Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Differential Geometry (http://www.physicsforums.com/forumdisplay.php?f=76)
-   -   Smooth manifold and constant map (http://www.physicsforums.com/showthread.php?t=436579)
huyichen Oct10-10 01:04 AM
smooth manifold and constant map
Suppose M and N are smooth manifold with M connected, and F:M->N is a smooth map and its pushforward is zero map for each p in M. Show that F is a constant map.
I just remember from topology, the only continuous functions from connected space to {0,1} are constant functions. With this be useful in solving the problem?
quasar987 Oct10-10 08:11 AM
Re: smooth manifold and constant map
Show that if M is connected, then a locally constant map F:M-->N is (every pt has an open nbhd where F is constant) is constant.
Then show that a vanishing pushfoward implies that F is locally constant.
Tinyboss Oct10-10 10:29 PM
If you define a path between arbitrary points of M, your domain becomes [0,1] which is easier to work with. If you're using Lee (I think I remember this exercise) you have as a theorem that connected manifolds are path connected.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
