How Do You Calculate Vector Sums and Differences Graphically?
  • Thread starter Thread starter soul814
    Physics Vector
The discussion revolves around calculating vector sums and differences graphically, specifically focusing on two vectors: Vector A, which is 3.00 units along the positive x-axis, and Vector B, which is 4.00 units along the negative y-axis. Participants are exploring how to graphically represent the addition (A + B) and subtraction (A - B) of these vectors.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the graphical representation of vectors, including the use of the parallelogram method for vector addition. There are questions about the correct interpretation of vector components and the resulting angles. Some participants express confusion about the graphical methods and the calculations involved in determining the resultant vector's magnitude and direction.
The discussion is ongoing, with several participants attempting to clarify their understanding of vector addition and subtraction. Some guidance has been offered regarding the graphical methods, and there is active engagement in exploring different interpretations of the problems presented.
Participants mention challenges with understanding the concepts due to teaching methods and textbook explanations. There is also a focus on ensuring that the graphical representations maintain the correct magnitude and direction of the vectors involved.
soul814
Vector A is 3.00 units in length and points along the positive x-axis. Vector B is 4.00 units in length and points along the negative y-axis. Use graphical methods to find the magnitude and direction of the vectors.
Find
A) A+B
B) A-B
I don't get it.
Welcome to PF!
Post in some more detail why you don't get it.
Well I'm taking ap physics right now and I don't get it my teacher just puts two problems on the board every day and then goes on solving them. He doesn't teach, so far I don't get any thing in physics.
Thats a question from my textbook. Is A) 3+-4? That seems wrong. Since R = Vector of (A) + Vector of (B)
but isn't the vector of A = 3?
since 3cos90 = 3
How would you solve this problem?
Use the paralelogram addition of vectors.
I have no clue what to do? I read the chapter three times and I just don't get it. I know what hte parallelogram addition of vectors is.
Its when you make a diagonal line between the two constants.
Can someone solve it with an explanation for me? Since even if you say all these rules I still won't get it. I have this textbook
http://www.brookscole.com/cgi-wadsw...uct_isbn_issn=003023798X&discipline_number=13
All right, let's take it easy!
1. Suppose you draw an arrow on a piece of paper.
That arrow has two features:
a) It has some length
b) It has a direction
You get that?
yep, the coordinates of X would be (0,0) to (0,3)
the coordinates of Y would be (0,0) to (0,-4)
Good!
So the arrowhead of X lies at (0,3) and the arrowhead of Y at (0,-4)
Do you agree with this?
yes i got that much
A useful property of vectors is that they remain the same vector if you move them as long as you don't change their magnitude or direction. So, you can move vector B out along the positive x-axis until its "foot" is at the "head" of vector A, and it's still the same vector. Now, what would the vector be that you could draw from the origin to the tip of vector B in it's new position?
(3,0) to (3,-4) so it would look like
Allright!
At this position, both X and Y has the "foot" at the origin.
You are asked to ADD Y to X.
That means:
"Slide" the foot of Y along X (without rotating Y!), such that when the foot of Y coincides with the arrowhead of X, you've got a line segment parallell to Y attached to the arrowhead of X (that line segment (the "translated Y") is of equal length as Y).
Draw this.
We say that the SUM of X and Y is the vector which has its foot in the origin, and its arrowhead coincident with the arrowhead of "translated Y"
Get that?
Looks like I was a day late and a dollar short here! Sorry for jumping in the middle of this!
like that right? and then you draw a line? and use the pythagorean theorem
Precisely!
This is the graphical way in summing two vectors together; how can you do this arithmetically if you're given the vector's components?
a squared + b squared = c squared?
3*3 + (-4)*(-4) = 25
square root of 25 = 5?
The Sum of (3,0) and (0,-4) is given by:
(3,0)+(0,-4)=(3+0,0-4)=(3,-4)
(It seems you did this somewhere..)
The magnitude (length) is, as you said, 5.
What is the vector's direction (given, for example, as the angle the vector makes with the x-axis)
45 degrees, going southeast, Oh when they ask what is A + B they are asking for the point at which it ends
45 degrees are incorrect; think again.
negative 45?
No, why did you think it was 45 in the first place?
3-4-5 triangle?
That's definitely correct, but there's no 45 degrees angle in that triangle.
Lets look at the tangent value in a 3-4-5 angle:
You have:
[tex]tan(\theta)=\frac{oppositeside}{adjacentside}[/tex]
In your case (let's just look at "4" rather than "-4") you have:
[tex]tan(\theta)=\frac{4}{3}[/tex]
Agreed?
now, what angle [tex]\theta[/tex] satisfies that equation?
(You'll need to use your calculator)
ummm about 53 degrees
That's right, so you'll agree the angle the vector (X+Y) is about -53 degrees respective to the x-axis?
Now, for your second problem, how would you approach this one?
A - B
Umm my guess is
A (0,0) to (3,0)
B (0,0) to (0,4) Since its Negative
Same magnitude, and this time its positive 53?
Your drawing is incorrect:
Let C=X-Y.
Hence, we have:
Y+C=X
(that is C is the vector added to Y so that the result is X)
Draw this.
(By the way, the coordinates of the arrowhead of C when its foot is at the origin is (3,4))
is it correct now?
You've certainly plotted the vector (3,4) correctly, however:
1. Plot Y, that is, the line segment from the origin down to (0,-4)
2. Plot X, that is, the line segment from the origin to (3,0)
3. Draw the line segment from the arrowhead of Y to the arrowhead of X.
4. Verify that that line segment is parallell to, and of equal length to the vector going from the origin to (3,4)
so its similar to my first graph for part A except you don't move it over?
  • · Replies 30 ·
  • · Replies 16 ·
