Calculating the Forces on a Charged Particle in an Electric and Magnetic Field
The discussion revolves around calculating the forces acting on a charged dust particle in the presence of both electric and magnetic fields. The particle has a negative charge and is moving vertically downwards while subjected to a horizontal magnetic field and a vertical electric field.
  • Mixed
  • Participants explore the calculation of the magnetic force using the formula F=|q|vB, discussing the direction of the force based on the right-hand rule and the charge of the particle.
  • There is an attempt to relate the electric field strength to the electric force, with some confusion about the appropriate equations to use.
  • Questions arise regarding the addition of forces, specifically whether to sum the magnitudes directly or use the Pythagorean theorem based on the directions of the forces.
Participants are actively engaging with the problem, providing calculations for the forces and discussing their directions. Some guidance has been offered regarding the application of the right-hand rule and the relationship between electric force and electric field. Multiple interpretations of the forces and their resultant are being explored, but no consensus has been reached on the final net force calculation.
There is some confusion regarding the directions of the forces and the application of the right-hand rule, as well as the treatment of negative magnitudes in force calculations. Participants are working within the constraints of the problem statement and the equations provided.
quik
A magnet produces a 0.40 T field between its poles, directed horizontally to the east. A dust particle with charge q = -8.0×10^-18 C is moving vertically downwards with a speed of 0.30 cm/s in this field. Whilst it is in the magnetic field, the dust particle is also in an electric field of strength 1.00×10^-2 V/m pointing to the north.
(a) What is the magnitude and direction of the magnetic force on the dust particle?
(b) What is the magnitude and direction of the electric force on the dust particle?
(c) What is the magnitude of the net force on the dust particle?
F=|q|vB
F=(k|q1q2|) / r^2
B=E/V
a) Magnitude: F=|q|vB = (-8 x 10^-18 C)(-0.003 m/s)(0.4 T) = 9.6 x 10^-21 N
Direction: Since the velocity is south and the force must be perpendicular to the velocity, the force must lie in a plane perpendicular to the north/south axis.
b) I know it has to do with "1.00 x 10^-2 V/m" but all I could do with it was:
Magnitude: B=E/V --> (1.00 x 10^-2 V/m) / (0.003 m/s) = 3.3(repeating) T
Direction: North
c) Would the net force be the sum of answers "a" and "b" or would it be:
Net force = sqrt(a^2 + b^2)
a: being the force in a)
b: being the force in b)
Thank-you.
Hi quik,
F=|q|vB
F=(k|q1q2|) / r^2
B=E/V
Okay; now you can use the right hand rule and the charge of the particle to determine whether the force is to the north or the south. What do you get?
Magnitude: B=E/V
No, I don't believe this equation applies here. You need the relationship between electric force and electric field. What equation is that?
Direction: North
If the two forces to be added are parallel or anti-parallel, you will either add or subtract the magnitudes to find the total magnitude; if the forces are perpendicular, you use the pythagorean theorem to find the magnitude.
Thank-you.
Hello alphysicist, thanks for replying.
I'm a little confused here, I thought:
+z axis = out of screen
+x axis = B
-y axis = v
But if the force is either North or South, since the velocity is going south, wouldn't it be north?
E = F/q --> F = Eq --> (1.00 x 10^-2 V/m)(-8 x 10^-18 C) = -8 x 10^-20 N
Would the net force be: (9.6 x 10^-21 N) + (-8 x 10^-20 N) = -7.04 x 10^-20 N ..?
Thanks again
+x axis = B
-y axis = v
This answer is correct, but it seems like you might be misunderstanding. The velocity is not to the south, it is vertically downwards. The force is perpendicular to both the velocity and the magnetic field (which narrows the choices down to two directions) and the right hand rule picks which one of those directions is correct.
That looks right (but I think you want to write it explicitly as a magnitude and direction).
That looks right (but it is not quite in the form of a magnitude yet).
Thanks again
Magnitude: 9.6 x 10^-21 N
Direction: North
Magnitude: -8 x 10^-20 N
Direction: South
[/QUOTE]
Magnitude: 7.04 x 10^-20 N
Direction: South
Direction: North
Direction: South
Direction: South
Magnitudes cannot be negative, but once you fix that everything looks right to me.
9K
  • · Replies 31 ·
