About the significance of commutivity
  • Context: Graduate
  • Thread starter Thread starter snoopies622
    Significance
The discussion revolves around the significance of commutativity in quantum mechanics, particularly in relation to angular momentum operators. Participants explore the implications of commutation on eigenvectors and the degeneracy of operators, examining both theoretical and conceptual aspects without reaching definitive conclusions.
  • Some participants propose that if operators A and B commute, all eigenvectors of A are eigenvectors of B if A is non-degenerate, while others argue that if A is degenerate, only some eigenvectors may be common.
  • There is a suggestion that the angular momentum operators L_x, L_y, L_z, and L^2 may be non-degenerate, but this is contested with claims that they are actually degenerate.
  • One participant references a source indicating that every eigenvector of the L_z operator is also an eigenvector of the L^2 operator, but not vice versa, raising questions about the degeneracy of L^2 and the other operators.
  • Another participant discusses the implications of an operator "connecting" eigenspaces, suggesting that commuting operators cannot connect different eigenspaces of another operator.
  • There is a discussion about the non-degeneracy of the momentum operator compared to angular momentum operators, with some participants expressing confusion over the definitions and implications of degeneracy in different contexts.
  • Participants express varying levels of interest in the practical applications of these concepts, with some focusing on theoretical understanding rather than practical use.
Participants do not reach consensus on the degeneracy of the angular momentum operators or the implications of commutativity. Multiple competing views remain regarding the nature of eigenvectors and the definitions of degeneracy.
Limitations include unresolved definitions of degeneracy, assumptions about the operators in question, and the complexity of the relationships between different operators and their eigenspaces.
This discussion may be of interest to those studying quantum mechanics, particularly in understanding the properties of operators and their implications in theoretical contexts.
snoopies622
This pertains to the quantum mechanics of angular momentum, so I'll ask it here:
If operators A and B commute, does it follow that
(i.) all of A's eigenvectors are eigenvectors of B and vice versa,
or that
(ii.) merely some of them are?
According to Gillespie (see below) the commutivity of A and B implies that they "possess a common eigenbasis" (and the converse) and his proof seems to imply (i.), but it assumes that the operators are non-degenerate, and I don't know if the angular momentum operators are. Also, if (i.) and its converse are true, then it would seem to me that if A and B commute and A and C commute, then B and C would also commute, and I know that that's not supposed to be true. Nevertheless, so far I haven't found anyone explicitly say that (ii.) is the case.
The book is "A Quantum Mechanics Primer" by Daniel T. Gillespie, 1970.
If A and B are [itex]n\times n[/itex] matrices so that they commute, then following claims are true:
If A and B are non-degenerate (no eigenvalue appears more than once in diagonal form), then the eigenbasis of A and B are the same. All eigenvectors of A are also eigenvectors of B.
If A is degenerate (at least some eigenvalues appear more than once in diagonal form), then it is possible to choose a common eigenbasis for the both A and B. Not all eigenvectors of A are necessarily eigenvectors of B.
I. All of A's eigenvectors are eigenvectors of B.
If A has degenerate eigenvalues, then the B matrix will be block-diagonal, meaning it can be diagonalized by a unitary operator. So by a suitable change of basis, it will be diagonal in both, and you will have the same eigenvectors.
Edit: Oh well, Jostpuur beat me to it, and said it better too ;)
So then, the angular momentum operators [itex]L_x , L_y , L_z , L^2[/itex] are all non-degenerate?
I'm also looking at Richard L. Liboff's "Introductory Quantum Mechanics", and in section 9.1 he indicates that every eigenvector of the [itex]L_z[/itex] operator is also an eigenvector of the [itex]L^2[/itex] operator, but the reverse is not true. The same is true for the [itex]L_x[/itex] and [itex]L_y[/itex] operators (in their relation to [itex]L^2[/itex]). I take it then that [itex]L^2[/itex] is degenerate, but I don't yet know about the other three.
They are all degenerate.
If two operators a and b commute, and a has some eigenspace L for an eigenvalue l then b cannot connect two eigenspaces of a.
If v1 is an eigenvector in the eigenspace L, then there are two possibilities when b is acting on v1: Either v1 is also an eigenvector of b or b transforms v1 into another vector that is also in L.
0xDEADBEEF said:
..b cannot connect two eigenspaces of a.
I'm sorry but I don't know what this means. What does it mean for an operator to connect two eigenspaces of another operator? That both eigenspaces of a are also eigenspaces of b?
I used the word "connect" for convenience without a formal definition. I thought the next sentence would explain it. If you apply b to a vector in L the resulting vector must stay in L. b cannot produce vectors outside of L but in another eigenspace say M from vectors in L.
I get it now. Thanks, 0xDEADBEEF.
Do you mean the four operators I mentioned in entry #4, or all operators in quantum mechanics?
I meant the four that you mentioned. The momentum operator is not degenerate for example.
But how does one know if an operator is degenerate or not?
You'll learn about all the eigenspaces of the important operators soon enough. There is no generic way to know if an operator is degenerate, and it is not that important.
0xDEADBEEF said:
There is no generic way to know if an operator is degenerate...
It does seem odd that
[tex] <br /> \hat {p_x} = - i \hbar \frac {\partial}{\partial x}<br /> <br /> [/tex]
would be non-degenerate while
[tex] <br /> \hat {L_z} = - i \hbar \frac {\partial}{\partial \phi}<br /> <br /> [/tex]
is degenerate.
Lx,Ly,Lz are not degenerate, as is L**2. To get two states with the same Lz=m, one must use two different values of l, hence these two states are not degenerate. Work out the matrices for L=2,3,4, and see directly the lack of degeneracy of the Li operators.
Regards,
Reilly Atkinson
I confess that I suspected as much.
Unfortunately, I don't know how to do that. Perhaps I can find out.
Regards,
Reilly Atkinson
l does not matter for the discussion of the degeneracy of Lz. All States with the same m number can be superimposed and form the respective eigenspace for that eigenvalue.
is degenerate.
It is a bit more tricky. [tex]p_x[/tex] itself is degenerate, on the three dimensional space, because it doesn't matter what the dependency of the wave function w.r.t. y and z is.
But in three dimensional space the full momentum operator that yields a vector as an eigenvalue is not degenerate. In two dimensions Lz is not degenerate, because we can only turn in one dimension.
What reilly describes is the fact that you can get a complete set of operators that all commute and then you can number the states in your system. So although the energy operator, [tex]L^2[/tex] and [tex]L_z[/tex] are all degenerate, because there are multiple functions with n=5, l=3 or m =2 the state that fulfills all three at the same time is unique. He confused this with degeneracy of a single operator.
So really don't get too confused. If you can write down two different functions that give the same eigenvalue, then the operator is degenerate. Simple as that.
can anyone put this into a practical use or just formulas for the sake of formulas? just trying to figure out peoples interest in this if not to develop new ideas or fix what is broken.
Two dimensions? Which dimension are you leaving out? Does it matter?
Hi ShadeTreePhys. I'm just trying to understand quantum mechanics, with no practical application in mind. I'm not trying to develop new ideas, and I don't assume that anything about QM is broken.
totally cool. i love seeking the know just to know. qm by it's self is not broken. the ref was to the lack of compatibility with the classical.
Common! Look at the operators. If we leave out the z dimension then Lz is the only one of the three operators that makes any sense. It uses x and y and their derivatives, and describes rotations in the x,y plane.
Oh, OK. I thought you were using spherical coordinates.
  • · Replies 17 ·
  • · Replies 19 ·
