Why are spool systems and increased stages used in compressors for axial flow?
The discussion revolves around the use of spool systems (twin and triple spools) and the necessity of increasing the number of stages in compressors, particularly in axial flow compressors. Participants explore the implications of pressure ratios, efficiency, and design considerations in jet engines and compressors.
  • Some participants question the rationale behind using multiple spools and increasing compressor stages, suggesting that a basic understanding of jet engines might clarify the issue.
  • One participant notes that axial compressors have limitations on the pressure ratio they can achieve, necessitating more stages for higher pressure ratios.
  • There is a discussion about whether the limitations are due to physical laws or design optimizations that avoid the need for complex gearing systems.
  • Some participants highlight that compressors operate against an adverse pressure gradient, which restricts the delta P across a stage.
  • It is mentioned that while high stage differential pressures can be designed, they tend to be inefficient, particularly in axial machines.
  • One participant points out that jet engines with axial compressors typically have more compressor stages than turbine stages, prompting questions about the reasons for this design choice.
  • Concerns are raised about the efficiency of achieving high compression ratios with fewer stages, with references to ramjets and their operational efficiency at different speeds.
  • Participants agree that while achieving high compression with a single stage is theoretically possible, it is impractical and inefficient compared to using multiple stages.
Participants express differing views on the efficiency and practicality of using multiple stages versus fewer stages with higher pressure differentials. There is no consensus on the optimal design approach, and the discussion remains unresolved regarding the best methods for achieving desired compression ratios.
Limitations include the dependence on specific design parameters and the unresolved nature of the efficiency trade-offs between different compressor configurations.
anvesh111
why the spools(twin spool,triple spool) are used in compressors,why the stages in compressor must be increased
I think a very basic google search on jet engines would provide you with this answer.
Your question doesn't make a whole lot of sense to me in the current form Can you restate it? It appears that you are asking why if you have multiple spool engines must the number of compressor stages increase. Is this correct?
i mean y do we need them
Rather than just have say one 20:1 pressure ratio stage?
Compressors, especially axial compressors are very limited as to the pressure ratio across them allowed. That means more stages required for a higher required pressure ratio.
By "allowed," I take it to mean you're referring to what the laws of physics allow? Or is it simply a case design optimization, whereby obtaining the same, final compression ratio via multi-stage axial compression does not require planetary gearing or substantially greater weight or strength of materials than would a design with fewer stages?
I mean allowed in that compressors are constantly working against an adverse pressure gradient which places a lot of limitations on what kind of delta P across a stage you can have. Has anyone ever noticed that all jet engines (with axial compressors) have a much larger number of compressor stages than the turbine?
You can design for a very high stage differential pressure, if you want. It's just terribly inefficient. :)
Yes. Why is that, Fred?
Not in an axial machine. You can with a radial/centrif if you want.
One word answer: separation.
Yes, http://en.wikipedia.org/wiki/Axial_compressor#Spools". As I said, they're simply much less efficient.
Separation occurs when turbines designed for a one pressure differential encounter a significantly greater pressure differential. It's a consequence of the design, as efficiency is highest when operated closest to the stall line.
Turbines with fewer stages and specifically designed for higher per stage pressure differentials do not experience separation within their design parameters. However, as I've mentioned, they're significantly less efficient than turbines designed for optimal efficiency, and which, as a consequence of their design, have more stages.
In short, it's entirely doable. It's simply not practical.
You're right. What do I know.
As an engine R&D guy, you know a great deal, Fred. This was simply a matter of extrapolating from existing design, in which case you were correct, vs considering a possible, but far less efficient, and therefore impractical design, for the concept mentioned by anvesh111 and minger.
Whoa whoa, apparently your sarcasto-meter didn't pick me up properly.
We do centrifugal compressors, but I know enough about axial systems to know that a 20:1 pressure ratio (for example) on a 5' fan blade is going to cause some issues.
Absolutely. As I said, it's not impossible. Merely grossly inefficient, and therefore impractical.
A similar, and familiar approach would involve a ramjet. Below Mach 0.5, they have almost zero thrust due to poor compression ratios, and below 600 kts, they're grossly inefficient. Between Mach 2 and 4, however, they'll outperform any turbojet.
The issue is one of compression. In a turbojet, we obtain efficiency by using multiple compression stages. A ramjet achieves efficiency by means of high mach to achieve that compression.
In a one-stage design, achieving a 20:1 compression ratio is "easy": just increase the velocity. When we do so, however, we find that achieving that high of a compression ratio requires a mach turbine (airflow over the turbines is mach), which introduces all kinds of wonderful problems.
Grossly inefficient. Very impractical.
But possible.
Again, we do not use multiple stages because achieving high compression with one stage is impossible. We do so because using multiple stages is much more efficient.
But possible.
yeah..i agree with you...thanks
But possible.
It is grossly apparent that you have never even seen a compressor in real life. I would suggest you read Hill and Peterson. You have linked to it. Try reading it especially section on axial compressors.
Gee, Fred, I must have missed 'em sitting out there on the wings as I tootled along through the sky. I always wondered what the throttle body was connected to... Thanks for clearing that up!
I'm a retired USAF officer with 2,400+ flight hours and an aero engineering degree from Virginia Tech.
You have yourself a nice day! :biggrin:
During those 2,400+ hours, were you designing jet engines? That is not to say we don't appreciate your service or your piloting knowledge, but please do not think that means you outclass Fred in jet engine design - it's a bit rude, to say the least.
https://www.physicsforums.com/showpost.php?p=2509216&postcount=13"I had actually acknowledged Fred's expertise. However, I also pointed out his entering assumption was limited to modern jet engines, designed for their overall efficiency, rather than expanded to consider the possibility (not the practicality) of the OP's question.
Regardless of Fred's credentials, he continues to dodge the issue while resting on laurels. To top it off, https://www.physicsforums.com/showpost.php?p=2512960&postcount=17", was rude and demeaning.
Fred can fend for himself, Cyrus. Whether he chooses to admit his error on the possibility vs practicality issue or not is up to him.
To bring another discipline in here, I'm not so sure a single spool would be possible mechanically. Problems arise as it is seeing pressure ratios in the teen range. That's a lot of force to put on the blade roots...
Again, it's possible, not practical (efficient). Obviously the blades of such an engine would have to be far more sturdy than on typical multi-stage compressors.
As for pressure ratio concerns, compare water, with it's density 1000 kg/m^3 density, and air, with it's sea-level, 20 deg C density of 1.2 kg/m^3 (more than 800 times greater). Yet we use water turbines all the time which handle stresses far exceeding that of a hypothetical single-stage air compressor.
Turbine blade strength isn't an issue, as they can be designed to be as strong as would be required.
From what I understand, reaction water turbines are typically only used in low head appliactions. I doubt they rotate anywhere near the speed that gas turbines do either.
I could fly by flapping my arms if I really wanted to. It would be very practical or efficient, but it could work.
Due to the momentum and viscosity of water, they do not need to.
Well this is a rather inane remark. Since you chose not to address the science/physics/engineering issue directly, I'll respond in kind: Good luck, but please don't overtrust your theory launch yourself off a cliff!
I'm flummoxed by your, Fred's, and others' errant belief that I am in any way proposing single-stage designs, particularly given my oft-repeated "possible, but not practical" mantra.
However, I am equally opposed to the hip-shooting "nope, can't be done" engineering nonsense that's been shoveled into this thread. What part of "possible, but not practical" are you and others failing to understand? Are you errantly believing I'm proposing single-stage designs?
Fess up!
From what I read, no one is asserting that one is proposing a single-stage compressure design with a high compression ratio. However, I believe one asserted that it is possible. Please provide an example of such an axial compressor, or failing that, please provide the equation for such a compressor.
Aircraft compressor stage compressor ratios might go to 4 or 5:1, but in the example cited earlier (http://en.wikipedia.org/wiki/Axial_compressor#Spools), the spool engines still have multiple stages, each with a compression ratio ~2:1. The wikipedia article is a bit misleading, because the RB.211 series is a three spool design (first run in Aug 1968). The RB.211-22 has a Single-shaft fan, 7-stage i-p compressor, 6-state h-p compressor, single-stage h-p and i-p, three-stage l-p turbine. Later designs in the series have a 6-stage i-p compressor. The total compression ratio is ~27:1. This is the point that FredGarvin was making.
http://en.wikipedia.org/wiki/Rolls-Royce_RB.211#RB211-22_series_2
http://www.flightglobal.com/pdfarchive/view/1969/1969%20-%201205.html
http://www.flightglobal.com/pdfarchive/view/1968/1968%20-%200493.html
I'm not so sure it is "easy". Please provide an example or the equations for an axial compressor stage.
There are numerous design constraints such at the blade tip speed and the speed of sound in the compressed air. The back pressure on a single stage with a compression ratio of 20:1 would be enormous and the rotation of the flow would seem to be problematic.
At which point, it is no longer a reaction turbine, it's an impulse turbine. They can use high head application, but like you said, you're using water momentum, not pressure to drive the blades. Because the wheel is spinning at 1/2 speed of the water jet, the actual force on the blades is not astonomical.
Simply saying "It can be done" doesn't either.
There's a big difference between not practical and not doable. There is reason behind one. It's not practical to drive a Hummer. However, if I have the money to do so and feel the need to look cool, why the hell not?
Could there be reason for a single-stage axial machine like you're describing? Sure, perhaps there are packaging concerns, maybe a single-stage can cost less than multi for a limited life application. However, if one of our customers came to us and asked for such a machine, we would respecfully decline, and not because it's not practical.
Well, in all honesty, we'd probably take the cabbage and then just not deliver (either on time or meeting goals). You know, the usual.
At 280 psi, it would have to be driven beyond mach. I never claimed one was ever designed, much less built. I merely stated it was possible.
Please demonstrate that it is possible, or at least provide the equation for the compression ratio of a single compressor stage for an axial flow.
(Sigh), it's beyond my dusty, 25-year-old degree. But it wasn't beyond the talents of my propulsion instructor who used it as an example of what's possible, but not practical.
  • · Replies 30 ·
  • · Replies 62 ·
31K
