Calculating Thrust in Propeller Engines: Can Anyone Help?
The discussion focuses on calculating thrust in propeller engines, specifically using the formula Thrust = Mass airflow × (Slipstream velocity - Aircraft velocity). Given the parameters of 1000 Kg/s mass airflow, 100 m/s aircraft velocity, and 120 m/s slipstream velocity, the correct thrust calculation is 20,000 N. The user initially misapplied the force equation F = ma without considering the slipstream velocity, leading to confusion. A helpful resource was provided for further understanding of propeller principles.
  • Understanding of basic physics principles, specifically Newton's second law (F = ma).
  • Familiarity with aircraft propulsion technology and terminology.
  • Knowledge of mass flow rate in propulsion systems.
  • Basic understanding of slipstream dynamics in aerodynamics.
  • Research the derivation and application of the thrust equation in propeller engines.
  • Explore the impact of slipstream velocity on overall aircraft performance.
  • Learn about the principles of mass flow rate in propulsion systems.
  • Investigate advanced topics in aerodynamics related to propeller efficiency.
Aerospace engineers, students studying aircraft propulsion, and anyone interested in the mechanics of propeller-driven aircraft will benefit from this discussion.
Emzielou83
Can anyone help me?
I'm doing a question on aircraft propulsion technology and I'm stuck.
The question is:
'If the mass of air through a propeller is 1000 Kg/s, the aircraft's velocity is 100 m/s and the slipstream velocity is 120 m/s, calculate the thrust?
Attempt at answer:
Surely if F = ma then the equation should be F = 1000 * 100 = 10000 Kg/s
But I don't think this is the right answer as I have not taken the slipstream velocity into consideration.
The only other equation I can find is
F = (m dot * V)e - (m dot * V)0 + (pe - p0) * Ae
But I don't have pe or p0 or Ae neither do I understand what they are.
Can someone please steer me in the right direction?
Thanks
Hi, with the given conditions, thrust can be calculated by using the formula:
Thrust = Mass airflow X (slipstream velocity-aircraft velocity).
Below website has good information may be it helps you.
http://www.flightlearnings.com/basic-propeller-principles-part-two/384/"
Thanks very much.
It seems so simple now, just couldn't see it.
Thanks again
  • · Replies 25 ·
  • · Replies 26 ·
