on the unit circle.
come on help me out here (your name), lol ok fine soooo...
sinθ = y/r --> y=1 and r=2 using THE theorem x=sqrt3 ?
You can look the answer up on wikipedia, it's a common angle and it was already addressed in this thread I believe.
okay I am not sure what your getting at, I know that sin(π/6) = 1/2 and sin(5π/6) = 1/2
I'm trying to get you to remember how those values were determined. Sin(pi/6) = 1/2 is easy. So we know 30 degrees is what we need. Since we have sine, it's positive in 1st and 2nd quadrants. So in the first quadrant we have 30 degrees, in the 2nd we know our "line" must make a 30 degree angle with the horizontal which would be pi, so we did pi - pi/6 = 5pi/6
oh ok so my number is not 1/2 but 0.6180 so that is 38.17degrees
so the line must make a 38.2degree angle with the horizontal since pi is (180degrees)
180-38.2 = 141.2degrees ~2.46rad
is this the answer?
Well try plugging that into your calculator :)
  • · Replies 18 ·
