Forces on a Book: Scale Reads 3 & 6 - How Can This Be?
  • Context: Undergrad
  • Thread starter Thread starter Mechanic
    Book Forces
The discussion revolves around the forces acting on a book placed on scales in different scenarios involving rockets. Participants explore the implications of acceleration, mass, and forces in a non-inertial reference frame, particularly focusing on how the scales read different values under varying conditions of acceleration and mass distribution.
  • Some participants assert that in a stationary scenario on Earth, the scale reads 3 due to equal and opposite forces acting on the book, while in a scenario with rockets, the scale also reads 3 despite the book accelerating.
  • Others argue that the readings of the scales in the rocket scenarios cannot be determined without knowing the thrust of the rockets, suggesting that the mass of the rockets is a critical factor that has been overlooked.
  • A participant emphasizes that regardless of the rockets' mass, if they are set to accelerate at g, the force on the book remains mg, questioning the impact of the rockets' arrangement on the forces acting on the books.
  • Another participant introduces a real-world example involving the space shuttle, discussing how the thrust and mass affect the readings on the scale, suggesting that additional forces come into play when considering the rockets' acceleration and mass.
Participants express disagreement regarding the interpretation of forces acting on the books in the rocket scenarios. While some maintain that the forces remain consistent, others challenge this view by highlighting the importance of the rockets' mass and thrust, leading to an unresolved discussion.
Participants note that the discussion hinges on assumptions about the rockets' thrust and mass, as well as the conditions under which the scales are reading the forces. The complexity of non-inertial reference frames and the effects of acceleration on force readings are also acknowledged but not fully resolved.
Mechanic
1.1 A weight scale is placed on a table on Earth, and a book of mass m is placed on the scale.
1.2 A force of magnitude mg is exerted on the book.
1.3 An equal and opposite force is exerted on the book by the table.
1.4 The book does not accelerate because there are equal and opposite forces of magnitude mg acting on it.
1.5 The scale is calibrated such that it reads 3 on the dial.
2.1 An identical weight scale is placed on the flattened nose of a rocket R1 throttled to accelerate through flat space at a magnitude of g and an identical book is placed on the scale.
2.2 A force of magnitude mg is exerted on the book
2.3 The book accelerates due to the application of the force from the rocket
2.4 The scale, being identical to the one on the table, reads 3
3.1 A rocket, R2, is identical to R1 and is also throttled such that it will accelerate at a magnitude of g when an identical scale and book are placed on its nose.
3.2 Remove any scale or book from the nose of R2, but leave the scale and book on R1, and place the two rockets nose-to-nose.
3.3 The book does not accelerate because there are equal and opposite forces of magnitude mg acting on it.
3.4 The scale reads 6.
In section 1 equal and opposite forces of magnitude mg cause the scale to read 3, but in section 3 equal and opposite forces of magnitude mg cause the scale to read 6. How can this be? Which of the numbered items above is incorrect?
3.3 and 3.4 are incorrect: in reality, you have no idea whatsoever what the thrust of the rocket is. The scale could read 10,000,0000 for all the information you have tells you. You're ignoring the mass of the rocket.
I went out into flat empty space and set the rocket throttles such that the acceleration of the books on the rocket noses was measured to be g. The mass of the book is m, so the force accelerating the book is mg, regardless of the mass of the rockets. Is this what you disagree with? I’m sure you’ve heard of the man in the rocket that is accelerating at g who cannot tell whether he is in such a rocket or on the surface of the Earth. That is the case regardless of what the mass and/or thrust of the rocket is – just as long as the acceleration is g. Are you saying that by arranging the rockets to be nose-to-nose the magnitude of the forces on the books change even though the throttles are set as described above?
Thanks
Yes...
Correct.
No. What you're missing is that the rockets are also accelerating at g, so the force applied to them is m(rocket)g. And then when you put two rockets nose to nose, you aren't just stopping the acceleration of the books, you are also stopping the acceleration of the rocket.
Consider this real-world example: The space shuttle. The space shuttle has a takeoff mass of almost exactly 2 million kg. The thrust at takeoff is:
Boosters: 12.5 million N each (2)
Main Engines: 5.4 million N total
That's an acceleration of: 1.55 g. Minus the 1g of gravity means that at takeoff the space shuttle accelerates at 0.55g.
So if you set your scale and book on top of it, it would read about 1.5N
But right before the shuttle lifts off, it is held down by explosive bolts. Alternately, you could just put a big object on top holding it down, similar to your nose-to-nose rockets. These bolts or this object pushing down on it must absorbe .55g*M(rocket), or about 11 million N of force.
  • · Replies 24 ·
  • · Replies 128 ·
12K
  • · Replies 49 ·
  • · Replies 30 ·
