12v DC motor precise stopping point?
The discussion focuses on controlling a 12v DC motor for a motorcycle kickstand using microswitches. By mounting normally-closed microswitches on the motorcycle frame, the motor can be programmed to automatically shut off when the kickstand is fully extended or retracted. This method ensures precise stopping points for both movements, enhancing safety and functionality. The solution involves integrating the microswitches into the motor's extension and retraction circuits.
  • Understanding of 12v DC motor operation
  • Basic knowledge of electrical circuits
  • Familiarity with normally-closed microswitches
  • Experience with wiring and circuit integration
  • Research wiring diagrams for integrating microswitches with DC motors
  • Learn about motor control circuits for precise stopping points
  • Explore safety mechanisms for automotive electrical systems
  • Investigate alternative motor control methods, such as PWM (Pulse Width Modulation)
Motorcycle enthusiasts, electrical engineers, hobbyists working on automated systems, and anyone interested in enhancing motor control for mechanical applications.
Hoovy
Lets say I want to move a kick stand on a motorcycle by use of a motor. Hooked up to the battery and a button on the handle bar. Is there a way of controlling the motor so it will automatically shut off when the kick stand has swung down all the way? Also when it has swung back up?
Thanks, Hoovy
Welcome to PF, Hoovy.
It's really simple. Just mount a couple of normally-closed microswitches on the frame, wired into both the extension and retraction circuits. When the stand goes down, it trips the switch wired into the extension lead. That still leaves the other side active. When it goes up, it trips the retraction shut-off.
Ahhh I see said the blind man. Thanks Danger
  • · Replies 24 ·
  • · Replies 68 ·
16K
  • · Replies 26 ·
10K
