Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Introductory Physics Homework (http://www.physicsforums.com/forumdisplay.php?f=153)
-   -   Manipulating inverse square graph into straight line graph (http://www.physicsforums.com/showthread.php?t=369832)
sync303 Jan15-10 11:20 AM
manipulating inverse square graph into straight line graph
In the course of performing several trials I determined that if you have 2 charged metal spheres (with the same amount of charge on them) and they are both positively charged, then the force of repulsion between them is changed by 1/4 each time you double the distance between them.
This experiment no doubt sounds very familiar as it has been done many times before.
I collected my data (16N@1.0cm, 4N@2.0cm, 1N@4.0cm, and 0.25N@8.0cm) and graphed it and of course I end up with a classic looking descending, concave looking graph which is the inverse square graph, I think.
2. Relevant equations
Now I have been puzzling over this for quite a while and even asked my boss and some co-workers to help and even together we can not figure it out - the question is:
"manipulate the data so that the graph is a straight line graph"
3. The attempt at a solution
I have tried doubling the charge, halving the distance, square rooting the distance, etc.
It always seems to end up with the same shape.
I think I might be missing the fundamental lesson here. Hopefully someone here can offer some insight.
mgb_phys Jan15-10 11:35 AM
Re: manipulating inverse square graph into straight line graph
You have a relationship that is force = some_factor/distance^2
And a straight line is y=mx + c
So you need to put it into this form.
y (ie. force) = m x (ie. 1/r^2 )
sync303 Jan15-10 12:07 PM
Quote:
Quote by mgb_phys (Post 2533007)
Thank you very much - I knew it was something fundamental.
I have been out of school for several years and am taking a course to upgrade and the formula for the graph of a line is something I have completely forgotten!
So I need to manipulate my F=kq/r^2 into a form that matches y=mx + c?
I will make an attempt to do so.
mgb_phys Jan15-10 02:01 PM
Quote:
Quote by sync303 (Post 2533045)
Yes just plot force against 1/r^2
sync303 Jan15-10 04:02 PM
Quote:
Quote by mgb_phys (Post 2533189)
Ok, I am still struggling with this.
If i used y=mx or in this case F=m(1/r^2) I am going to get the same answers am I not?
I can't see the difference between F=m/r^2 and F=m(1/r^2) where m is equal to kq.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
