Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   General Physics (http://www.physicsforums.com/forumdisplay.php?f=111)
-   -   What is time? (http://www.physicsforums.com/showthread.php?t=451115)
jeebs Nov25-10 11:47 AM
What is time?
I recently realized that we use this concept constantly but I have absolutely no idea how I would answer this. Never in any school physics lesson or university lecture I've attended has anyone even mentioned this. It's just sort of taken for granted because we all have experience of it passing. This a pretty open ended question, just thought I'd throw it out there. So, how would you define this quantity we call time?
Edi Nov25-10 02:07 PM
Re: What is time?
Tim is change/ movement. If there is no movement/ change in a system (and I mean at the deepest possible level), then practically, there is no time flowing. And it works backwards - no time= no change/ movement.
Jap.. this is the best I have :P
And yes - this is a very good and fundamental question that is bugging me for some time now..
pallidin Nov25-10 04:16 PM
Re: What is time?
I would agree. "Time" is just a concept that involves "change"
Without change there can be no time.
However, one has to be a little careful with this.
That is, just because something may not change internally does not mean that it doesn't change with respect to its external environment.
Movement of an internally, non-changing object through space is an example.
In short, "time" is a measurement of change, specific on perspective frame.
jeebs Nov25-10 06:04 PM
Re: What is time?
that's kind of unsatisfying I think. I mean, we could be sat in an enclosed room with no windows just staring at a wall, and be unable to detect any movement of anything, but we'd have no reason to suppose that time had stopped just because we couldn't see any of its effects. we could assume the world outside was still going about its business. am I missing the point here?
khemist Nov25-10 06:20 PM
Re: What is time?
You see the effect of time because you are still living. The fact your heart is beating is an indicator of time.
Time is obviously relative, however, and people might not agree on the simultaneity of a specific event.
bp_psy Nov25-10 06:36 PM
Re: What is time?
My favorite textbook definition for time is :
"If the internal state of a particle or a localized object is changing, its successive states define a continuum,which we call the time of that particle"
Classical Mechanics, Volume 1 A. Desloge
Whether that is enough for you is another issue.
Arsenic&Lace Nov25-10 07:13 PM
Re: What is time?
"Time is what happens when nothing else does." --Feynman Lectures
James A. Putnam Nov25-10 08:58 PM
Re: What is time?
The difficulty with time, I think, has to do with perception. We receive data from photons that consist of changes of velocity with respect to time. Moving down theoretically, it means that changes of distance with respect to time are not constant, they vary. I know that you know this. My point is that if we return to considering the data, and, recognize that we use it to form a visualization of what may be happening in the outside world, then visualizing distance and not visualizing time is a matter of interpretation. Time is not less real than is distance. Distance does not gain credibility leaving time to be an effect just because one is visualized and the other is not. (Gravity is not visualized either).
The cause of changes in distance are not known. The cause of time is not known. That is because, we do not know what cause is. Theoretical physics is necessary in order to substitute imagined causes for that which we cannot know. We can imagine something that we choose to generically call force to account for changes of position of an object; but, we cannot imagine something that causes time to move on. Force causes acceleration; but, that same imagined cause cannot cause time to accelerate. It is rather inferred from theory. Inferring is not satisfactory for explaing what time is. So, without an obvious clear answer, it is sometimes put forward that the motion of objects causes time. In other words, time is an effect.
Relativity theory seems to support this idea, so, it continues to be put forward. My point to this is that everything we observe is an effect. We never observe cause. Therefore, that which we observe objects to do may relate to time, but, cannot be shown to be the cause of time. The 't' in physics equations is always about a non-constant standard of cyclic activity. When that 't' varies it does not tell us what time is doing, it tells us what that cyclic activity is doing. If we discovered a measure of duration in time that was constant everywhere, at all time, in the universe, then we would know that time is not an effect of motion. However, that discovery would also necessitate doing away with Relativity Theory alltogether. Perhaps the most interesting possibility of an existing natural constant standard of time is that as a universal constant it should already appear in today's theories. Its interpretation may be incorrect; but, it should be already recognized by us under a different name.
Everything we learn comes from observing patterns in changes of velocity. There are two clearly fundamental properties that we cannot put into containers. We cannot isolate them in order to experiment on them. Neither one experiences changes of velocity. Those two properties are space and time. Since we cannot push or pull either of them, we cannot make measurements of rates of change for either. We only experiment on objects. We only know what it is that objects do. Objects are always things that exist in space and during time. Objects cause other objects to change that which they were doing. Objects causing effects that we observe to occur to other objects do not tell us about either space or time.
James
PhysDrew Nov25-10 10:08 PM
Re: What is time?
The simplest of question yet one of the most elusive!
Wasn't the question of time's uni-directionality one of the causes for physicist's to attempt to formulate a theory of everything? For in order to examine the nature of time, one must go back to the beginning. And once physicists mathematically examined the beginning with the two main theories of the time, the maths turned out to be nonsense.
And i dont think that the implication that if an entity is living, time is passing. A virus is considered 'dead' outside of a host. Surely time doesnt stop for the virus? How would it's metabolism kick in once it found its way into a host? How would it know, if time ceased for the virus?
71STARS Nov25-10 10:10 PM
Re: What is time?
Time is a measure of our Planet's 24 hour segment. Other planets and star system will naturally differ. We have even calculated light-years based on our conception of the Speed of Light, but it may differ within other systems. Bottom Line: Time is a measure.
Oldfart Nov26-10 01:36 AM
Re: What is time?
I think of time as a sort of ether which is repelleded by mass, energy. and by objects moving through space. Thus it might be a particle, and maybe is represented by what we call dark energy. Figuring this out is way outside my pay grade...
OF
Pilot7 Nov26-10 05:35 AM
Re: What is time?
The question is the deepest (physical) question I know. I spend several years on this one (basically as the guiding question of a masters and then PhD thesis in philosophy and the philosophy of physics).
Here is my favourite answer:
Time is God's way of keeping everything from happening at once...
Okay, and a little more explicative:
Time in physics actually has somewhere on the order of 14 flavours. For example in quantum physics, there are at least 10 different and even inconsistent definitions of time. Relativity theory, Quantum Gravity, etc. all do weird things with time. Coming back to classical physics, even here it has several variants. There is time the measure used in a laboratory and time the theoretical metric used to describe the evolution of classical systems. And there are some ways it has been used to talk about entropy and even be defined in terms of entropy (thinking to Prigagine for example).
On thing in all of this to keep in mind. All notions of “flow” are strictly non-physical. In fact, this sort of “time” has been traditionally called “psychological time”. Now what I will add is that if you think this through, you will see that there is still a pretty serious mystery behind all this: What is flow? This was the question I was addressing in the context of my graduate work—very subtle stuff. There is not theory in physics that even hints at what this could conceivably be, with the possible exception of certain variations of quantum gravity that treat the wave collapse as a genuinely “real” or ontological phenomenon. Even then, it requires something of a conceptual dance to tease out the semantic features that would make flow flow (pun intended).
If anyone is interested, write me and I will forward a copy of one of my papers that has a fair amount of background of all this stuff in it. (In other words, even if you don't like my approach to the problem, you get a taste of who else has said what about the issue).
GoliathX Nov26-10 03:21 PM
Re: What is time?
I have a theory which can explain time, dark matter, dark energy and the expansion of space easily.
First, I do not have a background in mathematics or physics. I was pursuing a pre-engineering degree before I got derailed by life stuff and will not be going back anytime soon.
Second, how can I go about getting taken seriously? Where is a place that I could honestly begin?
This is an honest inquiry and no I will not share this information publicly.
Thank you.
Athletico Nov27-10 09:40 AM
Re: What is time?
Quote:
Quote by GoliathX (Post 3005059)
Thank you.
I'd post your thoughts here. People on PF are pretty open-minded for the most part. Just be prepared for criticism - especially if your views are highly speculative and go against the grain of accepted theories.
DrGreg Nov27-10 10:51 AM
Re: What is time?
Quote:
Quote by Athletico (Post 3006041)
Thank you.
No, if your views are highly speculative and go against the grain of accepted theories, then it's against the rules of this forum to post your thoughts here:
Quote:
Quote by Greg Bernhardt
Overly Speculative Posts:
One of the main goals of PF is to help students learn the current status of physics as practiced by the scientific community; accordingly, Physicsforums.com strives to maintain high standards of academic integrity. There are many open questions in physics, and we welcome discussion on those subjects provided the discussion remains intellectually sound. It is against our Posting Guidelines to discuss, in most of the PF forums or in blogs, new or non-mainstream theories or ideas that have not been published in professional peer-reviewed journals or are not part of current professional mainstream scientific discussion. Personal theories/Independent Research may be submitted to our Independent Research Forum, provided they meet our Independent Research Guidelines; Personal theories posted elsewhere will be deleted. Poorly formulated personal theories, unfounded challenges of mainstream science, and overt crackpottery will not be tolerated anywhere on the site. Linking to obviously "crank" or "crackpot" sites is prohibited.
Unfortunately, without a background in mathematics or physics you will have great difficulty in being taken seriously anywhere else. For people to take your theory seriously, they will expect you to have a good understanding of existing theories. (E.g. see the Independent Research Guidelines referred to above.)
GoliathX Nov27-10 01:33 PM
Re: What is time?
Quote:
Quote by DrGreg (Post 3006130)
It is not really that highly speculative, all it really is is a change in perspective of how the current theories are currently viewed. It is just one thing or idea that can explain a bunch of these things we scratch our heads at, more than just specified above.
I have a good understanding of existing theories, I just do not have the schooling to go with it. Well read, just can't do the math, by myself that is. I would love to work with somebody that does possess those qualities, but I have no idea how to go about finding somebody willing to come down to my level (little math).
I don't just want to throw the idea out there however, especially on a message board. It is not because I am worried about criticism, that is expected.
pallidin Nov27-10 03:48 PM
Re: What is time?
Well, that must be "earned"
That is, you must prove yourself right(or reasonably so) WITHOUT any DEMAND that others MUST prove you wrong.
In other words, try not to have an attitude like "well, you can't prove me wrong so I must be right"
That just goes nowhere really fast, and makes one look like a babbling idiot.
So, with a speculative theory, I would approach it by first asking reasonable, specific questions. Allow yourself to be educated by the responses.
GoliathX Nov27-10 04:16 PM
Re: What is time?
Quote:
Quote by pallidin (Post 3006517)
That is not an issue. I am trying to bring this information humbly, I know where I stand. I am at the bottom rung of the ladder pretty much when it comes to credentials.
I have seen plenty of people raise their hands triumphantly saying THEY HAVE THE ANSWER only later to be seen with their tail between their legs. I do not have THE ANSWER. What I have may possibly be an answer, but I don't have the means or the methods to verify this by myself.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
