Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Mechanical Engineering (http://www.physicsforums.com/forumdisplay.php?f=101)
-   -   Maximum temperature reached by a reciprocating compressor (http://www.physicsforums.com/showthread.php?t=374626)
dE_logics Feb2-10 03:05 AM
What's the general temperature of reciprocating compressors which are applied in Refrigerators and ACs?
It will be good if you give me the temperature of the air which gets compressed...just need a rough idea.
Thanks.
stewartcs Feb2-10 11:14 AM
Re: Maximum temperature reached by a reciprocating compressor
Quote:
Quote by dE_logics (Post 2559587)
Thanks.
Many reciprocating HPAC's are multistage compressors so the temp will depend on the stage of compression. For example, the final stage in a particular 3000 psi HPAC is 311 deg. F (with seawater cooling) per my spec. sheet.
It depends on the design though...they are all different.
CS
dE_logics Feb2-10 12:22 PM
Thanks for the info.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
