Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   General Physics (http://www.physicsforums.com/forumdisplay.php?f=111)
-   -   explain when will upthrust change? (http://www.physicsforums.com/showthread.php?t=421198)
starwars32 Aug9-10 08:42 AM
Hi.. Can someone explain when will upthrust change? cos i come across books saying that upthrust will not change when two objects of different density but same material are placed in the same fluid. I also come across that upthrust will not change when same objects are being transferred from liquid a of different density to liquid b of another density, the upthrust also will remain same. Can some one pls explain to me when and when will upthrust not change? Under wad conditions thanks!
mgb_phys Aug9-10 09:08 AM
Re: Upthrust
The upthrust is equal to weight of the fliud the object displaces - so it depends on the size (volume) of the object and the density of the fluid - thats all
starwars32 Aug9-10 09:35 AM
Re: Upthrust
then does weight of an object plays a part? Next, if lets say for the same object, we put in fresh water of Density 1, we have an upthrust of U, if we put this object in sea water of Density 2, will we have a simliar upthrust?
sfsy1 Aug9-10 11:41 AM
Re: Upthrust
The weight of the object doesn;t affect upthrust, they are 2 different forces. And no upthrust will not be the same because the density of the fluid changed.
As said in the previous post, it's the volume of the object (i.e. the amount of fluid displaced) and the density that matters.
mgb_phys Aug9-10 12:52 PM
Re: Upthrust
Quote:
Quote by starwars32 (Post 2832844)
The upthrust is normally defined as just the upward buoyancy force - the overall buoyancy, or apparent weight, will depend on the upthrust and weight.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
