Mass sliding down an inclined plane (True/False)
A block of mass M sliding down an inclined plane experiences acceleration that is dependent on the angle of the incline. The normal force acting on the block is not equal to its weight, as it acts perpendicular to the surface. The frictional force must be less than the gravitational component acting down the plane. Halving the block's mass does not affect its acceleration due to the cancellation of mass in the formula. The presence of friction is necessary for the block to accelerate rather than maintain constant velocity.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of forces acting on an inclined plane
  • Familiarity with trigonometric functions (sine and cosine)
  • Concept of friction and its role in motion
  • Study the effects of angle on acceleration in inclined planes
  • Learn about normal force calculations in various scenarios
  • Explore the relationship between mass, acceleration, and friction
  • Investigate the conditions for constant velocity on inclined planes
Physics students, educators, and anyone interested in understanding dynamics and forces on inclined planes.
FAJISTE
**Mass sliding down an inclined plane (True/False)
A block of mass M is sliding down an inclined plane and is accelerating. Which of the following statements are true?
The acceleration of the block is dependent upon the angle of the inclined plane
The normal force of the plane is equal to the weight of the block
The frictional force must be less than the component of Mg down the plane
If the block's mass were halved, its acceleration would not change
The surface must have some friction because the block is accelerating
F=ma
Fx=mgsinx
Fy=mgcosx
1.True, depending on how high or low the angle is, the acceleration will change accordingly.
2. False, normal force is perpendicular, weight is straight down.
3. True, the weight is the hypotenuse of the triangle, which is always the largest.
4. True, the masses cancel out when you get your formula
5. True? Not to sure about this one. I say true because otherwise it would be constant velocity? It could be false. It probably is lol.
Am I right? Wrong?
Think all are right, but maybe not the last one. What if there were NO friction for the last question...
Yup, last one was false. Thanks
  • · Replies 27 ·
11K
  • · Replies 19 ·
