Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Engineering, Comp Sci, & Technology Homework (http://www.physicsforums.com/forumdisplay.php?f=158)
-   -   Help With Pseudo Coded Algorithm for The Diamond-Square Algorithm (http://www.physicsforums.com/showthread.php?t=318796)
quddusaliquddus Jun8-09 05:14 PM
I am trying to write a pseudocoded recursive algorithm.
Algorithm is located @: http://gameprogrammer.com/fractal.html#diamond
I am getting the ending wrong.
2. Relevant equations
Do diamond step.
Do square step.
Reduce random number range.
Call myself four times.
[From link above]
3. The attempt at a solution
My attempt:
Quote:
Function DiamondSquare(PointsColl as Points3DCollection) Points3DCollection
'Variables
Dim SquareSize as Integer = PointColl.Length
if SquareSize > 1 then
Dim RandomRange as Integer = 5
Dim Rand as Random(1234)
'Diamond Step
Dim SqrCorner1 as Integer = 1
Dim SqrCorner2 as Integer = SquareSize
Dim SqrCorner3 as Integer = (SquareSize - 1) * SquareSize +1
Dim SqrCorner4 as Integer = SquareSize * SquareSize
Dim SqrCentre as Integer = (SquareSize / 2) ^ 2
'Assign Diamond Centre value
SqrCentreValue = PointsColl(SqrCorner1) + PointsColl(SqrCorner2) + PointsColl(SqrCorner3) + PointsColl(SqrCorner4) + Rand.Next(0, RandomRange)
PointsColl(SqrCentre) = New Point3D(PointsColl(SqrCentre).X, SqrCentreValue, PointsColl(SqrCentre).Z)
'Square Step
Dim DiamCorner1 as Integer = SquareSize/2
Dim DiamCorner2 as Integer = DiamCorner1 + SquareSize
Dim DiamCorner3 as Integer = DiamCorner2 + SquareSize
Dim DiamCorner4 as Integer = DiamCorner3 + SquareSize
'Assign Diamond Centre Values to Diamond Corners
PointsColl(DiamondCorner1) = SqrCentreValue
PointsColl(DiamondCorner2) = SqrCentreValue
PointsColl(DiamondCorner3) = SqrCentreValue
PointsColl(DiamondCorner4) = SqrCentreValue
'Split into Four Squares
Dim Square1 as Point3DCollection((SquareSize/2)-1)
Dim Square2 as Point3DCollection((SquareSize/2)-1)
Dim Square3 as Point3DCollection((SquareSize/2)-1)
Dim Square4 as Point3DCollection((SquareSize/2)-1)
'Populate Square 1
Dim Index as integer = 0
For i = 0 to (SquareSize / 2) - 1
For j = 0 to (SquareSize / 2) - 1
Square1(Index) = PointsColl((i * SquareSize) + j)
Index = Index + 1
next
next
'Populate Square 2
For j = 0 to (SquareSize / 2) -1
Square2(Index) = PointsColl((i * SquareSize) + j + (SquareSize / 2))
Index = Index + 1
next
next
'Populate Square 3
Square3(Index) = PointsColl(((i + SquareSize / 2)* SquareSize) + j)
Index = Index + 1
next
next
'Populate Square 4
Square4(Index) = PointsColl(((i + SquareSize / 2) * SquareSize) + j + (SquareSize / 2))
Index = Index + 1
next
next
'Call function for each Quarter Square
Dim Square1 as Point3DCollection = DiamondSquare(Square1)
Dim Square2 as Point3DCollection = DiamondSquare(Square2)
Dim Square3 as Point3DCollection = DiamondSquare(Square3)
Dim Square4 as Point3DCollection = DiamondSquare(Square4)
Else
'Replace Square Values in PointsColl
'Retrieve Square1
Dim index as integer = 0
for i = 0 to (SquareSize / 2) - 1
for j = 0 to (SquareSize / 2) - 1
PointsColl((i * SquareSize) + j) = Square1(Index)
Index = Index + 1
next
next
'Retrieve Square2
PointsColl((i * SquareSize) + j + (SquareSize / 2)) = Square1(Index)
next
next
'Retrieve Square3
PointsColl(((i + SquareSize / 2)* SquareSize) + j) = Square1(Index)
next
next
'Retrieve Square4
PointsColl(((i + SquareSize / 2) * SquareSize) + j + (SquareSize / 2)) = Square1(Index)
next
next
End Function
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
