Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Interchange of limit operations (http://www.physicsforums.com/showthread.php?t=455259)
ait.abd Dec9-10 01:11 PM
Find a sequence of continuous functions [tex]f_n: R \rightarrow R[/tex] such that [tex]lim_{x \rightarrow 0}lim_{n \rightarrow \infty}f_n(x) [/tex] and [tex]lim_{n \rightarrow \infty}lim_{x \rightarrow 0}f_n(x) [/tex] exist and are unequal.
2. Relevant equations
N/A
3. The attempt at a solution
I think I need a sequence of continuous functions that has a limit function which is continuous at zero but discontinuous at some other point. In that case, the sequence of functions will not be uniformly convergent and we will not have these limits equal. But I dont know what function can fulfill this criteria.
micromass Dec9-10 01:16 PM
Re: Interchange of limit operations
Well, can you give a sequence which is not uniformly convergent?
ait.abd Dec9-10 01:23 PM
Yeah I can but the limits turn out to be equal. For example,
[tex] f_n(x) = (cos(x))^n[/tex]
[tex] lim_{n \rightarrow \infty}lim_{x \rightarrow 0} f_n = 1 [/tex]
[tex] lim_{x \rightarrow 0}lim_{n \rightarrow \infty} f_n = 1 [/tex]
This sequence is not uniformly convergent but the two limits are equal. The question requires them to be UNEQUAL.
ait.abd Dec9-10 01:24 PM
In above post, there is a mistake.
[tex] lim_{x \rightarrow 0} lim_{n \rightarrow \infty} f_n(x) [/tex] doesn't exist. The question requires them to EXIST.
micromass Dec9-10 02:30 PM
Are you certain that it doesn't exist? I think that the limit does exist and equals zero.
You do have to restrict the function to [-pi,pi], otherwise there is no limit...
ait.abd Dec9-10 02:43 PM
Quote:
Quote by micromass (Post 3028852)
Let's say we restrict the sequence to [-pi,pi] and say it is zero everywhere else (because we have to define it on R and not a subset of it).
Yes it doesn't exist. As you can see the limit function is following
[tex]lim_{n \rightarrow \infty}f_n(x) = 1 for x=0[/tex]
[tex]lim_{n \rightarrow \infty}f_n(x) = 0 , elsewhere} [/tex]
So the limit function is discontinuous at x=0 and [tex] lim_{x \rightarrow 0} f(x) [/tex] doesn't exist. By the way, it is the very first question of the exercise so it should be easy (I think so :confused: ) I dont know where I'm missing the point.
micromass Dec9-10 02:49 PM
So, the limit function is
[tex]f(0)=1~\text{and}~f(x)=0~\text{if}~x\neq 0[/tex].
Then the limit [tex]\lim_{x\rightarrow 0}{f(x)}[/tex] certainly exists (and it equals 0)! You can easily prove this with the definition of limit...
ait.abd Dec9-10 02:58 PM
Quote:
Quote by micromass (Post 3028885)
Don't mind my asking very basic questions because i think my definition of limit is flawed.
What I know is that limit is defined, in above case, when f is defined on C{0} i.e. R - {0}. In this case, we can say limit x approaches 0 is zero as you described. But, since function is defined on x=0, shouldn't we take f(0) as limit ? Also, if we take it as a limit as you say, shouldn't the limit be different if we approach it from either side i.e. (-pi,0) and [0, pi). So a limit is not really defined here?
micromass Dec9-10 03:10 PM
No, the limit of f is independent of f(0). The limit of a function is what the function value should be to make the function continuous. In our situation, we have that the function is 0, except in the point zero. So if f(0)=0 (which is not the case), then the function f would be continuous. This means that the limit of f equals 0.
ait.abd Dec9-10 03:18 PM
Quote:
Quote by micromass (Post 3028921)
I got it now ...and in that case limit will be zero irrespective of the direction we use to approach x=0. Thank you very much micromass it really helped. Thanks again.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
