Derivative of e^x Power Series: Own Power Series
The discussion revolves around demonstrating the differentiation of the power series for the exponential function, specifically showing that the derivative of the series \(\sum_{n=0}^{\infty }\frac{x^{n}}{n!}\) equals the series itself. Participants are exploring the differentiation of series and the role of factorials in this context.
  • Participants are attempting to differentiate the power series explicitly and are questioning how to handle the factorial in the context of differentiation. There are inquiries about the relationship between the differentiation of \(x^n\) and the power series.
The discussion is ongoing, with some participants providing hints and guidance on differentiating the series and applying the sum rule of differentiation. There is a lack of consensus on the approach, and multiple interpretations of the differentiation process are being explored.
Participants are navigating the complexities of differentiating a series term by term and the implications of treating constants such as \(n!\) during differentiation. There are indications of confusion regarding the application of differentiation rules in this context.
xvtsx
I need to demonstrate that [tex]\frac{\mathrm{d} }{\mathrm{d} x}\sum_{n=0}^{\infty }\frac{x^{n}}{n!}= \sum_{n=0}^{\infty }\frac{x^{n}}{n!}[/tex]
I just need a hint on how to start this problem, so how would you guys start this problem?
Carry out the differentiation explicitly.
Thanks for the quick reply, but I don't see how to take the derivative of the n factorial. could you please provide me with an example of how to do it?.Thanks
The n factorial is just a constant. The differentiation is with respect to x.
Okay I just got a weird answer, which I think its wrong. [tex]\frac{\mathrm{d} }{\mathrm{d} x}=\frac{(n!)}{nx^{n-1}}[/tex] could you give some steps cause for me its weird to differentiate explicitly with n and factorial.
Do you know how to differentiate x^n with n a constant? If so do you know how to differentiate constant*x^n? What if the constant equals 1/n!?
okay. if the result its 1/n! how is that related to the power series?
The result isn't 1/n!. I asked you three questions in post #6 and you avoided answering all three. If you want help you will need to cooperate.
Oh sorry. The only thing I can say is this dx/dx= n(x^n-1)(1)/n!
That is correct. Furthermore from the sum rule of differentiation you know that [itex](f(x)+g(x))'=f'(x)+g'(x)[/itex]. Therefore you can just interchange differentiation and summation. If you don't see it just write out the first few terms.
Honestly, I don't see it. what should I consider f(x) and g(x) ? because I only see n(x^n-1)(1)/n! as f(x).Sorry if I cause you trouble..
f and g are just two functions. You are dealing with a sum of more than two functions. Nevertheless the sum rule still applies in the same way and you can interchange differentiation and summation.
