How do I find the moment of inertia for a curve?
The discussion revolves around finding the moment of inertia for a curve that is revolved around an axis. Participants are exploring the application of integrals, particularly in the context of using cylindrical coordinates and the Theorems of Pappus, to compute the moment of inertia for various shapes.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to understand how to set up integrals for calculating moment of inertia, expressing confusion about the use of double and triple integrals. Some participants suggest using cylindrical coordinates and provide a volume element for integration. Others question how to apply these concepts to specific shapes like triangles or rectangles.
Participants are actively discussing the setup of integrals, with some guidance provided on using cylindrical coordinates. There is an ongoing exploration of how to interpret the radius in relation to the curve and the limits of integration. Multiple interpretations of the problem are being considered, particularly regarding the relationship between the curve and the axis of revolution.
There is mention of previous class instruction being limited, which may affect the understanding of the concepts discussed. The original poster expresses uncertainty about the application of the formulas and the physical interpretation of the variables involved.
rock.freak667
Say I am given some curve f(x,y) (revolved around some axis), how do I find the moment of inertia about an axis?
I know how to find the moment of inertia of things like a uniform rod, ring and sphere using
[tex]I=\int r^2 dm[/tex]
I believe I am supposed to to pick an elemental piece such that the revolved element is through the axis I want. But if I use I=[itex]\int[/itex]r2 dm, I don't get anywhere.
I've various places that I am to use a double integral or even a triple integral. But I don't know how to set these up to compute the moment of inertia.
Have you met up with the Theorems of Pappus yet?
Nope. All they did in class was how to get the moment of inertia of some figure (it escapes me what shape it was). But it was a triple integral, and they just put in the limits and some integrand (how they got it, I know not) and then just put the answer.
All right, then you will have to do something similar. Think in cylindrical coordinates, with the axis of revolution as the polar axis of the cylindrical coordinates. Let's suppose that your given curve is y = f(x). We want to use y as the maximum radius, and x as the z value in the cylindrical coordinate system, so the volume element is
dv = r dr dth dz
where
r is the radius to a point inside the volume, 0<=r<=f(z)
th is the angle theta that measures angle around the z axis, 0<=th<=2*pi
z is the original x value range
Then make your triple integration with all the proper limits and this should give you the volume.
dv = r dr dth dz
where
then I must still use the formula I=S r2 p dv (p=rho, S=integral)
what if I need to find the moment of inertia of a plane figure such as a triangle or rectangle?
That is a different problem, solved in a different way. Get through this one for now.
http://img23.imageshack.us/img23/1364/picwmz.jpg
I need to find the moment of inertia about the y-axis and in is really cm
So my integrals would be like this:
[tex]I_y= \pho \int_0 ^{0.03} \int_0 ^{2 \pi} \int_0 ^{0.03} r^3 dr d\theta dz[/tex]
In this problem, x is the radius, so solve the curve for x = f(y). Then use that as the upper limit of integration on r.
Then it should be:
[tex] I_y= \pho \int_0 ^{0.03} \int_0 ^{2 \pi} \int_0 ^{\frac{y^3}{9}} r^3 dr d\theta dz[/tex]
But I do not understand how x is the radius here if the curve shows that the x distance is not constant.Also why then would they give the distances 3cm and 3cm (vertically)?
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 16 ·
