Square matrix where the coefficients of the diagonal are 1
  • Context: Graduate
  • Thread starter Thread starter ario
    Coefficients Matrix
The discussion centers on a square matrix with diagonal coefficients equal to 1 and off-diagonal coefficients that are very small (approximately 10^-6). The determinant of such a matrix is always 1, leading to the challenge of finding roots of the determinant function, which is constant. Participants suggest examining the matrix's structure for patterns and considering alternative methods for root-finding, especially for large matrices, where numerical methods may be necessary.
  • Understanding of matrix theory and determinants
  • Familiarity with complex variables
  • Knowledge of numerical methods for root-finding
  • Experience with matrix manipulation in computational software
  • Explore matrix perturbation theory to analyze small coefficient effects
  • Learn about numerical root-finding techniques such as Newton's method
  • Investigate the use of symbolic computation tools like MATLAB or Mathematica
  • Study the implications of matrix size on determinant calculations
Mathematicians, data scientists, and engineers dealing with matrix computations, particularly those focused on complex variables and numerical analysis.
ario
Hallo everybody.
I have a square matrix where the coefficients of the diagonal are 1, while the others are very small (say 10^-6). Of course the determinant of this matrix will be always one.
This is my problem:
the coefficients are functions of a variable (w, complex variable). So, the determinant of the matrix will be a function of w. I need to find the solutions, the roots w of this function (the determinant=0), but since the diagonal is made of 1 and the other coeffs are very small, this function will be constant and equal to 1.
How can I avoid this problem...extracting the diagonal...
I tried to normalize the other small coefficients using new variables but they still are very small.
Thank you for your help,
Ario
Being small in abs value and being zero aren't the same thing. also what is the size of the matrix? if it is a 10**6 by 10**6 matrix then the small entries may contribute significantly to the determinant. other than this it appears you're just using numbers that are too small for your computer to handle.
Hi Ario,
Thank you for sharing your problem with us. It seems like you are trying to solve for the roots of a function that is constant and equal to 1. In this case, there are no solutions since the function is always equal to 1, regardless of the value of w.
One way to avoid this problem is to take a closer look at the matrix and its coefficients. Is there a specific pattern or structure to the coefficients that can help you determine the roots? Can you use any other methods or techniques to solve for the roots instead of relying on the determinant? Additionally, if the matrix is large, you can try using a computer program or calculator to help you find the roots more efficiently.
I hope this helps and good luck with your problem-solving!
  • · Replies 33 ·
