Density of electrons and quarks
The discussion centers on the density of electrons and quarks, exploring their properties as fundamental particles and comparing their densities to that of neutron stars and white dwarf stars. Participants examine the implications of treating these particles as point-like versus having measurable sizes, and the challenges in defining their densities.
  • One participant claims the density of an electron is e21 gm cm3, suggesting it is significantly denser than a neutron star.
  • Another participant challenges this by stating that electrons and quarks are thought to be point particles, implying infinite density.
  • A different participant disagrees with the point particle characterization, referencing a source that provides mass and radius for quarks and electrons.
  • Further clarification is provided that the size limits for these particles are based on experimental upper limits, not definitive measurements.
  • A participant references Kip Thorne's work on white dwarf star densities and discusses the complexities of measuring particle sizes due to quantum mechanical effects and the Heisenberg uncertainty principle.
  • Concerns are raised about the ability to measure the size and density of fundamental particles, suggesting that quantum mechanics complicates these measurements.
Participants express differing views on whether electrons and quarks can be considered point particles, with some asserting they are while others provide evidence against this notion. The discussion remains unresolved regarding the accurate characterization of their densities.
Participants note limitations in defining particle sizes and densities due to the nature of quantum mechanics, including the effects of wave-particle duality and the Heisenberg uncertainty principle. There is also mention of the lack of consensus on how to compute the density of atomic particles.
This discussion may be of interest to those studying particle physics, quantum mechanics, or astrophysics, particularly in understanding the properties of fundamental particles and their implications in various physical contexts.
jimjohnson
I recently noticed that the density of an electron, assuming it is a particle, was e21 gm cm3. This is e7 x more than a neutron star 2 x e14. I then looked up quarks. The up quark is the most dense (mass = 9 x e-27 gms, radius .5 x e-17 cm) with a density e5 x the electron or 1.7 x e25. Thus, a quark is e12 x more dense than a neutron star.
Is this correct??
I don't know how you are calculating the density of electrons and quarks, but they are thought to be point particles, and are thus of infinite density so to speak.
No, I do not think they are point particles. My source for mass and radius is a chart on fundamental particles from cpepweb.org.
For the electron and quark it says the size is <10^-18m and <10^-19m respectively. These numbers aren't what people think the sizes are, they are upper limits from experiments on what the sizes would be if there was any size at all. A size of 0 (point particle) is consistent with "<10^-18m".
Thanks for checking source and responding. I will have to research point particles.
Kip Thorne in his book BLACK HOLES AND TIME WARPS has some fascinating discussion on the density of white dwarf stars beginning on page 140, and continuing thru all of Chapter 4 and beyond.
Sirius B a well know white dwarf has a density of about 4 millions grams per cc, or about 60 tons per cu in based on modern astornomical observations. A formula called the Stoner-Anderson equation of state allows computation of the resistance to collapse (and formation of a black hole) as a function of density. For such astronomical bodies, electron and neutron degeneracy play major roles in resisting collapse, far more than thermal vibrations. His discuss will give you a good feel and some basic mathematics for astronomical bodies.
I do NOT know of any reasonable way to compute the density of an atomic particle, electron or any other, but my gut feel tells me its (a) quantum mechanical and (b) a probability type function. I think post #4 has the right idea...but there is more to why such an upper size limit exists.
Part of the physical measurement problem is that when one tries to confine any particle for measurement, Heinsenberg uncertainty comes into play as does wave-particle duality. This means when you try to hold an electron still and get a "size" measurement, it's wave becomes more and more frantic...you can't confine it to measure it's size...it's analogous to electron degeneracy which is a major factor resisting neutron star collapse into black holes. In an analogous way, when you try to probe an electron with ever larger experimental frequencies, that means additional energy, and to get a more accurate "picture" you end up adding energy to the particle...increasing thermal vibrations and obscuring it...
I did a quick check of Wikipedia http://en.wikipedia.org/wiki/Electron
and the description of an electron has a lot of data but I did NOT see size nor density...
  • · Replies 58 ·
9K
  • · Replies 17 ·
  • · Replies 26 ·
