Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Computers (http://www.physicsforums.com/forumdisplay.php?f=190)
-   -   A serious question about CPU/GPU bottlenecks. (http://www.physicsforums.com/showthread.php?t=387306)
The_Absolute Mar17-10 01:06 AM
At the end of this month, I am building a gaming desktop computer with the following specifications. I was told that the ONLY CPU capable of not having any bottleneck with the Radeon HD 5xxx series is a Core i7 @ 4.5 GHz. How badly will a Phenom II X4 965 BE @3.4 GHz bottleneck a single Radeon HD 5870? Will the ability of that GPU be severely limited limited by that bottleneck? Do I have to spend another $1,000 to buy a Core i7 rig with an X58 motherboard and water cooling after trying to get it to that ludicrous speed?
Off topic, I heard that the first revision of the Sapphire HD 5870 has been discontinued, but is there any way of getting a hold of One anymore? The 2nd revision runs about 20 *C hotter both idle and load, due to cheaper circuitry than the 1st revision.
If you can't get the 1st revision anymore, it's a damn shame. Sapphire should be ashamed of themselves.
Also, what is the maximum theoretical graphical settings I could play Crysis on and still get a playable frame rate?
* Phenom II X4 965 Black Edition
* ASUS Crosshair III Formula AM3 socket motherboard.
* 4GB of 1333 or 1600 MHz DDR3 RAM
* Sapphire Radeon HD 5870 Vapor-X
* 850W or greater PSU
* CoolerMaster HAF 932 full tower case
* DVD-RW ROM
* 1TB 7200 RPM HDD
* Windows 7 Home Premium 64-bit
ZoomStreak Mar18-10 07:36 AM
Re: A serious question about CPU/GPU bottlenecks.
I'd have a read of this article:
http://www.tomshardware.co.uk/balanc...nced_pc&xtcr=1
In general, most games are GPU limited once you have a fairly decent processor (eg. i5 750, phenom 965). The i7 often performs no better than these ones since it's set up to run 8 threads but most games aren't that well threaded. That build looks pretty good, I'd look through some of the benchmarks/reviews on tomshardware to get an idea of what it's capable of doing... should definitely play crysis at most resolutions.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
