Where can i find a US standard AC err transformer or something?
The discussion revolves around finding a suitable device to limit the RMS voltage for a US standard AC vent fan, with a focus on various methods to reduce the fan speed without overheating components. Participants explore different devices, including dimmer switches, light bulbs, and transformers, while considering the types of motors involved.
  • One participant suggests using a dimmer switch specifically designed for ceiling fans, noting compatibility issues with induction motors.
  • Another participant questions the function of a dimmer switch and discusses its mechanism involving a triac that chops the voltage sine wave.
  • There is a proposal to use a 40-watt lamp in series with the fan as a method to slow it down, emphasizing the need for experimentation with lamp wattage.
  • Some participants mention that shaded pole motors are likely used in domestic vent fans and discuss the potential for using ceiling fan controllers with switched capacitors.
  • Concerns are raised about the sparking caused by triac-based dimmers and the noise issues associated with series inductors.
  • One participant shares positive experiences using the light bulb method with shaded pole motors, suggesting it as a reliable solution.
  • Discussion includes technical details about shaded pole motors, including their construction and operational characteristics.
Participants express multiple competing views on the best method to limit the voltage and control the fan speed, with no consensus reached on a single solution. Various approaches are debated, and some participants share personal experiences while others raise concerns about specific methods.
Participants note the importance of understanding the type of motor used in the fan, as different motors may respond differently to the proposed solutions. There are also mentions of potential risks and limitations associated with each method discussed.
chopficaro
i have a vent that is too fast and too loud, and it runs off of US standard ac. i was wondering if there is a (good brand name) device that could limit the rms voltage. i don't want a pair of resistors, that would heat up real fast.
i need the voltage cut in half, approximately.
an analog device would be fine, but it would be even better if i could hook it up to the usb! then i bet i could do all sorts of cool things with all of my household appliances, although my budget is super strict.
A good choice is the dimmer switch used specifically for ceiling fans. Do not use it with an induction motor, only shaded pole motors or universal (ac/dc) motors.
Bob S
uh oh, well i see a HUGE inductor in there. what does a dimmer switch do? if it just alters the voltage then all of the impedances would be the same yes? does a dimmer switch apply a certain voltage to a transistor to allow current to reach the bulb?
im sorry I am a dc guy mostly, i don't know how transistors and things act under ac
It has a triac in it that is triggered part way through every voltage sine wave, so the front end of each half cycle is chopped off. Be sure to use the one for motors and not lights. If you want a fixed inductor, you could use a ballast for fluorescent lights. Be sure to check the current rating. Be sure the motor is not an induction motor. I have a 1 KVA Variac that I use for adjusting voltages, but they are very expensive. Yoou could use a step-down transformer, but they are expensive too. What current does the motor draw?
Bob S
A cheap source of high powered resistors is 110 volt lamps.
If you put a 40 watt lamp in series with your fan it will slow it down with no risk to the fan or the lamp. The lamp wattage would have to be determined by experiment but you would have it in a socket so you can try different wattage lamps.
Wire it safely with insulated connections and allow room around the lamp for cooling.
As long as the motor is NOT an induction motor. Induction motors want to run at about 1200, 1800, or 3600 RPM (in the United States), independent of input voltage. Single phase induction motors draw a high surge current when they start, and the series lamp may limit adequate starting current.
What kind of fan motor is it?
Bob S
For a domestic vent fan, I'd guess it is a shaded pole motor.
There is also a type of ceiling fan controller that uses switched capacitors. This would be a neat compact way of doing it. Without knowing more about the fan, it would be risky to suggest this, though, as they are not cheap.
Triac ones as in lamp dimmers cause sparking in the fan windings and series inductor ones seem to go noisy and start rattling after a while.
I'd still suggest a series lamp as a cheap solution. Starting torque is not a problem for a fan.
I've used the light bulb method with shaded pole motors and it works quite nicely. You can also put a switch in parallel with the light bulb and have a 2-speed fan. I've also use a lamp dimmer but I prefer the light bulb method (if it's feasible).
A shaded pole motor does look like a big inductor. Usually the rotating part of it is open and not very conspicuous but there is a large field coil at one side of the actual rotating part.
Even less conspicuous is a single shorted turn of copper wire around one part of the core. This actually starts the motor turning and keeps it turning.
Yes, I've used lamps for this sort of thing and they work fine. If it doesn't, well you haven't lost much by trying.
vk6kro said:
Even less conspicuous is a single shorted turn of copper wire around one part of the core. This actually starts the motor turning and keeps it turning..
I have seen shaded pole motors with 4 shaded poles (speed ~ 1600 RPM).
Bob S
I've never seen more than one shorted turn, but interesting that some motors use more.
There must be more of these motors than any other kind, but they always look like a piece of junk. Yet they just keep on turning for year after year.
Stove hoods with variable speed vent fans on are the market. What's the application?
Shaded pole motors are the least expensive ac motor to manufacture. The copper rings do very little at near-synchronous RPM, but they provide necessary starting torque. The copper rings retard the B field relative to the main field by a few degrees, but the rings also attenuate the amplitude (~1 neper per radian). The real-part attenuation means heat, so the motor gets hot. But they run a long time, especially if they have ball bearings rather than sleeve bearings.
Bob S
  • · Replies 18 ·
