Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Engineering Systems & Design (http://www.physicsforums.com/forumdisplay.php?f=99)
-   -   F1 car design (http://www.physicsforums.com/showthread.php?t=288851)
Beaujolais Jan31-09 07:26 PM
F1 car design
Hi this is my first post here, I am just looking for some advice on designing a F1 model car. Like what the best possible shape for a Formula 1 car could be (Less drag and other factors which may effect its speed). The model car will be propelled forward by a Co2 Canister and will be and a straight track . It is only around 230mm in length and 50mm in width . To be designed on solidworks.
Thanks.
Cyrus Jan31-09 10:34 PM
Re: F1 car design
I think this would be the best shape:
http://www.blognroll.net/content/bin..._Mercedes-.jpg
turbo Jan31-09 10:38 PM
Re: F1 car design
wrong. The car is going to be propelled by a CO2 cartridge. Why would it need air intakes, and other stuff associated with ICE technology? That sucker has got to be light, lean, and sleek.
Beaujolais Feb1-09 07:15 AM
Re: F1 car design
Yea your right turbo those air intakes would slow it down soooo much . What about that same car but with the air intakes edited off or something? or would that effect the rest of the car's aerodynamics?
brewnog Feb1-09 01:58 PM
Re: F1 car design
F1 aerodynamics aren't designed to minimise drag for high speed, they're designed for optimum downforce for cornering, which greatly increases drag.
Beaujolais Feb1-09 03:10 PM
Re: F1 car design
What is the best possibly design for a F1 car with a front and rear spoiler powered by a Co2 canister on a straight track then?
brewnog Feb2-09 01:35 PM
Re: F1 car design
Well what are your objectives?
My design (given "CO2 canister power" and "straight track" as my only design constraints) would be a buggy made of balsa wood and wire, with enough wheels to hold onto the track to keep it straight. Aerodynamics wouldn't even feature except for some simple nozzle to direct the flow backwards.
Mech_Engineer Feb6-09 09:20 PM
Re: F1 car design
Ironically, an optimized model of an F1 car wouldn't necessarily have the same shape as a full-size F1 car either. The aerodynamic effects at work do not scale linearly with size, and neither does the speed the car will be traveling at. As was mentioned, an F1 car is also optimized for lots of downforce, to aid in cornering.
For a drag car going straight on track and propelled by a "jet" in the back, I suspect your optimum solution would be light; as light as you can possibly make it. As for shape, probably something close to a jet dragster would be best. Depending on the length of the race, and the speed achieved, it's possible the aerodynamics would even take a back-seat when compared to the overall weight of the vehicle.
http://www.superchevyshow.com/driver...empsey2006.jpg
tormund Mar9-09 02:29 PM
Re: F1 car design
Quote:
Quote by turbo-1 (Post 2057732)
the intakes would enable the air to go through instead of around the car, enabling there to be less drag, hence making it faster
minger Mar9-09 03:00 PM
Re: F1 car design
Quote:
Quote by tormund (Post 2109547)
The air will still have to go around whatever CO2 cartridge is pushing the car. In that case, its better if the air goes around the car rather than "through" the body, then split at the rear going around the cartridge.
turbo Mar9-09 03:16 PM
Re: F1 car design
Mech Engineers suggestion is just what the doctor ordered. Light, lean, and sleek. Wings, spoilers, air intakes, etc would all result in extra turbulence and drag.
Kbonga Mar27-09 09:48 AM
Re: F1 car design
You dont need all the down force of an F1 car. you are going in a striaght line. you need less weight as earlier stated.
mgb_phys Mar27-09 10:35 AM
Re: F1 car design
Quote:
Quote by brewnog (Post 2058391)
Cd for an F1 car is sometimes >1 depending on the circuit, twice as bad as a Hummer!
Danger Mar27-09 10:38 AM
Re: F1 car design
I just want to check as to whether the CO2 is being used as a rocket or running through some sort of turbine and gearbox to the axle.
If the former, then I would still recommend creating as much downforce as possible. Those suckers have one hell of a lot of energy. I remember once wedging one between the slats of a corn crib and shooting the cap off with a .22 rifle. The instant result was a cloud of ice crystals, and then I spotted the cartridge about 200 ft. in the air, climbing at over 60 and moving like greased bacon through a goose's a$$. It went at least a mile... probably more. Keeping something like that on the ground won't be easy.
Mech_Engineer Mar27-09 11:24 AM
Re: F1 car design
Quote:
Quote by Danger (Post 2135624)
You're correct tha model CO2 dragsters are hard to keep on the ground, but maximum downforce isn't really the solution. You need to pay close attention to the height of the CG of your car relative to the CO2 cartridge's nozzle. Also, longer cars are more stable at high speed.
Depending on what kind of track this thing is going on, you'll have to balance a trade-off between weight, length, and aerodynamic stability (you don't want to generate lift, esepecially in the front end). Most CO2 dragster tracks I've seen also have the car on a wire or string to keep it on the track, because it's basically impossible to keep them going straight otherwise...
Danger Mar27-09 12:17 PM
Re: F1 car design
Wow... it never occurred to me that someone has done this before. I thought that it was just an off-the-wall experiment. :redface:
Mech_Engineer Mar27-09 02:22 PM
Re: F1 car design
Quote:
Quote by Danger (Post 2135741)
I made a CO2 dragster in the Boy Scouts, but obviously didn't do much in the way of design optimization. They were pretty fun to watch because they usually crashed fantastically at the end of the track :biggrin:
See for yourself: http://en.wikipedia.org/wiki/CO2_dragster
Kbonga Mar27-09 04:20 PM
Re: F1 car design
I dont know much about these cars, but you may just need some kind of counter weight of the CO2 cartrage. I understand weight is a big factor so this might not be good advice.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
