Calculating upright loads to base plate
  • Thread starter Thread starter 3thanol
    Base Plate
The discussion revolves around calculating the loads transmitted to a base plate from an upright structure subjected to a horizontal force. Participants explore the mechanics of load distribution among fixing points and the implications of different assumptions regarding the base plate's attachment to the foundation. The scope includes technical reasoning and mathematical analysis related to structural engineering.
  • One participant describes a scenario with a 10 kN horizontal force applied at the top of a 3 m upright, seeking to understand the load transmitted to the base plate and its fixings.
  • Another participant calculates that the 10 kN load produces a 30 kN-m couple at the base plate and discusses the distribution of tensile and compressive forces among the bolts based on their configuration.
  • A different participant questions the definition of the fulcrum point and suggests that the pivot point should be at the edge of the base plate, proposing a different method for calculating the load on the fixing points.
  • Further clarification is provided regarding the assumptions made about the bolts being double nutted and how this affects the load distribution, contrasting it with a scenario where the base plate rests directly on concrete.
  • Participants discuss the shear load distribution among the bolts, with one participant stating it is assumed to be equally distributed.
Participants express differing views on the appropriate fulcrum point and the resulting load calculations, indicating that multiple competing models and assumptions are present in the discussion. No consensus is reached on the best approach to calculate the loads.
Participants highlight various assumptions regarding the configuration of the base plate and bolts, which may significantly affect the calculations. The discussion includes considerations of different loading scenarios and their implications for structural integrity.
3thanol
Hello PF I hope you can give me some guidance. This is something that I am getting more and more on my desk, to be honest I don't understand it enough to give an answer. I have searched the net looking for an answer but can only find details on fulcrum points class 1,2 & 3 which does not seem to be what I receive. Maybe I am overlooking or missing something. I don't claim to be brilliant at maths but this is really bugging me, I am sure it has a relatively simple formula.
Anyway I have attached a picture of a quick drawing I done. I have i.e. square base plate with 4 fixings points and an upright in the centre x high in this example 3mtrs high. The upright has a force of 10kN applied pushing it directly horizontal at the very top.
What is the load transmitted to the base plate and ultimately how can I then workout the load at the relative fixings points, I understand the 2 fixings opposite to the direction of force will be taking most Tensile load but am at a lose to know where to really start.
I would hazard a guess that the load is transmitted to the base plate and would become a value of xxxKNm and would pivot around the fulcrum, lifting the opposite side which would then become a tensile load again, with maybe slight shear given the slight oblique motion possibly?
Any help would be greatly appreciated, Thank you.
I'm not sure of what you mean by the fulcrum point. The 10 kN load applied 3 m from the base produces a 30 kN-m couple at the base plate. But what is the base plate attached to? If it were a plate bolted at the 4 locations shown (0.7m spacing) and double nutted (one nut above and one nut below the base plate) to a foundation, them 2 of the bolts would be in tension, and the other 2 in compression. The tensile force in the two bolts in tension would be 30/0.7) = 43 kN or about 21.5 kN/bolt. The compressive force in each of the other 2 bolts would have the same magnitude. And each bolt would see 2.5 kN shear. But your question needs clarification.
Thanks Phantomjay. The Base plate is steel which is fixed to concrete with bolts, the fulcrum or pivot point, I would have thought is the edge of the base plate where the application would pivot around should it be toppled over.
Would the measurement not be from the back fixing centres to that edge 0.85 and if the case would this take the other two bolts out of compression and useful and a measure of 0.15 be obtainable, which could contribute to clamp the whole thing down.
so you would have 30/0.85/2 = 17.62kN per back fixing 30/0.15/2 = 100kN per front fixings. then would have to work out what percentage each bolt is clamping.
Also how did you come to that shear load if I may ask.
Many thanks.
I assumed double nutted bolts (the lower nuts under the base plate are usually called leveling nuts); with this assumption, the base plate sits on the nuts, not the concrete, and bolt forces are determined as I noted, using the center of the base plate as the neutral axis, to yield the 21.5 kN tension in each of the 2 tension side bolts, and 21.5 kN compression in each of the 2 compression side bolts.
If one were to assume that the base plate is directly resting on the concrete, and bolted to the concrete with just single nuts on the bolts above the plate, the analysis woul be a bit different, as you'd have tensile forces on two of the bolts, and a triangular distribution of compressive stress acting on the other side, from the concrete bearing stresses. Such analysis for this case would be simuilar to reinforced concrete design with tension in the rebar and compression in the concrete, with the compressive force in the bolts ignored. The first method yields a conservative result if this is the case. Resist the temptation to use the far edge of the plate as the pivot for this latter case; all bolts will not be in tension.
The shear load is assumed equally distributed amongst each bolt (10 kN/4 = 2.5 kN).
  • · Replies 17 ·
26K
16K
