Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Engineering, Comp Sci, & Technology Homework (http://www.physicsforums.com/forumdisplay.php?f=158)
-   -   Force from internal gear (http://www.physicsforums.com/showthread.php?t=309787)
ADunn Apr25-09 08:52 PM
I'm trying to determine the forces that an internal gear applies on a pinion. I can measure the angular velocity of the gear and any relevant dimensions but can only find force equations for gears with a single point of contact. Any guidance is greatly appreciated.
minger Apr28-09 12:55 PM
Re: Force from internal gear
The torque in from the input gear equals the torque out on the output gear. Using gear radii, you should be able to easily find the tangential forces.
Also, gears typically have single point contacts. Unless you have a contact ratio greater than 2, there will be times when you have single-point contact.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
